 Old 07-20-2018, 01:46 PM   #1
nebolskeetskeet's Avatar
Posts: 45   (View Stats)
nebolskeetskeet is a glorious beacon of lightnebolskeetskeet is a glorious beacon of lightnebolskeetskeet is a glorious beacon of lightnebolskeetskeet is a glorious beacon of lightnebolskeetskeet is a glorious beacon of lightnebolskeetskeet is a glorious beacon of light
Default BNR S3 with Cobb EBCS
So, I have been trying to diagnose some issues, but have come across something that doesn't seem to be right.
My MS6 has a BNR S3 turbo and a 3-port Cobb EBCS, and I have a question about how the EBCS is installed. Currently the turbo has a line connected to the port on the compressor side, and is plumbed to the lower port on the wastegate (similar to the image below).
On Cobb's EBCS Mazdaspeed installation page, they state to cap both ports (shown below).
I have a rich at idle issue right now, but my radiator recently developed a leak. I am waiting for my new radiator to come in, but am trying to diagnose as much as possible while the car is torn apart.
It seems obvious to me to fix it, but I just want to make sure everyone agrees.
Link to Cobb's instructions: https://cobbtuning.atlassian.net/wik...ntrol+Solenoid
2006 Black Mica MS6 - COBB AP V2, OTS 93 Stage 3 Tune, BNR S3, Relentless IM, CX Racing FMIC, AEM CAI, Cobb EBCS, Autotech HPFP Internals, Magnaflow Cat-Back, ATP Catted DP
(GONE) - 2008 Black Mica MS3
nebolskeetskeet is offline   Reply With Quote
 Old 07-20-2018, 06:29 PM   #2
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Pics aren't showing up for me...
There are only a couple ways to route it for it to work properly and many ways that won't work properly.
Search google for 3-port EBCS hose routing and see if yours looks like one of them.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 07-20-2018, 07:41 PM   #3
That’s weird. The images I added are in the link to Cobb’s site in my original post.
I basically added the first two images underneath “Cobb EBCS Installation” in the provided link.
 Old 07-20-2018, 10:03 PM   #4
Solarsurge's Avatar
Posts: 577   (View Stats)
Proper 3-port routing should be:
Turbo Inlet Pipe > EBCS Port 1 (right port)
Compressor Port > EBCS Port 3 (middle port)
Wastegate Port > EBCS Port 2 (left port)
Intake Manifold > BPV Port (factory routing)
Also worth mentioning that you want to keep the SHORTEST route possible for all hoses. Don't mount your EBCS halfway across your engine bay and run 3 foot hoses. I'd say try to keep your hoses less than 1 foot if possible.
Last edited by Solarsurge; 07-20-2018 at 10:11 PM. Reason: Moved Port 3 to middle to eliminate confusion
 Old 07-21-2018, 06:48 AM   #5
Solarsurge's Avatar
Am I being punked? Do I need to diagram this for you? Here...
TIP =====hose===== EBCS 1
COMP =====hose===== EBCS 3
WG =====hose===== EBCS 2
IM =====hose===== BPV
The Following User Says Thank You to Solarsurge For This Useful Post:
nebolskeetskeet (07-21-2018)
 Old 07-21-2018, 07:59 AM   #6
I get your routing.. but my question still stands about the second port on the wastegate. There are 2 ports on the wastegate, 1 that goes to the boost controller, and the other that used to be plumbed to the compressor port. Your routing doesn’t mention what to do with the second port on the wastegate.
I appreciate your help and I do understand what you are saying lol. So thanks you guys for your time. I am just trying to make sure everything is installed correctly.
 Old 07-20-2018, 10:28 PM   #7
Fstrnyou's Avatar
Avoid mounting it to the firewall unless you want to hear it clicking.
Other rides:
History:
 Old 07-20-2018, 10:29 PM   #8
Solarsurge's Avatar
Maybe I want to know it’s working
 Old 07-20-2018, 11:14 PM   #9
So you guys agree that the compressor port and bottom port of the waste gate should be capped?
I went ahead and capped them and now I have a tee running off of the bpv to port 3, port 1 to tip, and port 2 to wastegate.
 Old 07-20-2018, 11:39 PM   #10
Solarsurge's Avatar
Did you read what I wrote at all? lol
NO. You don’t cap them. You run 1/8” ID hoses in the manner I indicated. Stock EBCS only has two ports. That routing is to replace the stock EBCS on a 2 port stock setup. Your turbo is meant to be run in 3 port mode.
 Old 07-21-2018, 06:41 AM   #11
I did read your post. You never mentioned what to do with the second port on the wastegate. As fstrnyou stated, I corrected the routing to be consistent with cobb’s instruction.
 Old 07-21-2018, 05:03 AM   #12
Fstrnyou's Avatar
OP's routing is per Cobb's instructions for 3-port setup.
Other rides:
History:
 Old 07-21-2018, 06:48 AM   #13
Fstrnyou's Avatar
Not to start a whole new discussion on boost source, but I use the stock EBCS boost source (compressor housing). It's a lot less hose and the source pressure should be higher there which I think would make a faster reacting wastegate.
Other rides:
History:
 Old 07-21-2018, 07:12 AM   #14
Solarsurge's Avatar
Precisely why probably every other EBCS maker recommends my routing in their instructions and nearly all modded Mazdaspeeds are hooked up that way. I honestly don’t know why Cobb is so extra with their routing. It makes no sense.
 Old 07-21-2018, 10:34 AM   #15
Fstrnyou's Avatar
Route as described. Either way, I don't care. Cap off any unused ports.
Other rides:
History:
 Old 07-23-2018, 01:23 PM   #16
KamloopsDan's Avatar
Posts: 64   (View Stats)
KamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to allKamloopsDan is a name known to all
This is how mine is setup on my BNR S4.
KamloopsDan is offline   Reply With Quote
The Following User Says Thank You to KamloopsDan For This Useful Post:
Solarsurge (07-23-2018)
Cobb EBCS m249saw 2010 MS3 - Turbo Induction 70 07-22-2012 09:17 PM
Page generated in 0.37289 seconds with 24 queries
