![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score I checked the error with Autoenginuity software and it shows Anti-lock Brakes CAN U2023 Fault received from external node . If I restart the car the dash light is gone. I checked all 4 wheel speed sensors and they all have clean connections and a clear view to the axle (front) or tone ring (back). Any tips? 2007 with 107k miles. Only engine mod is CAI. Last edited by Lex2007; 04-05-2016 at 08:56 PM. |
![]() Join Date: Dec 2013 Location: Pinckney, Michigan
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 794
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score A U2023 points towards a Keyless control module. I have no records for a DSC/ABS module
__________________ 2011 MS3 COBB AP/Hypnotic Tuned/JBR 3.5in WP/CS Wiper Delete/EBAY DP/CS RMM/CS Lowering springs/Maisonvi shift bushings and knob/OBX Catback/AT Internals/Synapse DV/ CP-E TMIC/E30 |
(Thread Starter) | Not Ranked : 0 score Alpine, Why would a keyless control module trigger the loss of traction symbol on the dash? |
![]() Join Date: Sep 2011 Location: Canada
I am just getting into learning about CAN myself, so I am not much help, but I believe there is no real problem with the TCS system, but you may have a bad or failing connection between CAN connected units. TCS might be getting confused or going into limp mode because of misinformation (possibly from keyless). Clear as mud?
__________________ SyntheticAtmosphere '06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit If it feels good, do it...Even if you shouldn't! | |
| Not Ranked : 0 score "U2023 Fault Received From External Node RCM U2023 is set when a module receives invalid network data from another module with a faulted input." Suggestion: Reset codes, then hit your TCS button (cancel system) and see if code reappears on your drive.
(Thread Starter) | Not Ranked : 0 score S-A, Thanks for your thoughts and info. I am able to reset the codes with Autoenginuity, in fact the loss of traction light doesn't come on when I restart. But after a 5 - 10 miles its not coming back on. Faster than previously. Why doesnt the system tell me which module is giving the bad input/signal? Would the dealer just switch out the PCM or how is this issue addressed? |
| Not Ranked : 0 score I believe because all of the info is piggy backed across the network at the same time, the PCM dosent have the ability to self diagnos fapatalk
(Thread Starter) | Not Ranked : 0 score Yo my car is buggin out. Its throwing the CEL light now and I could feel a slight hesitation at highway speed for a maybe 20 seconds. I pulled the codes and its throwing a bunch codes. Some are old some are new. I mean what the hell am I supposed to do with this info? Am I supposed to assume the computer itself is malfunctioning? P0126 coolant temp too low when its reading 190 degrees? U2023 Fault received from external node (instrument cluster CAN and ABS CAN) U2064 Warning indicator received by another module B1261 Sun load sensor short circuit to ground?! wha? |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score Do you have a remote start or alarm installed? The interface modules tap into the medium speed and high speed can networks and can fuck shit up if its bad/miswired. Check your wires going into the ecu by the intake. Unplug and re-seat the connectors for the ecu. Disconnect the battery then wait a while for the system to drain power out and reconnect.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| Not Ranked : 0 score Start by checking ground connections and battery connections. fapatalk I would also chase that sun load sensor short...that could be throwing things off...short circuit bad! fapatalk
__________________ SyntheticAtmosphere '06 Speed6 Whitewater Pearl (COBB AP v2, CS s2 SRI/TIP, Autotech HPFP, Cp-e RMM&RDM, Fidanza/LuK, homebrew Testpipe&OCC) next...meth habit If it feels good, do it...Even if you shouldn't! Last edited by SyntheticAtmosphere; 04-08-2016 at 03:59 AM. Reason: MSF Database - Automerged Doublepost |
(Thread Starter) | Not Ranked : 0 score Nope, no alarm or remote start. My radar detector (worthless noisemaker) is wired in to overhead light 12v and a Parrot Bluetooth connected to stereo but not spliced in. Those have been there forever. I have had problems with wires going into the plug at the primary computer (PCM, or ECU) and have had to swap out a few. Protect your PCM the Wiring Harness from Corrosion That sun load sensor short sounds like bullshit because the CEL was coming on before and I wasn't getting that code. I'm gonna disconnect battery, check primary ground (which is right on top of body where the hood meets the body yes?). I do keep an eye on that connector and Deoxit intermittently as a result of my past issues. |
(Thread Starter) | Not Ranked : 0 score I do believe I figured out the cause of these random error codes. I of course suspected the harness near the computer because I've had issues with corrosion of terminals and plugs. This time I found the band clamp for the cold air intake had rubbed against 4 of the harness wires enough to expose the wires and was shorting them causing random error codes. I know I'm not the first person this has happened to. You can see the worn insulation and exposed wires here: In case you dont know where Im referring to, here is a different view: Check your harnesses guys. |
![]() Join Date: Jan 2018
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score What does the code mean U2023 |
| Anti-Lift, so why not anti-squat? | EvoFire | MazdaSpeed 3/6 - Suspension & Brakes | 12 | 08-22-2017 09:56 PM |
| Toyota class-action anti-lock brake lawsuit tossed out | Haltech | Automotive News | 0 | 01-11-2013 04:10 PM |
| just received my AP, need help. | titusdrake | MazdaSpeed 3/6 - ECU Computer Tuning | 8 | 11-11-2011 08:04 PM |
| 2009 MS3 brakes vs. 2010 MS3 brakes | Driver72 | 2010 MS3 - Suspension & Brakes | 11 | 11-21-2009 10:34 AM |
