Groans: 211
| Not Ranked : 0 score
2. Do a compression and leak down test and post the numbers. 3. Send it off for a rebuild or get an S3/S4 and downpipe. And an aftermarket TMIC as stock sucks and heatsoaks easily. Then you wont be disappointed in the HP numbers. But don't expect a wildly huge gain on our shitty California 91 octane. Maybe consider getting a second map from Freektune for E85. Most run around a 30% mix and gain around 50HP over pump gas only.
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
| Upgrading HU, should I upgrade amp? | sallyspeed3 | MazdaSpeed 3/6 - Car Audio & Electronics | 4 | 07-30-2011 06:41 PM |
| upgrading exhaust | Vinnie | MazdaSpeed 3 - Engine, Transmission & Driveline | 21 | 02-18-2010 10:47 AM |
