![]() Join Date: Sep 2017 Location: East coast
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Hi so I am wondering how much hp gain I will get by adding a J2 engineering down pipe and what are the best axles if I start putting hp into the car for the rear? Also will getting a new intake manifold help at all on HP? |
| Not Ranked : 0 score What the fuck
| The Following 2 Users Say Thank You to btstarcher For This Useful Post: | KiwiFlavor (09-14-2017), monkey.bones.007 (09-14-2017) |
![]() Join Date: Nov 2010 Location: Edmonton, Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17
Groaned at 6 Times in 4 Posts
| Not Ranked : 0 score |
| The Following User Says Thank You to Ewind For This Useful Post: | btstarcher (09-14-2017) |
(Thread Starter) | Not Ranked : 0 score I thought i was pretty clear with my questions. Clearly I wasn't. Maybe I missed something or don't know all I need to. |
Groans: 211
| Not Ranked : 0 score You're missing a lot. Like a few sandwiches short of a picnic.
| The Following User Says Thank You to Thor Hammer For This Useful Post: | monkey.bones.007 (09-15-2017) |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Not Ranked : 0 score This is the best Axel/axl
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
| The Following 2 Users Say Thank You to KiwiFlavor For This Useful Post: | monkey.bones.007 (09-14-2017), Thor Hammer (09-15-2017) |
![]() Join Date: May 2013 Location: CO
Rep Power: 2407 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,487
| The Following 2 Users Say Thank You to monkey.bones.007 For This Useful Post: | KiwiFlavor (09-15-2017), Thor Hammer (09-15-2017) |
| The Following User Says Thank You to Fstrnyou For This Useful Post: | monkey.bones.007 (09-14-2017) |
| HELP! Trouble with front axel shaft | JustTheTip | MazdaSpeed 6 - Engine, Transmission & Driveline | 4 | 02-10-2014 03:28 PM |
| cv axel problems? | treyclash | 2010 MS3 - Engine, Transmission & Driveline | 5 | 08-04-2010 06:51 AM |
