  • 1 Post By wankular
 Old 09-22-2011, 11:26 AM   #1
JohnMS3's Avatar
Posts: 754   (View Stats)
JohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the worldJohnMS3 is the leader of the world
Neutral  +1 score
Default Anyone know how to make this?
I've been trying to find a radiator cooling panel for the ms3...with my fmic on, my ect's have skyrocketed and I'm trying to find a way to keep it down. I want to utilize the emblem grill and direct air towards the radiator. I also want to use the exisiting air duct to flow air towards the sri.
Found this on another forum and the guy did a decent job with the panel that he made. I just need a recommendation on what material I could use that would be easily shaped to create a base template before I make the final piece in sheet aluminum.
-John
| Cobb AP | Cobb SRI/TIP | CXRacing/Godspeed FMIC | AQ Motorsports downpipe | Mazdaspeed CBE | Autotech HPFP internals | Koni Yellows | Eibach Prokit | Progress RSB | Mazdaspeed camber arms | CPE RMM | TWM shortshifter/bushings | Redlinegoods shifter/e-brake boots | Defi Red Racer boost gauge | RPM ventpod | OEM RX8 wheels | Yokohama S-drive 245/40/18 | Volt 4300K HID | Ho-en yellow fogs | Mazda5 rear rotors | Dual Fiamm horns |
JohnMS3 is offline   Reply With Quote
 Old 09-22-2011, 11:32 AM   #2
wankular's Avatar
Posts: 4,343   (View Stats)
In case anyone is wondering, the GT Spec panel for the regular 3's will not fit an MS3. GT Spec told me so.
2009 MS3 sport MGM
The Following 2 Users Say Thank You to wankular For This Useful Post:
JohnMS3 (09-22-2011), rfinkle2 (09-22-2011)
 Old 09-22-2011, 12:31 PM   #3
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
Neutral  -1 score
Tin snips, hammer, epoxy and an old piece of aluminum siding... or plastic stock or something to that effect.
Actually, you could probably make it out of wood and just paint it with polyurethane and then paint it. You can get a 4' x 8' piece of 1/8" paneling at Home Depot for like $10.
 Old 09-22-2011, 01:50 PM   #4
JohnMS3's Avatar
is there something i can use to mold its shape to reduce making a lot of measurements?
-John
 Old 09-22-2011, 02:39 PM   #5
wankular's Avatar
Do it like the dudes on American Chopper and make a template out of paper.
2009 MS3 sport MGM
The Following 3 Users Say Thank You to wankular For This Useful Post:
Easter Bunny (09-28-2011), JohnMS3 (09-22-2011), spoolin00 (09-25-2011)
 Old 09-22-2011, 02:45 PM   #6
Mizzle's Avatar
Groans: 324
Cardboard, but yes - what he said.
 Old 09-22-2011, 03:14 PM   #7
MoparGo
Lurkers
MoparGo's Avatar
Posts: n/a
Arrow +1 on the...
...cardboard to design the pattern...
...& aluminum for panel/ductwork...
The Following User Says Thank You to For This Useful Post:
 Old 09-22-2011, 03:16 PM   #8
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
add water, less coolant...also u might add an oil cooler which will take away the heat it transfers to the oem oil cooler and your ect will drop as a result.
skool s out
JohnMS3 (09-22-2011), jroc (09-27-2011)
 Old 09-22-2011, 04:30 PM   #9
redmnsterut's Avatar
Posts: 838   (View Stats)
redmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the worldredmnsterut is the leader of the world
+1 on cardboard, get a long piece and make a ruff cut out, then put it where you'd like it to go, find our mounting points and then cut out of sheet metal, aluminum. Once done, paint it and install.
SURE RMM | SURE Shift Weight | SURE SSP | CP-E CAI | CP-E DP | CP-E TIP | COBB AP |SnailD Tunned| TEIN Springs | SU Turbosmart BPV | Autotech HPFP Internals | Autolite XP step colder plugs | JBR Heavy Shift Knob | CXracing FMIC | Block8 Single Gauge Pod | MSD DashHawk
Waiting to be installed: SURE Dreadnaught | JBR Shifter Bushings | SU Boost Tubes | P&P Intake Manifold
Soon to come:SURE Intake/TB TIG | SURE Juggernaught | RSB |
286awhp / 346lbs tq @4500 ft ASL
redmnsterut is offline   Reply With Quote
 Old 09-22-2011, 04:42 PM   #10
wankular's Avatar
Step 2. Make me one.
2009 MS3 sport MGM
The Following User Says Thank You to wankular For This Useful Post:
 Old 09-22-2011, 04:44 PM   #11
I might be going to my buddies shop this weekend to do my rmm and a couple other things. If I get some time Ill will try to get a cardboard cut out design... But it will be for the MS6
 Old 09-25-2011, 05:19 PM   #12
JohnMS3's Avatar
did some measurements and came up with this...dont have the ducting set up yet.
-John
The Following 2 Users Say Thank You to JohnMS3 For This Useful Post:
AZSPEED3 (09-25-2011), PunjabiPlaya (09-25-2011)
 Old 09-25-2011, 07:18 PM   #13
uncorked11's Avatar
Posts: 1,238   (View Stats)
Groans: 165
Fiberglass? Simple amd cost effective.
 Old 09-25-2011, 07:28 PM   #14
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
skool s out
m
 Old 09-26-2011, 11:42 PM   #15
Mizzle's Avatar
Groans: 324
Fiberglass is a pain to work with compared to cutting out tin and riveting/gluing or using plastic paneling (like they use at BestBuy for head unit installs when there's no kit out there.)
 Old 09-27-2011, 02:34 PM   #16
JohnMS3's Avatar
here's the final template (including all mounting points) before tracing/cutting in sheet aluminum...
i'm contemplating if i should remove the ducting and just cover that area as well since i dont think there will be a difference in underhood temps...in fact i dont think there will be a big difference in coolant temps with the panel on. but i'll still finish it since i already started it.
-John
NCZ13 (09-27-2011), wankular (09-27-2011)
 Old 09-28-2011, 12:09 PM   #17
Mizzle's Avatar
Groans: 324
*shrugs* if it didn't make a difference, Mazda wouldn't spend any money on it.
 Old 09-28-2011, 12:20 PM   #18
Two nuns and a pack mule
AtTheDriveIn's Avatar
Posts: 1,527   (View Stats)
AtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the worldAtTheDriveIn is the leader of the world
Have you done the coolant bypass mod? It helps quite a bit.
AtTheDriveIn is offline   Reply With Quote
 Old 09-28-2011, 06:24 PM   #19
JohnMS3's Avatar
decided to remove the ducting on the driver's side...the opening to the engine bay is still there so air will still pass through. i will also make some vertical panels to direct the air downward as it enters the grill. the template for the top panel is done, found 3'x3'x3/16" aluminum sheets for 20 bucks online...just need to find someone with a jigsaw.
-John
 Old 09-28-2011, 09:12 PM   #20
JohnMS3's Avatar
Just saw some jigsaws on harbor freight for 20-25 bucks...any reviews on chicago electric tools?
-John
 Old 09-30-2011, 11:54 AM   #21
Mizzle's Avatar
Groans: 324
99.9% of them are shit.
The power tools are worth the price. I have a cutting wheel that performs flawlessly from Chicago Tools. It's all made-in-China shit, so don't expect diamonds. All hand tools have lifetime warranties from the store, though, so they replace it if it ever breaks. You don't even need a receipt half the time - you just walk in, set yours on the counter, grab one on the shelf, show them and leave.
*edit*
As far as using a jigsaw on this project, you'd be much better off buying a cutting wheel and cutting it out. A jigsaw has a tendency to pull/push the material and you risk jagged edges and bending the material. If you use a cutting wheel, you just trace the line and hand sand the sharp edge off and you're done.
 Old 09-30-2011, 12:06 PM   #22
MSP611's Avatar
Posts: 2,291   (View Stats)
cutting wheel.. or a dremel... i love angle grinders i use them for a lot of shit... harbor freight ones arent bad either..
In progress:
 Old 10-01-2011, 09:34 AM   #23
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
7 Gauge is a little thick IMO, could have got away with like 28 gauge and just used some snips to cut out your template.
 Old 10-06-2011, 10:10 PM   #24
tastysi2004's Avatar
Posts: 1,063   (View Stats)
what is it???
 Old 10-07-2011, 05:05 PM   #25
Etipp98's Avatar
You bypass the coolant that circulates through the throttle body.
Did I make a BooBoo? acidbbg MazdaSpeed 3/6 - Wheels & Tires 17 12-07-2009 06:04 PM
can someone make me a map? NJSPEED3 MazdaSpeed 3/6 - ECU Computer Tuning 33 11-26-2009 09:28 PM
Marketing 101: Make stuff up, make it visible - BMW's subtle 1-Series shilling Haltech Automotive News 0 04-13-2008 08:51 AM
Page generated in 0.44641 seconds with 30 queries
