(Thread Starter) | Not Ranked : 0 score Basically I have like 5 Defi gauges, a Innovate MTX-1 WB o2, and a generic digital water temp sensor for my l/a intercooler system and its just getting kinda rediculous. I am wondering if I can sell all or most of those gauges and pick up this one, it has a MAP input, 2x temp, 1x pressure, and WB a/f Anyone use one of these?
Groans: 793
| Not Ranked : 0 score So does it monitor 10 parameters or does it monitor 9 parameters? At any rate, 450 bucks it too much.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals Last edited by Tokay444; 05-02-2012 at 04:59 AM. Reason: MSF Database - Automerged Doublepost |
| Not Ranked : 0 score looks like its on sale for 179 so i guess the params that dont require extra sensors get them from OBD2?
![]() Join Date: Feb 2012 Location: Quantico, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,434
| Not Ranked : 0 score Sensor Displays •Boost/Vacuum (psi or kPa x 100) •Water Temperature •Engine Speed (rpm) •Vehicle Speed (mph) •Throttle Position (%) •Injector Duty Cycle (%) •O2 Sensor A/F Signal (V) •Secondary Temperature (Water or Oil) *Requires optional sensor •Oil Pressure *Requires optional sensor Ohh...and the site is garbage.
__________________ [SIGPIC][/SIGPIC] 2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_Nameless Race Pipe_RBF600_Ferodo DS2500_PTUNING Tuned Less parking more racing Last edited by leon78; 05-02-2012 at 05:54 AM. |
(Thread Starter) | Not Ranked : 0 score Yeah it can pull info from the obd2 port and you can add a wb o2 or take it from the ecu and you can add two temp sensors, map sensor, and a pressure sensor. From the reviews I have seen online it looks legit and it looks like you can read it during the day. I already have two wb o2 sensors so thats covered, ide just need a pressure sensor for oil pressure and a temp sensor for the oil and a temp sensor for the l/a system.
![]() Join Date: Apr 2012
Rep Power: 0 ![]() Thanks: 0
| Not Ranked : 0 score Dsport July 2008 (issue 67a)has a full review of it.... |
| The Following User Says Thank You to 6oostfreek For This Useful Post: | 06Speed6 (05-03-2012) |
(Thread Starter) | Not Ranked : 0 score Yeah I saw the review but those magazine reviews can be really biased, I was hoping for a non promotional review
| Not Ranked : 0 score +1...deff interested in this.
__________________ [SIGPIC][/SIGPIC] 2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_Nameless Race Pipe_RBF600_Ferodo DS2500_PTUNING Tuned Less parking more racing |
| Customer Collaboration Designs Excellence | CorkSport | CorkSport | 0 | 09-02-2011 12:10 PM |
| GM designs windshield to see what the eye might miss | Haltech | Automotive News | 0 | 03-17-2010 10:40 AM |
| Why Different Designs In Pumps? | mrlilguy157 | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 18 | 09-09-2009 03:58 PM |
| BMW DesignWorksUSA designs ultimate gaming rig | Haltech | Automotive News | 0 | 03-15-2009 07:40 AM |
