![]() Join Date: Sep 2017 Location: Western Mass
Rep Power: 43 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
(Thread Starter) | Not Ranked : 0 score So last night my engine popped... Background: Bought the car private sale late aug/early sept. Previous owner didn't know if cam actuator was ever done on it, so the grand scheme was to do the timing set sooner then later to avoid what happened to my best friend, were the actuator let go taking out the head. Fast-forward to now: Bought the timing set from Edge, take apart the car, put everything in... Add used JBR intake with new filter for good measure along with intercooler hoses. Put everything back together start the car and it purrs like a kitten, life is good. Since the purchase of this car and knowing the fact that its unknown about the cam actuator I took it easy on it until now, now its time to see what the car feels like at about redline... Take off easy in 1st then give it the beans! Shift 2ed, this is pretty sweet! Shift 3rd only stay in it for a second then shift 4th to slow down... Car acts unusual and then the oil light comes on... Shut off immediately, coast to side of road... Trail of fresh engine oil with a puddle forming under it... Awesome. Push the car to my Uncle's house that happened to be down the road, park it, get a ride to get my other vehicle. I work half days at my main job on Fridays so I go to investigate, car won't turn over, I found nice aluminum fragments on the belly pan right off the bat... Sweet! there must be a nice hole somewhere! take the belly pan down look up... nothing obvious... huh this is weird. At this point I have access to limited tools but took the intercooler off then pulled the plugs which all looked good which leaves me confused. Going to tow the car to my parents house to use my fathers lift again to further investigate. That being said if I do need a block my best friend has a car he bought with an over heated motor that I can rob the block out of baring the block is still good. The thought now is to never have this happen again so I was thinking of Manley rods and possibly Wiseco pistons even though I don't plan on putting a big turbo on this car I just cant see putting stock stuff back in at this point. I know I will address that issue tonight when I actually find something.And to add to this awesomeness I found the rear diff mounts were on there way out, hence why I took off nice in 1st, but previous to this event I just ordered both SURE mounts... yay
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 |
| Not Ranked : 0 score Anyone buying an MS6 should add the cost of a new motor when buying one regardless of mileage. I know some make it up to higher mileage, but the majority lose compression in #3 and or grenade like yours.
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 |
| The Following User Says Thank You to dale_gribble For This Useful Post: | MazdaspeedKills (11-02-2017) |
![]() Join Date: Aug 2009 Location: Hershey, PA
Rep Power: 265 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 4 Posts
Fact remains, all turbo motors regardless of manufacturer have durability issues. That's why my next car will be N/A.
__________________ '06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs | |
| Not Ranked : 0 score If losing compression on #3 and/or grenading are my only options, then I guess the pin is pulled on mine, cause compression is good. I've been keeping my eyes peeled for deals.
Groans: 111
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
(Thread Starter) | Not Ranked : 0 score Haven't taken a picture yet but with a mirror we found a hole behind the starter so... its either cyl 3 or 4 that got it, my father and I are semi-zing that the oil pump wasn't really happy.
Groans: 438
The more I think about it, the more I wonder if there was something that went wrong with the balance shaft, and that's what took the motor out.
__________________ All good things must come to an end... | |
Groans: 111
| Neutral : +1 score LSPI.
| The Following 2 Users Say Thank You to mituc For This Useful Post: | MD1032 (10-29-2017), monkey.bones.007 (10-29-2017) |
![]() Join Date: May 2012 Location: Greensboro NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 751
Groans: 27
| Neutral : +1 score it does sound like LSPI but usually thats accompanied with high boost low rpm scenario's
__________________ 06 VRM Speed 6 W/Navi 05 Mazda Family Truckster FREEKTUNED\\Cobb AP\\Autotech Internals\\Eibach Pro Springs\\Sure SRI+TIP\\Street Unit TP\\CPE RMM\AWR 88 Duro TMM\\Forge V1\\JBR Shortcut\\JBR SSB\\CPE & Sure Rear Diff Mounts\\Unicorn Blood (Rotella T6) twitter.com/djern instagram.com/djern facebook.com/djern |
Groans: 111
| Not Ranked : 0 score Not necessarily. 1st/2nd gear or low part throttle acceleration in any gear after moving with a constant speed and rpm at low load is where LSPI occurrences blew all engines.
| Not Ranked : 0 score Holy crap! I just watched a video of a Vauxhall Opel and what they claim was knock/ping when I searched for LSPI. That's the same crap my car was doing way back when it was stock and the reason I bought versatuner in the first place. I was getting crazy KR for no apparent reason...or so I thought at the time. It would spit and sputter and make that same noise in the video and blow black smoke because of Knock enrichment.
![]() Join Date: Jun 2009
| Not Ranked : 0 score A good tune will minimize the risks of LSPI damage (but not totally eliminate it). Tunes that build high torque above 300 ft pounds at low rpm are not good for this engine and are largely just for dyno queen bragging. Tunes should be softer until 3,500 rpm before ramping up the power. A red line upshift or even an upshift at 5,000 rpm will always cause you to fall back comfortably above the low rpm danger, so there is little benefit in having crazy high torque at or below 3,000 and a lot of risk. Even on stock tune these engines can blow if you get heavily into boost below 3,000 rpm. The damage is cumulative, so the boom might happen when just cruising with light throttle inputs.
| Not Ranked : 0 score My "LSPI", if that's what it was, went away when I nerfed my WGDC tables to zero at 3k and below. I left 3.5k and up as they were. Basically running spring pressure on the K04 until 3k, then it would ramp up on its way to 3.5k. That's the last time I had experienced it. But now there appears to be new oils that should "help" with LSPI. GM's test has created a new specification called "Dexos1 Rev2" or something like that.
![]() Join Date: Mar 2010 Location: San Francisco, CA
Rep Power: 295 ![]() Thanks: 14
| Not Ranked : 0 score WELP, This thread just made me look at my nearly 100,000 MS3 very differently
__________________ 2009 Mazdaspeed 3 GT CWP Mazdaspeed Coilovers // BMW E46 M3 Front Endlinks (works perfectly) // SPC Rear Camber Arms // Mazdaspeed CAI // CP-E Turbo Inlet // TurboXS BPV // CP-E 60 Duro RMM // Damond PMM // TWM Short Shifter // JBR Shifter Bushings // JBR Heavy Shift Knob I have an Autotech HPFP laying around, just too lazy to install it. |
Groans: 438
| Not Ranked : 0 score I wish my car was acting up before, throwing codes, blowing smoke... Something that would have told me something was wrong. I had no issues at all before it happened, other than the injector seal going bad about 5 months earlier. But I replaced all of those with CS seals,compression was good after reinstalling, and car ran perfectly. Here's some pics of the damage. Funny thing is (hahaha... I guess?) the crank was in perfect condition other than the gear for the balance shaft.
Groans: 111
![]() Judging by how #3 was cracked it may have been some extra oil in that cylinder, and too much was too much once things started moving. It could have been LSPI as well if the detonation was big enough, when the engine starts cold with all that soot coming back from the EGR and crankcase ventilation system you never know. The BS gear most probably was damaged by the rod bits. it's hard to tell once this happens and you have metal pieces everywhere. I hate seeing this kind of pictures with engines... When they fist popped up back in like 2009-ish I said to myself that when my engine will go I hope it will go differently and remain usable for a rebuild. I was kind of lucky in this regard, first time I cracked ringlands on #2 and #3 (26PSI on stock everything and revlimit set at 7k was too much) and second time the custom forged pistons hit the squirters and even if the BS gear was damaged by one of the squirters at least the rest of the engine (block, head, turbo) remained intact.
| Not Ranked : 0 score sometimes parts may get weaker and weaker over time and stress. I remember an old tempo 2.3 that overheated after the belt broke, It overheated at the point of losing all it's power....i just replaced the water pump and belt...I ran the car for almost 1 year without management. One day, i just reved it up a little in neutral and a rod went out of the bloc. I was surprise it didn't happened sooner but at time the rod went out, there was no reason for it to break right there...
![]() Join Date: May 2016 Location: Niskayuna, NY
Rep Power: 0 ![]() ![]() Thanks: 4
| Not Ranked : 0 score I have a speed 6 with 145k miles... seeing all these random engine grenades makes me nervous and want to just get rid of it now and get something else ... part of me still wants to keep it i really love this car! That is really unfortunate OP.... |
(Thread Starter) | Not Ranked : 0 score Well I can't get rid of the car, I've only had it two months, the body is freaking solid for 111K and being in the northeast, I will try to snap pictures of the undercarriage soon. I know I don't keep you guys updated a lot on here but working two jobs, ripping this apart and other commitments have me taxed on time. The spare block that my buddy gave me is being sent to my engine builder on tuesday to see what it needs for machine work. Fingers crossed I'll have the blown one out and on the engine stand disassembling it this weekend. So the next question I have is... Whats with people taking the counter balance assembly out of these engines? Wouldn't you have to have the rotating assembly re-balanced?
Groans: 211
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
| The Following User Says Thank You to Thor Hammer For This Useful Post: | LenSpeed6 (11-03-2017) |
(Thread Starter) | Not Ranked : 0 score thanks for the link!
__________________ 06 Speed6 White/Black interior Sure Diff Mounts, JBR Intake, JBR I/C Hoses, Wiesco pistons .5mm over, Molnar H-Beam Rods, King bearings, New to me Cylinder Block, CS turbo, CS catted turbo back exhaust, CS HPFP, CS EBCS, CS injector seals, AP v3, FREEKTUNE, rebuilt clutch from Falcon Clutch with kevlar lining, DM PCV plate, DM stage 1 OCC, EcoBoost oil pump, vented oil cap with baffle, Speed Solutions PTO bearing caps, All Damond mounts To think... this is suppose to be my winter car... because, '72 AMC Javelin AMX 366 CI, 4speed 13.13 quickest 1/4 mile et so far '12 1/2 Triumph Daytona 675R stock some how '79 AMC Spirit AMX, 4.6L stroker I6 | |
![]() Join Date: Mar 2017 Location: Guelph, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Not Ranked : 0 score I did hear fairly recently that a lot of ST owners are suffering from LSPI as well. Essentially the same basic engine idea. I also remember watching someone’s YouTube video about them trying to floor their ecoboost mustang in 5th gear and have it blow black smoke and backfiring. It’s very hard to minimize boost in lower rpm range. While highway cruising I watch my boost gauge more than any other gauge. If Im on any incline and I see my gauge coming out of vacuum for more than a second, I downshift.
__________________ '06 MS6 GT VRM |
(Thread Starter) | Not Ranked : 0 score yeah my plan is to add a gauge package to this car, its a wonder why they never put at least a boost gauge from the factory on these cars. I'd love to get and access port, we will see if funds prevail with all these other parts I have to buy.
![]() | | #24 | ![]() |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score You could just always run e85. It would help a lot with charge temp wich i believe is a factor in LSPI. Alcohol does wonders for this motor when it comes to longevity. Knowing how these cars are hit and miss when it comes to random out of know where catastrophic suicide i wanted a back up plan. Also if i crashed or the car got totaled i wanted a spare motor so i could buy a speed with a blown motor for super cheap. I kept my eye out for a extra used block early on to build slowly and on the cheap just incase i needed it. Wife getting prego just launched my plans into overdrive.
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
| Not Ranked : 0 score I've been running 2 gal of E with each tank since early summer. It really takes some of the stress away...from me and the motor. Ha. I'd like to think it saved me on those hot days stuck in CLT traffic with TMIC heatsoaked and I mash the go pedal when I see a break in traffic in a lane that is moving.
![]() | | #27 | ![]() |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score Bad tune and if you are awd boosting it at low rpm will bend the rods, aftermarket rods are a must, fueling must be on point. or you will need a 12 pack of engines, But engines can't fix a bad factory tune.... good luck
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
![]() | | #28 | ![]() |
(Thread Starter) | Not Ranked : 0 score I kinda figured that id have to break down and get a AP, just overwhelming when I have to dump $3k+ on a car I just bought to use for a freaking daily. Its frustrating when my buddy and I pounded his car with a bad turbo and nothing happens and continue to have fun with the CS turbo in his, I buy a car that ran stronger then his did stock for whatever reason, red line the dumb thing 3 times and it suffers catastrophic failure. sorry for the short rant, I guess at the end of it fingers crossed I wont have to worry about this crap happening again and if my buddy explodes his engine we will know what to do.
![]() | | #29 | ![]() |
| Not Ranked : 0 score When running an old turbo sport car, you should save some money for an engine or at least the turbo....If you run it for a long time, you will have to... Water/meth injection can be a nice insurance against LSPI. My stock engine did see a lot of high boost in low rpm events without knock for years until i made a tuning error that took away a ringland. Just few seconds of knock was enough...Even if the ringland went away first, i was able to see marks on the specific upper rod bearing....Maybe if i would have continued to wot it this way i would have ended with a rod out of the bloc too...
| This music makes me wanna go zoom zoom boom boom!!! | asall667 | MazdaSpeed 3/6 - Car Audio & Electronics | 28 | 09-17-2011 01:38 PM |
| BOOM-'FREAKIN-BOOM | tutuga | MazdaSpeed 3 - Engine, Transmission & Driveline | 181 | 05-09-2009 12:53 AM |
| engine boom=( w/o a boom sound | johnac08 | MazdaSpeed 3/6 - Turbo Induction | 96 | 05-05-2009 08:46 PM |
| Uh oh i make boom boom | Jarods7920 | MazdaSpeed 3 - Engine, Transmission & Driveline | 167 | 05-03-2009 09:00 AM |
