![]() Join Date: Jan 2011
Rep Power: 0 ![]() Thanks: 0
| COCKSTRONG ![]() ![]() ![]() Join Date: Jul 2011 Location: Your Mom's House
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,809
Groans: 890
| Not Ranked : 0 score simply. Yes. You also need upgraded pump internals to run that tune safely.
__________________ Searching for something? Try MS3Shadow's Custom Search EVERY "I DON'T USE MSF" FACEBOOK RETARD EVER |
| The Following User Says Thank You to SofaKingAwesome For This Useful Post: | TexasSpeed3 (03-30-2012) |
(Thread Starter) | Not Ranked : 0 score I heard that the fuel pump was only necessary with the gen2s. I know it is recommended and I will install within a month but will it be ok if I run this tune without the upgraded internals for a month or two? |
| The Following User Says NO Thank You to psmith22 For This Un-useful Post: | TexasSpeed3 (03-30-2012) |
Groans: 890
| Not Ranked : 0 score mAYBE. mAYBE NOT. DAMN, IM STILL IN CAPS LOCK THURSDAY RAGE MODE.
| The Following 4 Users Say Thank You to SofaKingAwesome For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Okay thanks for your help |
![]() Join Date: Jul 2010 Location: Maryland
Rep Power: 188 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 49
I would just drive like a granny till you get the upgrade just in case (lay off high boost/WOT).
__________________ 09 TR MS3 Cp-e Nano SRI | Cp-e TIP | Cp-e RMM 75d | Cobb catted 3" DP | Cobb AP - Jorge Carrillo protune NGK Iridium IX 6510 plus | PTP HPFP upgrade (internals) TrMotorsprt MT1 18x8.5 +48 | Dunlop Direzza Sport Z1 Star Spec 235/40/18 | Mutegi Black Lug nuts Hawk HPS Pads | Ate Super Blue | Techna-Fit SS lines Hella Supertones | JBR Heavy Shift Knob | |
| The Following User Says Thank You to Biggs For This Useful Post: | SofaKingAwesome (03-29-2012) |
(Thread Starter) | Not Ranked : 0 score Alright I'll try my best not to push it too hard. Hopefully I get this upgrade soon so I can have some fun with the new map and downpipe Also I'm still running the old COBB maps where it doesn't require the fuel pump in the map I will be installing but I have notice that it does in the new maps. I'm not sure if that makes a difference or not but I figured I would just let you guys know. Last edited by psmith22; 03-29-2012 at 12:56 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Feb 2009 Location: Flanders, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 224
| Not Ranked : 0 score It does make a difference. In the new stage 2 maps the ECU is expecting a fuel pump that can handle higher pressures than stock, so I wouldn't flash to stage 2 until you have the new internals installed but thats just me.
__________________ 2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40// |
(Thread Starter) | Not Ranked : 0 score Its about 430 at idle and when I get on it its about 1750. is that alright? |
Groans: 890
| Not Ranked : 0 score Yeah keep an eye on it and get the internals before the stock ones fail.
(Thread Starter) | Not Ranked : 0 score Alright. What psi does it need to reach for me to start being concerned? |
![]() Join Date: Mar 2012 Location: Portland, Oregon
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 83
| Not Ranked : 0 score also, when you upgrade the internals you will notice your AFR holds so much better at high RPMS. when i upgraded mine and had done a DYNO before and after the numbers were crazy better! but the AP didnt really show that it was bad FP internals, they just made a huge difference. |
| I can haz fast? ![]() Join Date: Nov 2010 Location: Indianapolis IN
Rep Power: 218 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 437
| Not Ranked : 0 score Anything below 1600 psi at WOT and I would start to get concerned.
__________________ 2012 Mazdaspeed 3 CWP - Cobb AP Stage 2+ OTS/Cobb SRI+TIP/Autotech HPFP Internals/JBR 80 duro RMM/JBR SSP/JBR Sway Bar/UR Race Pipe and Catback Exhaust//Corksport TMIC/Denso ITV22/15% Window Tint/Super Race Weighted Neo Chrome Shift Knob/Morimoto 5K HIDs/Cobb BPV XLE/Corksport Lowering Springs. 18 x 8 MB Battles wrapped in 235/40/18 Nitto NT 555 Extreme Performance Tires. 2008 Mazdaspeed 3 SSM - Sold Mods: Cobb AP Stage 2 Base Map by Phate/Forge BPV(Blue 2 Shims)/JBR RMM/Stealth Black Cobb SRI/JBR SSP & Heavy Shift Knob/15% Window Tint/DDM 6k HIDs in Lows and Fogs/Hardwired Escort 9500i/Autotech Fuel Pump Internals/CNT Catless DP/CNT Catback Exhaust |
| downpipe ?? *help* | viper1b2 | MazdaSpeed 3/6 - Turbo Induction | 3 | 01-30-2011 11:44 AM |
| downpipe | brokeven | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 01-30-2011 11:14 AM |
| ATP Downpipe | 2010ms3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 01-17-2010 07:59 PM |
