Like Tree5Likes
 Old 06-19-2012, 04:29 PM   #41
bertrand_CX_7's Avatar
Posts: 1,455   (View Stats)
bertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the worldbertrand_CX_7 is the leader of the world
Where to get the spacer?
Originally Posted by Design View Post
5 mm spacers on the tie-down bolts for mine.
2010 MazdaSpeed3 Velocity Red: Forge BPV V2, CP-e [HPFP, TMIC, Driver + passenger Mount, 75-A], CorkSport [RSB, Coilover, camber plate], SPC rear camber arm, JBR SSP stg2 + heavy knob, Cobb [ SRI, AP ], HTP 3.5" TIP, - STG2 PERM tuned by DJ, Ultimate Racing TBE (Metal core DP). Aeroforce dual guages, Hankook R-S3 on stock wheels, Sparco Evo2 race seat. ARP long wheel studs -- 17x9 ET 45+ Kosei K1 TS on 255/40/17 on Dunlop Direzza ZII.
Pending install: JB EGR block plate
Next mod:CorkSport[ Front + Rear swaybar endlinks ], OCC, brake upgrade (CorkSport or BBK), 6 point Harness.
2007 CX-7 GT AWD: CPE CAI, ETS 3" TMIC, JB EGR block plate ,Matt's OCC, AutoExec Strut tower bar, AutoExec lower arm bar, Nittos 420 tires, 12" JBL subwoofer with Bose system.
bertrand_CX_7 is offline   Reply With Quote
 Old 06-19-2012, 05:30 PM   #42
Design's Avatar
Posts: 1,887   (View Stats)
Groaned at 9 Times in 5 Posts
Pair of washers should do the trick. I had some spares laying around. Prevents the brace from arcing along the sides of the battery.
09 CWP MS3 GT
Ownership & Build Thread
The Following User Says Thank You to Design For This Useful Post:
bertrand_CX_7 (06-19-2012)
 Old 11-09-2012, 10:56 AM   #43
MadOzodi's Avatar
Posts: 686   (View Stats)
Thread revival.
After five years and ten months, it's finally time to replace the original battery in my GEN1. I'm amazed that it's lasted this long. Looks like I'll be going with a Duralast Gold.
07 COSMIC BLUE MS3 GT
MadOzodi is offline   Reply With Quote
 Old 11-09-2012, 09:15 PM   #44
Ups wrong post ........
 Old 12-26-2013, 08:31 PM   #45
Notorious AMA's Avatar
Posts: 116   (View Stats)
Notorious AMA has a brilliant futureNotorious AMA has a brilliant futureNotorious AMA has a brilliant futureNotorious AMA has a brilliant futureNotorious AMA has a brilliant futureNotorious AMA has a brilliant futureNotorious AMA has a brilliant futureNotorious AMA has a brilliant futureNotorious AMA has a brilliant futureNotorious AMA has a brilliant futureNotorious AMA has a brilliant future
If you have a Costco membership you are wasting your money getting anything other than the Kirkland brand. 3 year direct replacement + 3 year prorated + 800 CCA. All under 70 bucks.
There are only a few manufacturers out there that build automotive batteries. The Costco battery cells are built through Johnson Controls - the same supplier for Toyota, Sears DieHard, Optima, Everstart, and many others.
If you don't have a Costco membership, get an Everstart Maxx for a hundred bucks and call it a day. CCA is roughly 550-600 which is better than OEM, IIRC. 3 year direct replacement + 2 year prorated warranty.
I work at Costco & I don't get a battery anywhere else. It's almost like never paying for a new battery again just return it if you have any issues & get another one.
Injen CAI
Notorious AMA is offline   Reply With Quote
The Following 2 Users Say Thank You to Notorious AMA For This Useful Post:
memin (12-26-2013), Playaj (12-26-2013)
 Old 12-26-2013, 09:41 PM   #46
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Even tho you necroed an over year old thread, I'm gonna give it a like cuz I agree about Costco batteries
Sent from my KFAPWI using Tapatalk HD
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 03-12-2015, 08:38 AM   #47
ssspencerjr's Avatar
Posts: 11   (View Stats)
ssspencerjr is an unknown quantity at this point
New poster here, just found this post.
My OEM battery died 2 years after I bought the car new. I then purchased an OEM Mazda battery from my dealership with a 3 yr warranty, it's already showing signs of failing.
So are the red top batteries good to go for 1st Gen MS3? Should I look for an alternative?
ssspencerjr is offline   Reply With Quote
 Old 03-12-2015, 08:40 AM   #48
Holy old thread resurrection!
Optima sucks. I burned through a bunch of them. Have a Auto Zone Duralast Gold and it has been solid for at least 3 years no problem.
 Old 03-12-2015, 08:42 AM   #49
Thanks for the tip. I'll have to check them out. Do you know the part number so I can have them check for stock/pricing?
I know there's a big Interstate Battery center near me but I don't know if their batteries are any good.
 Old 03-12-2015, 08:59 AM   #50
No idea, but Interstate is really good too.
 Old 03-12-2015, 11:25 AM   #51
MadOzodi's Avatar
Damnit, turned the color of poo again...
Had my Duralast Gold replaced under warranted recently...for whatever reason, they got rid of the different colored top covers.
 Old 03-12-2015, 11:50 PM   #52
Sinister_Speed3's Avatar
Posts: 180   (View Stats)
Sinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond reputeSinister_Speed3 has a reputation beyond repute
I just went through this and my stock battery finally died on my 2009. I went with costco because of price and no pepboys warranty BS (pay $15-20 to install or else warranty is not valid). Did the swap in costco parking lot and it only cost ~$75 with core exchange, I believe it was #3 battery. Car starts without hesitation.
nick
Sinister_Speed3 is offline   Reply With Quote
 Old 03-13-2015, 03:25 AM   #53
mach69's Avatar
Posts: 79   (View Stats)
mach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond reputemach69 has a reputation beyond repute
Agreed with the crappy Optimas. I've had a durlast gold since 2011. Not one problem or signs of failure.
The battery type is: 35-DLG
Well worth the money you pay for it. 10 year prorated warranty i believe.
2008 Mazdaspeed 3 - True Red
Engine: CPE Nano, CPE TIP, CPE TMIC, CPE HPFP, CS BeCuse Injector Seals, SU Boost Tubes, Forge BPV V1, ITV-22, AQ Motorsports DP, Dashhawk, Spin-on Oil filter conversion, Saikou Michi OCC, Cobb AP Self-tuned, VTCS Delete, EGR Delete, TB Coolant Bypass, DFDD VVT, 3 bar map
Drivetrain: Southbend Clutch Stage 3 DD, JBR Short Shift Plate, SU Shifter Bushings, CPE Stage 2 RMM, CPE TMM
Suspension: Koni Yellows, Eibach Springs, Cobb RSB, MOOG Swaybar Endlinks, Energy Suspension FSB Bushings
mach69 is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/battery-replacement-86484/
Which battery to replace with? This thread Refback 11-26-2013 03:38 PM
Oil Pan Replacement MrBojangles MazdaSpeed 3 - Engine, Transmission & Driveline 16 06-14-2016 01:23 PM
Serpentine Belt Replacement, GM Replacement Parts For Older Cars, Fixing A Radiator Fan, Rebuilt Brake Calipers: Mike Al Haltech Automotive News 0 03-27-2009 02:30 PM
Toyota lowers the price of Prius battery replacement Haltech Automotive News 0 09-25-2008 01:30 PM
Nokia Compatible Replacement Lithium Ion Cell Phone Battery $5.99 Free Shipping at Meritline Haltech Hot Deals Section 0 04-11-2008 04:31 PM
Page generated in 0.33254 seconds with 29 queries
