Like Tree16Likes
 Old 12-29-2011, 04:27 AM   #1
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
Doesn't Synapse have a BOV for the DISI? Or was there a fallout I missed back in the day?
http://synapseengineering.pinnacleca...acturer&mid=12
2007 MS6 - broked & gone
2006 MS6 - less broked
RhoadBlock is offline   Reply With Quote
 Old 12-29-2011, 06:23 AM   #2
irishking03's Avatar
Posts: 2,136   (View Stats)
irishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the world
Synapse Engineering Outlet
I will add it just incase someone does come across it.
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
irishking03 is offline   Reply With Quote
 Old 02-02-2012, 05:17 PM   #3
I was running that on my car for a while.
Excellent valve, holds up to 60 psi and is very fast.
usename Robry has it on his car now.
 Old 02-03-2012, 08:00 AM   #4
DaDoctor's Avatar
Posts: 276   (View Stats)
DaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the world
a few posts up, I asked a question about the cobb xle valve. Whats your take, you think its the same as the wrx one?
Also, how are you running it? with full circulation, does it make any sound?
2011 Mazdaspeed 3 - Black Mica
NJSPEED3 PNP Manifold/Cp-e HPFP/Cp-e Catted DP/Cp-e FMIC/Cp-e Stage2 RMM 75a PMM and TMM/Cp-e Triton/CS Exhaust hangers/JBR SSP V1/3 Bar Map Sensor/Matt Jackson Harness/JBR Tigs
Suspension: KW V1 Coils/CS FSB & RSB/CS Front and Rear Endlinks/CS Aluminum Skidplate/CS Mid-Chassis Brace
Appearance:Lamin-X Smoke - Headlights, Taillights and reflectors/Corksport Antenna/TagArmur CF License Plate/Optima Yellowtop Battery/CS Interior Lighting Kit/DDM 3k/Block8head Defrost guage/ defi red boost guage
DaDoctor is offline   Reply With Quote
The Following User Says Thank You to DaDoctor For This Useful Post:
rfinkle2 (02-03-2012)
 Old 02-03-2012, 08:07 AM   #5
It is a high quality bpv, without a doubt. I bought it because I like Cobb products, and it is specifically advertised as being meth resistant.
I'm running it in full recirc.
It does make a sound, but not quite as loud as a full VTA BOV would.
If you have an open element intake such as an sri or cai, that is what lets most of the sound out of the intake system from a bpv.
I'm not sure whether or not the dimensions for the wrx and the mazdaspeed are the same on the flange, so I can't tell you for sure whether or not the xle for the 2 applications are identical.
Edit: see post below
DaDoctor (02-03-2012)
 Old 11-16-2012, 07:06 PM   #6
Rainmens's Avatar
Posts: 129   (View Stats)
Rainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the worldRainmens is the leader of the world
Official Synapse Store | Buy our DV, BOV, and Wastegate with Synchronic Technology and more | Synapse Engineering
Yes sir, Synapse FTW! Self tuned (no shims) BPV.
304whp/360tq Vdyno 1.01 CF
Cobb AP, Sure 3" Full3 Aeros Intake, Autotech Internals, M2 DP, 3" CP-E Single Exit (w/resonator), 3.25" ETS, PnP'ed IM w/VTCS removed, 1/16"Sure TIG spacer Synapse BPV, AWR 70 Duro RMM, JBR 70 Duro TMM, Denso 1-Step Colder Plugs, TWM Shifter Bushings, SM OCC, Custom Shift Knob, Custom Shifter Weight, SURE Shorcut, H&R Springs, Tenzo DC-6 Wheels
Rainmens is offline   Reply With Quote
The Following 2 Users Say Thank You to Rainmens For This Useful Post:
mig02 (12-26-2012), rfinkle2 (01-11-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/bov-boost-bypass-valve-thread-99892/
?????? This thread Refback 11-08-2013 09:22 AM
Blow off valve 2010 ms3 This thread Refback 06-13-2012 12:09 AM
Turbosmart dual port bov? - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 02-14-2012 08:35 AM
Page generated in 0.34324 seconds with 26 queries
