Like Tree16Likes
 Old 12-17-2011, 04:25 PM   #1
irishking03's Avatar
Posts: 2,136   (View Stats)
irishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the world
Default BOV/BPV Thread
****Updated 2/2015 by @Inquisitive;! Thank you!***
BPV / BOV
A Blow-off Valve (BOV) or Bypass Valve (BPV) is a pressure release system present in most turbocharged engines. Its purpose is to prevent compressor surge, and reduce wear on the turbocharger and engine. Blow-off valves relieve the damaging effects of compressor "surge loading" by allowing the compressed air to vent to atmosphere, making a distinct hissing sound, or recirculated into the intake upstream of the compressor inlet. They provide improved / quicker throttle response, better boost handling capacity / higher clamping load to maintain boost pressure more reliably and quicker spool recovery.
A compressor bypass valve (CBV), also known as a pressure relief valve or diverter valve, is a manifold vacuum-actuated valve designed to release pressure in the intake system of a turbocharged vehicle when the throttle is lifted or closed. This air pressure is re-circulated back into the non-pressurized end of the intake (before the turbo) but after the mass airflow sensor.
A blow-off valve, (sometimes "hooter valve", not to be confused with a bypass valve) performs the same task but releases the air into the atmosphere instead of recirculating it. The blow-off action produces a range of distinctive hissing sounds, depending on the exit design. Some blow-off valves are sold with a trumpet-shaped exit that intentionally amplifies the sound. Some turbocharged vehicle owners may purchase a blow-off valve solely for the auditory effect even when the function is not required by normal engine operation. Motor sports governed by the FIA have made it illegal to vent un-muffled blow-off valves to the atmosphere.[citation needed]
Blow-off valves are used to prevent compressor surge, a phenomenon that readily occurs when lifting off the throttle of an unvented, turbocharged engine. When the throttle plate on a turbocharged engine closes, the high pressure air in the intake system is trapped by the throttle and a pressure wave is forced back into the compressor. The compressor wheel slows rapidly and may even stall, and the driver will notice a fluttering air sound. The rapid slowing or stalling stresses the turbo and imparts severe turbo lag if the driver accelerates immediately after the surge event.
Disadvantages
In the case where a mass airflow sensor (MAF) is used and is located upstream from the blow-off valve, the engine control unit (ECU) will meter out excess fuel because the atmospherically vented air is not subtracted from the intake charge measurements. The engine then briefly operates with a fuel-rich mixture after each valve actuation.
The rich mixing can lead to hesitation or even stalling of the engine when the throttle is closed, a situation that worsens with higher boost pressures. Occasional events of this type may be only a nuisance, but frequent events can eventually foul the spark plugs and destroy the catalytic converter, as the inefficiently combusted fuel produces soot (excess carbon) and unburned fuel in the exhaust flow can produce soot in the converter and drive the converter beyond its normal operating temperature range.
An alternative method for utilizing both a MAF and a blow-off valve is to have the MAF located down stream between the intercooler and the throttle plate. This is known as Blow-through rather than the traditional Draw-through set up. Care must be taken as to the position of the MAF to prevent damage to the sensitive element. (I.E. on a SR20DE motor, the MAF must be at least 12" from the throttle plate, and the blow-off valve must be 6" from the MAF sensor). By using a draw-through method, the MAF won't be affected by the blow-off valve opening as the pressure is vented before the air reaches the MAF.
One approach used to mitigate the problem has been to reduce the boost pressure, which reduces the required venting volume and yields less charge over-calculation by the ECU. The air can also be recirculated back into the intake, a typical stock setup for cars with an upstream MAF sensor. The situation can also be corrected by switching the fuel metering system over to a manifold absolute pressure sensor, a conversion that usually requires a compatible aftermarket ECU or piggy-back fuel controller. The MAP sensor monitors the absolute pressure in the manifold at all times and will correctly detect the change that occurs when the valve vents, allowing the ECU to reduce fuel metering accordingly.
Operation
A blow-off valve is connected by a vacuum hose to the intake manifold after the throttle plate. When the throttle is closed, the relative manifold pressure drops to below zero bar and the resulting pressure differential operates the blow-off valve's piston. The excess pressure from the turbocharger is then vented into the atmosphere or recirculated into the intake upstream of the compressor inlet.
FYI
Most BOV/BPV will need some maintenance through the years. Basically they need to be re-oiled.
The following list will be discussed below with images:
• Forge (both V1, V2 and unknown versions purchased) BPV
• Turbosmart Dual Port BPV / BOV Combination
• Go Fast Bits (GFB) Respons BPV / BOV Combination
• Forge V2 BPV
• Forge V1 BPV
• HKS SSQV BOV
• CorkSport (CS) MZR BPV
• Cobb XLE BPV / BOV Combination
• Synapse Synchronic BOV
• Forge V? BPV
• TurboXS BPV
• Tial QR BPV
• Turbosmart Kompact Plumb Back BPV
• GReddy RZ BOV
• CX Racing BOV (comes with their FMIC)
• JBR DISI Bypass Valve Return Hose
• Synapse Synchronic DV
Turbosmart Dual Port Maz Type 5 BPV / BOV Combination
Billet aluminium; Holds boost more efficiently over stock valve; BPV spring rate is tuneable to the vacuum of your car; Choice of high pressure and low pressure springs; Gain Top End Horsepower; vents to intake, atmosphere becoming a blow off valve or adjustable mixture of both, while the Sleeper version is quiet during mild boost; note: both are taller, therefore, will not work with stock air-box
Available from: Turbosmart Dual Port Maz Type 5 BPV / BOV Combination
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $482.96
Dual action, twist BPV to BOV adjustable
Available from: Go Fast Bits (GFB) Respons BPV / BOV Combination
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $268.68
Forge BPV
Made from billet aluminium
V1: Makes a ping / swords clashing noise
V2: stealth
Available from: Forge BPV
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $169.95
HKS SSQV BOV
Info: http://www.hksusa.com/
Nickel-plated, die-cast metal secondary valve, which is swaged to the primary valve, a stainless steel C-Clip and spring to increase sealing and durability; First Sequential Blow-Off Valve featuring a unique, pull-type, sequential valve structure and a differential pressure control system allowing for stable operating ranges from low to high boost pressures. Note that a separate flange must be purchased and fitted to the BOV before installing on your car; comes with inline filter on the vacuum line; can keep closed at idle. The recirculating kit is an optional extra (additional expense), but note that 100% VTA can damage your CAT.
Requires a separate (extra cost) mounting flange kit which is difficult to install properly (ex. CP-E, Jay Racing / JSC Speed, etc.)
Available from: Hasegawa, Kitagawa, and Sigma (HKS) SSQV BOV
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $331.95
Half the spring height, 30% larger piston, 33% faster to vent
Available from: CorkSport (CS) MZR
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $188.99
Different vent modes, pre-load adjustable, compatible with alcohol / water mix, reliably holds high levels of boost without leaks, fast venting, Teflon coated, hard anodized piston providing low sliding friction, reduces surface wear and minimizes maintenance requirements, can hold up to 60 psi
Available from: Cobb Tuning XLE BPV / BOV Combination
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $295
Eliminates the need for diaphragms by using a piston actuator that does not require frequent lubrication; can hold 60 psi yet still prevent compressor surge; can install as pull or push type valve
Available from: Synapse Synchronic BOV
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $289.95
TurboXS BPV
Each flange is beefy to keep it from warping and allowing you to have the best mating surface possible
Available from: TurboXS BPV
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $239
Tial QR BPV
6 spring options (3 PSI to 12 PSI)
Available from: Tial QR BPV
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $259 silver, black, red, purple, blue
Available from: Turbosmart Kompact Plumb Back BPV
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $184.49
GReddy RZ BOV
Easily adjustable to eliminate compressor surge and preventing premature boost leakage while increasing boost response between shifts; made of durable cast and billet aluminium frame; valve to diaphragm ratio provides performance that cheap piston types cannot offer; spring stiffness adjustment screw; three models
Available from: GReddy RZ BOV
MS6 (?), MS3 Gen1 (?), MS3 Gen2 (? Although several Genpu owners have installed this) $360 for Type FV for RX-7
Available from: CX Racing BOV (comes with their FMIC)
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $399
Direct (5 layers silicone & 4 layers of reinforcement) replacement for OEM, which will show signs of deterioration and cracking within a year degrading performance to eventually throwing a CEL.
Available from: JBR DISI Bypass Valve Return Hose
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $35 in red, blue, black or white
CP-E Helihose
4-ply reinforced silicone hose, helical cut throughout for flexibility, steel wire routed through the hose to prevent kinking, while maintaining extreme flex, two SS liner clamps are included, providing clamping pressure without tearing silicone, gloss silicone finish with CP-E logo, 14.5” in length, made in the U.S.A., lifetime warranty
Available from: CP-E Helihose
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $64.48
CorkSport (CS) DISI Silicon Bypass Valve Hose
Made from long lasting, four-ply reinforced, high quality, molded silicone for a strong flexible connection for ideal flow from the bypass valve to the turbo inlet pipe, comes in black, red, blue or white with two T-Bolt clamps
Available from: CorkSport (CS) DISI Silicon Bypass Valve Hose
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $39.99 in black, red, blue or white
Eliminates the need for diaphragms by using a piston actuator that does not require frequent lubrication; can hold 60 psi yet still prevent compressor surge; extremely fast response (< 25 msec) to eliminate compressor surge, 6061 aluminium, use a bolt on adaptor or weld Al or SS flange
Available from: Synapse Synchronic DV
Caps for Synapse Synchronic DV
MS6 (Yes), MS3 Gen1 (Yes), MS3 Gen2 (Yes) $282.95; standard black cap (or colours: blue, red, orange, raw - add $29.99)
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
irishking03 is offline   Reply With Quote
The Following 33 Users Say Thank You to irishking03 For This Useful Post:
09Speed3Z (12-17-2011), 2008MS3H (01-16-2012), Arnie1229 (01-09-2015), blanczak (07-13-2012), CWP_MS3 (03-20-2012), Dahouse702 (12-26-2011), Don06speed6 (12-17-2011), ESB Jiu JItsu (08-06-2012), i8urgti (12-17-2011), jax ms3gt (05-10-2016), Jetech (07-02-2013), JLuth (12-17-2011), Juyoung (09-02-2012), KusteLokal (12-17-2011), Mase (03-22-2012), mayer (02-24-2012), mrthedan (04-27-2013), Ms3_Miami (02-03-2012), MS6FL (12-17-2011), Onelovesoccer (12-22-2011), PapaBruno (09-29-2014), Plavin1991 (05-10-2012), Pointless (08-06-2012), Poohster (12-22-2011), rfinkle2 (12-17-2011), RhoadBlock (12-17-2011), RotaryWeaponSE7EN (03-22-2012), Sid3wayS (12-29-2011), SJP0tato (12-21-2011), Staceye77 (06-01-2012), TWENTY1 (04-05-2013), uncorked11 (02-15-2012), zpele (12-17-2011)
 Old 12-17-2011, 04:45 PM   #2
JLuth's Avatar
Posts: 92   (View Stats)
JLuth has a reputation beyond reputeJLuth has a reputation beyond reputeJLuth has a reputation beyond reputeJLuth has a reputation beyond reputeJLuth has a reputation beyond reputeJLuth has a reputation beyond reputeJLuth has a reputation beyond reputeJLuth has a reputation beyond reputeJLuth has a reputation beyond reputeJLuth has a reputation beyond reputeJLuth has a reputation beyond repute
Nice write up!
2006 Speed6 <- SURE TIP & SRI, COBB AP Stage 1+ ->
Next: DP, RMM, RDFM & Brace, HPFP Internals.
JLuth is offline   Reply With Quote
The Following User Says Thank You to JLuth For This Useful Post:
irishking03 (12-17-2011)
 Old 12-17-2011, 05:10 PM   #3
KusteLokal's Avatar
Posts: 2,664   (View Stats)
KusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the worldKusteLokal is the leader of the world
Groans: 124
This should be made a sticky
1995 Miata 1.8
2006 MS6 Sold
KusteLokal is offline   Reply With Quote
The Following User Says Thank You to KusteLokal For This Useful Post:
 Old 12-17-2011, 05:13 PM   #4
Don06speed6's Avatar
Posts: 2,492   (View Stats)
Don06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the worldDon06speed6 is the leader of the world
Groans: 62
@Raider will probably merge it into the NEWB thread.
Cobb AP(FREEK TUNED)/CS TBE/SURE AEROS/CPE TIH/ ITV 22/SU RMM/KMD INTERNALS/SURE DREADNAUGHT/JUGGERNAUGHT/WHITELINE RSB/SURE ANCHORS/SURE COUNTERWEIGHT/SURE SHORTCUT/JBR HEAVY KNOB/JBR EGR DELETE/SPC BALL JOINTS/CENTRIC BLANKS/HPS PADS/BNOON BOLT/ALTERED CUSTOMS FMIC/TURBO XS RFL
Don06speed6 is offline   Reply With Quote
The Following User Says Thank You to Don06speed6 For This Useful Post:
 Old 12-17-2011, 05:17 PM   #5
Actually waiting for him to add it.
2012 Liquid Silver
Cobb AP
 Old 12-17-2011, 06:52 PM   #6
Sorry, actually Just saw this. Can you add Forge v1 and v2? Blue springs no shims. Oh and this is. Sticky. Will mess with the main thread in the am. @RhoadBlock to updated the newb thread.
I'll throw $ your way when I get to a computer.
mazdaboy22 (10-29-2012), shawn19 (07-16-2012)
 Old 12-17-2011, 06:55 PM   #7
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
blue 2 shims you mean, killahpanties.
07 MS3
The original Genpoo Hater
zpele (12-17-2011)
 Old 12-17-2011, 06:58 PM   #8
For me, no shims. Wild.
Don06speed6 (12-17-2011), shawn19 (07-16-2012)
 Old 12-17-2011, 07:16 PM   #9
I will work on it tomorrow at some point. I'm finishing some Christmas shopping. Hope it's okay for now.
2012 Liquid Silver
Cobb AP
The Following User Says Thank You to irishking03 For This Useful Post:
 Old 12-17-2011, 07:20 PM   #10
spoof3r's Avatar
Posts: 260   (View Stats)
spoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the worldspoof3r is the leader of the world
Very nice, detailed write-up. This will be great. We better not have any more threats with questions concerning this matter.
2010 Mazdaspeed3 - Garrett GT3076R Turbo, SteedSpeed Manifold, Tial 38mm External Wastegate w/ Dump Tube, ATP Big MAF Housing, ATP 3" TIP/Intake, HKS SSQV BOV, Ultimate Racing FMIC, Ultimate Racing Catless DP, CS Test pipe, CS Catback Exhaust, Autotech HPFP Internals, Hallman Pro Boost Controller, Cobb AccessPORT, BC Coilovers, DDM 8000k HID's, Red Brake Calipers w/ Decals, Custom Smoked Headlights, Smoked Taillights, 18% Window Tint.
2011 Mazda2 Sport - OEM Fog Lights, OEM Touring Rear Spoiler, Sport Edition F2 Silver Wheels, Green Brake Calipers, 18% Window Tint,
Social Engineering - Because there is no patch for human stupidity.
spoof3r is offline   Reply With Quote
The Following User Says Thank You to spoof3r For This Useful Post:
 Old 12-17-2011, 07:38 PM   #11
I will add a link to where these can be bought from. Thanks for the input guys..
2012 Liquid Silver
Cobb AP
 Old 12-17-2011, 07:44 PM   #12
Robust Mongoloid
09Speed3Z's Avatar
Groans: 399
Good write up Ryan,
A few spelling mistakes and grammar mistakes but overall well done.
Just a few quick things I saw....... (all my own personal suggestions)
Many Videos can be watch to listen to what these sound like.
Many videos are available to help you decide between which sound you would like for your car.
You need to purchace the seperate flange
*purchase
**separate
There are a few different companies as well as colors to choose from when looking to add a BOV/BOV to your car.
BPV/BOV
, as the inefficiently combusted fuel produces soot (excess carbon) and unburned fuel in the exhaust flow can produce sootin the converter and drive the converter beyond its normal operating temperature range.
lolwut?
How about pick one or the other inefficiently combusted fuel or unburned fuel.
I have choosen the HKS
It should be chosen. Lose an "o"
/ Grammar Nazi.
______________________
Built By NATOR
Tons of Ricer Mods
The Following 4 Users Say Thank You to 09Speed3Z For This Useful Post:
Analytical (03-30-2018), Arnie1229 (01-09-2015), BobbleHead (12-18-2011), irishking03 (12-17-2011)
 Old 12-17-2011, 07:44 PM   #13
RhoadBlock's Avatar
Posts: 793   (View Stats)
Groaned at 7 Times in 4 Posts
^ lol nice
Adding it to the Newb thread now.
@irishking03 also, change the Forge link from a link to a pic. And I'd put a one or two line gap in between each brand, just so all the pics don't run together. You don't necessarily have to add a link to each one if you don't want to. You can probably just mention at the top that most, if not all, can be purchased from several of the forum vendors. Just link the Vendor Section or something. Good work bro.
2007 MS6 - broked & gone
2006 MS6 - less broked
RhoadBlock is offline   Reply With Quote
The Following User Says Thank You to RhoadBlock For This Useful Post:
 Old 12-17-2011, 07:50 PM   #14
Originally Posted by 09Speed3Z View Post
Good write up Ryan,
*purchase
**separate
BPV/BOV
lolwut?
/ Grammar Nazi.
Thanks Pal. I will fix. I kinda just through this together and forgot to look over it. Im trying to do it but I just got laser eye surgery last night and I cant quite look at the computer for to long with out my eyes bothering me. But as soon as I can I will change this.. Thanks again
2012 Liquid Silver
Cobb AP
 Old 12-17-2011, 07:56 PM   #15
Originally Posted by RhoadBlock View Post
^ lol nice
I added Forge Photo.. I added a line after each company branded BPV.. WIll edit tomorrow. Eyes are bothering me a bit tonight.. A little off topic but laser eye correction was done yesterday morning and my shit is all dry.. "NO HOMO"
2012 Liquid Silver
Cobb AP
RhoadBlock (12-18-2011)
 Old 12-26-2011, 01:12 PM   #16
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
@irishking03
Just figured Id throw my .02, my HKS came with a flange already mounted and a direct bolt on cost a lil more but well worth the simplicity. Dont want to get newbs confused if they run into it online. Also might want to put that most of these bov/bpv need regular maintnence, re-oiling(the hks dosnt)
TEAM LUXURY
 Old 12-26-2011, 01:27 PM   #17
bigriver's Avatar
Posts: 1,123   (View Stats)
Nice thing about hks and mounting the flange yourself is that you can "clock" the hks before tightening down the snap ring so the vacuum inlet does not rub the hood and align the hks body to not rub the oem shroud cover if still using stock tmic.
Hks comes with an inline filter on the vacuum line.
The cpe helihose is a great replacement recirc hose as it is flexible and reinforced with copper wire.
bigriver is offline   Reply With Quote
 Old 12-26-2011, 01:42 PM   #18
Sid3wayS's Avatar
Groans: 97
The flange mine came with allows for 360 degrees of rotation.
TEAM LUXURY
 Old 12-26-2011, 02:49 PM   #19
bigriver's Avatar
Yes you can rotate 360* but once the snap ring is set completely, the hks should not move. Thats how my flange kit worked. If it does, then a leak could occur since the seal should be tight on the flange. What kit do you have? I bought the cpe kit which uses the hks snap ring. Maybe yours is different, idk.
 Old 12-26-2011, 03:24 PM   #20
Sid3wayS's Avatar
Groans: 97
Oh for sure once the ring is in place that son of a bitch is fucking solid lol. As to what brand Im not sure. I bought it from a non msf vendor n its only description was that it was 2010 specific. Looks almost exactly like the photo up top.
TEAM LUXURY
 Old 12-26-2011, 03:30 PM   #21
bigriver's Avatar
Haha! Ya you had me wondering what kit allows for 360* movement when installed. But since yours is solid, its all good.
 Old 12-26-2011, 05:17 PM   #22
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Maybe add a description of the stock BPV. It's a dual-chambered design, and works really well as long as the glue seal on the top doesn't leak.
I can provide pics of the stock BPV I have disassembled in my garage.
Tapadatass
 Old 12-27-2011, 05:41 AM   #23
@irishking03
I will add that later today when I get a chance.. Thanks
Tapadatass
do it.. Thanks man.
2012 Liquid Silver
Cobb AP
Last edited by irishking03; 12-27-2011 at 05:41 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-28-2011, 04:39 PM   #24
@irishking03
Just added note in RED that says basically you can buy the hks from a few vendors and add the flange and recirc kit.
2012 Liquid Silver
Cobb AP
 Old 12-29-2011, 04:27 AM   #25
RhoadBlock's Avatar
Doesn't Synapse have a BOV for the DISI? Or was there a fallout I missed back in the day?
http://synapseengineering.pinnacleca...acturer&mid=12
 Old 12-29-2011, 06:23 AM   #26
Synapse Engineering Outlet
I will add it just incase someone does come across it.
2012 Liquid Silver
Cobb AP
 Old 01-27-2012, 08:49 AM   #27
DaDoctor's Avatar
Posts: 276   (View Stats)
DaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the worldDaDoctor is the leader of the world
Can anyone confirm that the cobb tuning xle bpv Model#771650 for the mazdaspeed 3 is the same as the cobb tuning xle bpv Model#724650 for the Subaru Impreza WRX 2008-2012? They look identical on cobb's website. I would save almost $50 online if I purchase the wrx one from here:
Cobb tuning 08-10+ WRX and 05-09 LGT , Engine Performance, Subaru 2008+ WRX / STI performance parts, Subaru Performance
If this has been covered already I apologize...
2011 Mazdaspeed 3 - Black Mica
NJSPEED3 PNP Manifold/Cp-e HPFP/Cp-e Catted DP/Cp-e FMIC/Cp-e Stage2 RMM 75a PMM and TMM/Cp-e Triton/CS Exhaust hangers/JBR SSP V1/3 Bar Map Sensor/Matt Jackson Harness/JBR Tigs
Suspension: KW V1 Coils/CS FSB & RSB/CS Front and Rear Endlinks/CS Aluminum Skidplate/CS Mid-Chassis Brace
Appearance:Lamin-X Smoke - Headlights, Taillights and reflectors/Corksport Antenna/TagArmur CF License Plate/Optima Yellowtop Battery/CS Interior Lighting Kit/DDM 3k/Block8head Defrost guage/ defi red boost guage
DaDoctor is offline   Reply With Quote
 Old 02-02-2012, 05:17 PM   #28
I was running that on my car for a while.
Excellent valve, holds up to 60 psi and is very fast.
usename Robry has it on his car now.
 Old 02-03-2012, 08:00 AM   #29
DaDoctor's Avatar
a few posts up, I asked a question about the cobb xle valve. Whats your take, you think its the same as the wrx one?
Also, how are you running it? with full circulation, does it make any sound?
The Following User Says Thank You to DaDoctor For This Useful Post:
rfinkle2 (02-03-2012)
 Old 02-03-2012, 08:07 AM   #30
It is a high quality bpv, without a doubt. I bought it because I like Cobb products, and it is specifically advertised as being meth resistant.
I'm running it in full recirc.
It does make a sound, but not quite as loud as a full VTA BOV would.
If you have an open element intake such as an sri or cai, that is what lets most of the sound out of the intake system from a bpv.
I'm not sure whether or not the dimensions for the wrx and the mazdaspeed are the same on the flange, so I can't tell you for sure whether or not the xle for the 2 applications are identical.
Edit: see post below
DaDoctor (02-03-2012)
 Old 02-03-2012, 08:13 AM   #31
ckMS3's Avatar
Posts: 1,112   (View Stats)
ckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the world
^ my forge v1 and stock bypass worked fine on my friends legacy gt so i don't see why the cobb xle shouldn't work
BNR S3 // E85 Mix // Freektune
348tq/367whp -21.5 psi
Now - 25-26 psi + JBR 3.5 Intake
ckMS3 is offline   Reply With Quote
The Following 2 Users Say Thank You to ckMS3 For This Useful Post:
DaDoctor (02-03-2012), rfinkle2 (02-03-2012)
 Old 02-04-2012, 07:41 PM   #32
Ferg's Avatar
Posts: 1,498   (View Stats)
Ferg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the worldFerg is the leader of the world
@codyb154
2008 Silver Mazda 6s (AEM cai and jdm cbe) sold feb 2011
2008 Black Ms3 SOLD
Vibrant CBE/custom straight test pipe/SURE AEROS SRI/short shifter/jbr chrome molly 88 duro dogbone rmm/rally armor mudflaps/MOTORCRAFT trans fluid/EBC Redstuff front pads/JBR short shift weight/JBR adjustable short shift plate @30%/autotech internals/MD OCC/ Prosport Evo Boost gauge with Vent Pod/NGK one step colder plugs
AP Dizzy Tuned by BUCKER
CorkSport Interior LED Kit
2015 STi Limited in Lightning Red
Stock bottom end died at 18K hard canyon miles.
Current Mods after build
Forged High Performance CP Pistons, CP Rings, King Race Bearings, Manley H Beam Rods, 20g Turbo with 8cm Hotside, Cobb Performance Fuel Regulator, DW300c Intake pump, 1000cc Injectors, Cobb intake, Nameless 3" divorced catless DP, 3" MagnaFlow catback, Grimmspeed EBCS, SPT lower shift bushings, SPT short shifter, Diode Dynamics Boomerang kit, AP v3 Tuned by Justin@FreekTune
[11:46 AM] wdawson4: now here is where i get expensive it takes atleast 250,000 to pound my butthole i cant sell that for cheap
Ferg is offline   Reply With Quote
 Old 02-04-2012, 08:31 PM   #33
deptstower's Avatar
Posts: 6   (View Stats)
deptstower has a little shameless behaviour in the past
this is awesome - thanks so much
deptstower is offline   Reply With Quote
 Old 02-04-2012, 08:39 PM   #34
deptstower's Avatar
i like the cobb xle -- AWESOME
The Following User Says NO Thank You to deptstower For This Un-useful Post:
jeopardy98 (02-04-2012)
 Old 02-11-2012, 09:31 AM   #35
chasgrady's Avatar
Posts: 7   (View Stats)
chasgrady will become famous soon enough
Any suggestions for a Forge V1 with CP-E nano and turbo inlet? which spring / shim combo? Thanks!
chasgrady is offline   Reply With Quote
The Following User Says NO Thank You to chasgrady For This Un-useful Post:
Don06speed6 (02-11-2012)
 Old 02-15-2012, 12:35 PM   #36
DaDoctor's Avatar
Holy crap. Search button lol.
Sent from my T-Mobile G2 using Tapatalk
 Old 02-29-2012, 12:51 PM   #37
serum's Avatar
Posts: 28   (View Stats)
serum has a spectacular aura aboutserum has a spectacular aura about
Great thread. Thanks
08 Cosmic Blue Speed 3 GT, COBB AccessPort, COBB SRI, COBB TIP, Forge v2 BPV, Corksport RMM, TWM Bushing Kit, Denzo ITV22 (1 Step Colder Spark Plugs), Resonators deleted, JBR SSP, Raceland Coilovers, Corksport Rear Camber Arms, 18x9.5 +30 Varrstoen ES2 with 215/40/18 Falken 912 tires
serum is offline   Reply With Quote
 Old 02-29-2012, 01:08 PM   #38
MSpeedzilla's Avatar
Posts: 121   (View Stats)
MSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the worldMSpeedzilla is the leader of the world
Thanks for thread good info
_____________________________________________
2008 Silver Gen 1, MS3 MSCAI, Cobb TIP, Full Catless Race/Downpipe, Cobb XLE Bpv, MAPerformance rmm, Cobb AP, HPFP, xt-m5-qs, Shift bushings(washers), denso ITV22, Torque Android app, .
MSpeedzilla is offline   Reply With Quote
 Old 03-20-2012, 08:41 AM   #39
kopperman1474's Avatar
Posts: 1   (View Stats)
kopperman1474 is an unknown quantity at this point
I am currently in the market and finalizing all the paperwork for my 2011 ms3. I already have a small list of parts I am looking to buy without voiding warranties. The only part that I have been reading about and sort of worried about is the BOV. I am leaning towards the turbosmart dual port 50/50, my friend has this exact piece but I think I would like to hear a little more from a forum. I know I can run full recirculation, but I also want to know that if I keep it 50/50 will my car run rich? It will be my first modification to the car along with a corksport stage II short ram intake. I am worried about the car running rich and causing ecu problems them eventually totally ruining my car. So any information would be greatly appreciated. I was also wondering if any lights on the dash come on such as engine check when you put on the BOV.
Thank you
Future ms3 lover
kopperman1474 is offline   Reply With Quote
 Old 03-20-2012, 09:42 AM   #40
SWAY's Avatar
Posts: 2,517   (View Stats)
SWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the worldSWAY is the leader of the world
Groans: 190
Groaned at 60 Times in 43 Posts
Thank you
Future ms3 lover
You need to worry about other shit before you worry about a bov/bpv, the stock one is fine until you up the boost levels a lot. Get more mods first that matter, that should be down the road.
~Sent from my GNexus running Aokp~
~2011 Liquid Silver MS3~ ---->> ZZB
TEAM LBN BEERS -- FYCN
TEAM MUMFORD -- FYCN
SWAY is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/bov-boost-bypass-valve-thread-99892/
?????? This thread Refback 11-08-2013 09:22 AM
Blow off valve 2010 ms3 This thread Refback 06-13-2012 12:09 AM
Turbosmart dual port bov? - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 02-14-2012 08:35 AM
Page generated in 0.65248 seconds with 42 queries
