![]() Join Date: Nov 2015
Rep Power: 0 ![]() ![]() Thanks: 3
![]() Join Date: Aug 2008 Location: Kenosha, WI
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score So, are are you taking it to a shop or fixing this yourself? If this were my car, I'd take the belt off and start it and see what you hear. Noise gone = something run by the belt needs help. Or you may more clearly hear that it's the timing chain flopping around. Or does the noise change when you actuate the clutch? |
(Thread Starter) | Not Ranked : 0 score don't have a garage so diy is not an option. I did not hear the noise change nor is there any discernable effect on driving - drives the same as before, the rpm's don't bounce, idle is steady. thx |
![]() Join Date: Nov 2016 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
Groans: 105
| Not Ranked : 0 score Can you do any work or diagnosis at home? If not, your best bet is a shop. Not much us keyboard wrenchers can do about a noise from this far in cyberspace.
__________________ Stockish |
(Thread Starter) | Not Ranked : 0 score ac compressor, in case anyone is curious. thanks for entertaining the post. |
| The Following User Says Thank You to Roman-dude For This Useful Post: | Db09ms3 (11-01-2019) |
Groans: 105
| Not Ranked : 0 score No no, thank you for using facebook to figure out the noise
Rep Power: 3747 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| I've got the same noise. Had the AC compressor replaced at the end of last summer, the damn thing has already crapped out again.
| Misfiring Clicking engine sound. | JibboMe | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 32 | 07-20-2015 03:22 PM |
| Knocking sound from engine | rednofive | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 20 | 11-02-2012 09:34 PM |
| Bad Sound from Engine Bay | MattJackson86 | MazdaSpeed 3 - Engine, Transmission & Driveline | 22 | 08-30-2012 08:49 PM |
| Does my engine sound okay? | Qtip | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 04-05-2010 08:16 PM |
| Unusual Engine Sound | mordxp | MazdaSpeed 3 - Engine, Transmission & Driveline | 22 | 03-15-2010 06:53 PM |
