  • 1 Post By reconbygod12
 Old 05-28-2011, 09:18 PM   #1
reconbygod12's Avatar
Posts: 112   (View Stats)
reconbygod12 is a splendid one to beholdreconbygod12 is a splendid one to beholdreconbygod12 is a splendid one to beholdreconbygod12 is a splendid one to beholdreconbygod12 is a splendid one to beholdreconbygod12 is a splendid one to beholdreconbygod12 is a splendid one to behold
Groaned at 33 Times in 13 Posts
Default best boost control source to use
1. manual boost controller
2.electronic boost controller
3.grimmspeed boost solenoid
i've looked all over the forums, but everywhere i look i am just finding mixed reviews about everything..so pretty much i am asking what would be the best way to control boost now for me...i am running the halloman mbc, but i am ntoa fan of it
MIDORI likes this.
reconbygod12 is offline   Reply With Quote
 Old 05-28-2011, 09:34 PM   #2
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
make sure you donate!! but this is the best solution
just use the Cobb Ap to control your boost. it's got that capability and more!
RichTuned
BlueDmnSpeed is offline   Reply With Quote
The Following 2 Users Say Thank You to BlueDmnSpeed For This Useful Post:
manelscout4life (05-29-2011), Raider (06-07-2011)
 Old 05-28-2011, 09:41 PM   #3
well when the people i went to put on my bigger turbo for me while i was in the field, they took my boost solenoid off and put the mbc on
id donate but usually when i ask something i get stupid replys 95% of the time
Last edited by reconbygod12; 05-28-2011 at 09:41 PM. Reason: MSF Database - Automerged Doublepost
The Following User Says NO Thank You to reconbygod12 For This Un-useful Post:
 Old 05-28-2011, 09:44 PM   #4
SSinstaller's Avatar
Posts: 3,989   (View Stats)
Groans: 60
A good tuner could make any one of those three control your boost just fine..
If you've got an AP get the grimmspeed or a perrin EBCS and let the AP/ECM do the work...
 Old 05-28-2011, 10:24 PM   #5
with the grimmspeed can i keep my pro tune that was made prior to it? even though i used a mbc with the pro tune that i have now
 Old 05-28-2011, 11:19 PM   #6
Whiteboy's Avatar
Posts: 2,032   (View Stats)
Whiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the worldWhiteboy is the leader of the world
Groans: 142
Neutral  :  -1 score
You get stupid replys because you haven't donated.
Why should we, the contributing members of this forum, help out someone who hasn't contributed to this forum?
In case you haven't figured it out yet, this forum is supported by its members not vendors or advertisments. Did you think a forum of this magnitude is free to run???
We will give a fuck about you once you become a contributing member of OUR forum!
Cheers!
~My Mod List: ETS TMIC; CP-E SRI; COBB TIP; CP-E DP; CP-E RMM; CP-E Safe Seals; ITV-22's; GHL SS CBE; TWM STS w/bushings; Autotech HPFP Internals; AP (Stratified by Lex); Matt Damond OCC; CP-E Triple Gauge Pod w/ Prosport Premium Boost, AFR, and Oil Pressure Gauges; JBR Eliminator Shift Knob~
Whiteboy is offline   Reply With Quote
The Following 4 Users Say Thank You to Whiteboy For This Useful Post:
-cj- (05-28-2011), manelscout4life (05-29-2011), rob ms6gt (06-06-2011), Z3roFlaw (06-06-2011)
 Old 05-29-2011, 01:46 AM   #7
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
Neutral  :  -1 score
i run a 3071 , ap, and hallman pro mbc.... i can make boost do w/e the fuck i want it to do....
but seriously u need to donate jew
 Old 06-05-2011, 10:36 PM   #8
2010Speed3's Avatar
Posts: 607   (View Stats)
2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world2010Speed3 is the leader of the world
I'm having issues controlling boost and believe I have a damaged OEM boost control solenoid. Does the Grimmspeed EBCS fit the genpu's?
SOLD on 08/2013
2010 Black Mica MazdaSpeed3
Performance: BNR S3 - Sure Full 3" Aeros - Bosch 3 Bar Map - DDM HID Kit 6k 35w - Hella Super Tones - CorkSport LED Light Kit - Cobb Knob (Red) - VG Sharkfin Antenna - Sure Anchors - Jbarone 88duro Dog Bone RMM - Black CorkSport SRI/TIP (Powder Coated Black) - Ultimate Racing Race Pipe & CBE - KMD Internals - CorkSport Cold Air Box w/ Carbon Fiber Top - Turbosmart SU Blacked Out BPV - Cobb AccessPort Stage 2 (Nataphen Tuned) - JBarone RSB - CP-E TMIC
2010Speed3 is offline   Reply With Quote
 Old 06-06-2011, 04:55 PM   #9
the genpu has the same port to plug in...if that doesnt fit there is a perrin taht is offered and considered universal
The Following User Says Thank You to reconbygod12 For This Useful Post:
2010Speed3 (06-07-2011)
 Old 06-06-2011, 05:11 PM   #10
If you wanted to, you could use the grimmspeed in 2 port mode, and yes, it is a direct fit (as easy as 3 vacuum lines and a plug).
The directions for the grimmspeed on on their site, in pdf form, for both 2 and 3 port mode hook-ups.
If you decide to use the grimmspeed in 3 port mode, it will need to be tuned for.
 Old 06-06-2011, 05:20 PM   #11
rob ms6gt's Avatar
Posts: 416   (View Stats)
Way to threadjack the non-believer
rob ms6gt is offline   Reply With Quote
 Old 06-07-2011, 06:31 PM   #12
2010Speed3's Avatar
Lol sorry? I didn't really mean to, but I'm not sure if you're happy or not. I didn't feel like this thread was going anywhere anyway... haha
Thank you for affirming that. I'm considering this because of Nataphen's suggestion. He said he would be able to tune it through ATR.
Wonderful, thanks for the confirmation.
SOLD on 08/2013
 Old 06-07-2011, 06:45 PM   #13
xhymer's Avatar
Posts: 346   (View Stats)
xhymer is the leader of the worldxhymer is the leader of the worldxhymer is the leader of the worldxhymer is the leader of the worldxhymer is the leader of the worldxhymer is the leader of the worldxhymer is the leader of the worldxhymer is the leader of the worldxhymer is the leader of the worldxhymer is the leader of the worldxhymer is the leader of the world
Groans: 84
My car didn't like the Grimmspeed EBCS.
I switched to a Turbosmart MBC... car performs much better. Just my personal experience.
I'd prolly keep the manual, man. Less margin for error imo.
2007, Bolted, 3076, Pu powered, Hiroshimian Ford with an e25 !!TUNE OF PHATE!!
"Yeah *smiles*... Yeah, this motherfckr pulls!" - Clint Griest
xhymer is offline   Reply With Quote
 Old 06-08-2011, 07:25 AM   #14
nattun's Avatar
Posts: 260   (View Stats)
nattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond reputenattun has a reputation beyond repute
Groaned at 3 Times in 1 Post
Turbosmart dual stage MBC FTW!! I really liked mine. The boost is rock solid with no spikes and def holds better/longer.
...and its for sale here: http://www.mazdaspeedforum.org/forum/foru...age-mbc-82769/
2006 Mazdaspeed 6 - Velocity Red Mica - #5129 - Totaled
2006 Mazdaspeed 6 GT - Titanium Gray Metallic - #3820
nattun is offline   Reply With Quote
 Old 09-04-2018, 10:24 AM   #15
sarm1084's Avatar
Posts: 11   (View Stats)
sarm1084 is on a distinguished road
Groaned at 5 Times in 2 Posts
Cheers!
Well your marketing skills are great. I'm sure he ran home and smashed his piggy bank after your heated rant.
Sent from my VS835 using Tapatalk
Future
Gen1 Owner,... Hopefully! lol
sarm1084 is offline   Reply With Quote
The Following 2 Users Say NO Thank You to sarm1084 For This Un-useful Post:
Db09ms3 (09-04-2018), KiwiFlavor (09-04-2018)
 Old 09-04-2018, 10:57 AM   #16
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
Way to resurrect a damn 7 year old thread bro. Apparently your forums skills are great.
2012 NASA Spaceship Gray MS3
Db09ms3 (09-04-2018), MSMS3 (09-09-2018)
 Old 09-04-2018, 02:11 PM   #17
lazza151's Avatar
Posts: 50   (View Stats)
lazza151 has a spectacular aura aboutlazza151 has a spectacular aura about
2010 Gen 2 Velocity Red
- Freektuned
- AP V3
- HPFP
- Cobb RMM
- Damond PMM
- Turbo Back Custom SS Race Pipe
- K&N Drop in Air Filter
- Bov
- Raiden by Lenso Forge Type Monoblock 18 x 8 ET/ 35 Wheels
- Falken Azenis FK510 235/40 Tyres
- Webasto Sunroof.
lazza151 is offline   Reply With Quote
BT boost control zx2man MazdaSpeed 3/6 - Big Turbo Builds 16 11-16-2010 09:14 PM
Possible to control boost with... demonspeed MazdaSpeed 3/6 - Turbo Induction 6 02-04-2010 12:09 AM
Wastegate control, Boost spikes, PID control FreeFlyFreak
Cobb ATR Support
83 11-05-2009 12:40 PM
sb boost control problem speed_3 MazdaSpeed 3/6 - ECU Computer Tuning 20 07-01-2009 04:53 PM
AP + Map clamp + Boost control ccann26 MazdaSpeed 3/6 - ECU Computer Tuning 19 08-15-2008 08:11 PM
Page generated in 0.38297 seconds with 32 queries
