 Old 09-16-2018, 10:55 AM   #1
herny316's Avatar
Posts: 3   (View Stats)
herny316 is an unknown quantity at this point
Default Any help identifying offical part # for spoilert clip
I've tried digging in a few online breakdowns and using google to search this site, but haven't quite nailed it yet.
I have a 2008 Speed 3 hatchback from the US. Our spoiler got knocked up somehow and one of the two side plastic clips that reside in the edges of the spoiler broke off in the hole on the hatchback door. I'd like to replace it on general principle and to eliminate more vibrations.
For our spoiler on the outer edge it is held down by two 10mm bolts on each side, then lower each side has a single plastic clip. The base is rectangular ~ 14x11x1mm with a circular Christmas tree that pokes up from it with a shock absorbing gasket.
Any help finding the proper part number or a suitable replacement would be much appreciated. Photo links here:
Apologies if this went into the wrong sub-forum. Still trying to learn my way around here.
-Thanks
Hah. Apparently I screwed up the image links. Here are direct URLs.
https://www.dropbox.com/s/peigic9oqd...34.23.jpg?dl=0
https://www.dropbox.com/s/maexcq5q28...32.38.jpg?dl=0
https://www.dropbox.com/s/l6y0bg147m...33.52.jpg?dl=0
Last edited by herny316; 09-16-2018 at 10:55 AM. Reason: MSF Database - Automerged Doublepost
herny316 is offline   Reply With Quote
part # for Radio pannel clip / tab darkmx-6 MazdaSpeed 3/6 - Car Audio & Electronics 2 10-10-2018 08:57 PM
need help identifying a part boatis 2010 MS3 - Suspension & Brakes 18 12-15-2014 06:06 PM
Help identifying this part - after JBR TMM install IMASA MazdaSpeed 3 - Engine, Transmission & Driveline 4 06-07-2013 03:45 PM
Quick question about identifying correct part. neptune03 MazdaSpeed 3/6 - Suspension & Brakes 0 10-15-2012 08:16 PM
Help Identifying H&R Springs. Part # weirdness... Tibu MazdaSpeed 3/6 - Suspension & Brakes 0 05-26-2011 05:53 AM
Page generated in 0.24293 seconds with 21 queries
