 Old 10-30-2019, 07:53 PM   #1
Roman-dude's Avatar
Posts: 56   (View Stats)
Roman-dude will become famous soon enoughRoman-dude will become famous soon enough
Default Can anyone id this engine sound? Thx
Can anyone id this engine sound? Started a couple of days ago but gotten louder. Haven't made it to the shop yet. No codes or loss of power or increase /decrease in sound at speeds. Thanks.
Roman-dude is offline   Reply With Quote
 Old 10-31-2019, 01:45 PM   #2
deuce_WI's Avatar
Posts: 234   (View Stats)
deuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond reputedeuce_WI has a reputation beyond repute
Groaned at 6 Times in 2 Posts
So, are are you taking it to a shop or fixing this yourself?
If this were my car, I'd take the belt off and start it and see what you hear. Noise gone = something run by the belt needs help. Or you may more clearly hear that it's the timing chain flopping around. Or does the noise change when you actuate the clutch?
deuce_WI is offline   Reply With Quote
 Old 10-31-2019, 01:49 PM   #3
Roman-dude's Avatar
don't have a garage so diy is not an option.
I did not hear the noise change nor is there any discernable effect on driving - drives the same as before, the rpm's don't bounce, idle is steady. thx
 Old 10-31-2019, 02:17 PM   #4
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Can you do any work or diagnosis at home? If not, your best bet is a shop.
Not much us keyboard wrenchers can do about a noise from this far in cyberspace.
Stockish
 Old 11-01-2019, 06:38 AM   #5
Roman-dude's Avatar
ac compressor, in case anyone is curious. thanks for entertaining the post.
The Following User Says Thank You to Roman-dude For This Useful Post:
Db09ms3 (11-01-2019)
 Old 11-01-2019, 10:31 AM   #6
Db09ms3's Avatar
Groans: 105
No no, thank you for using facebook to figure out the noise
Stockish
 Old 11-01-2019, 10:55 AM   #7
Police - Grammarhead
Vansquish's Avatar
I've got the same noise. Had the AC compressor replaced at the end of last summer, the damn thing has already crapped out again.
 Old 11-01-2019, 10:57 AM   #8
Roman-dude's Avatar
which one did you get that already went on you?
Misfiring Clicking engine sound. JibboMe MazdaSpeed 3/6 - Troubleshoot/Diagnostics 32 07-20-2015 03:22 PM
Knocking sound from engine rednofive MazdaSpeed 3/6 - Troubleshoot/Diagnostics 20 11-02-2012 09:34 PM
Bad Sound from Engine Bay MattJackson86 MazdaSpeed 3 - Engine, Transmission & Driveline 22 08-30-2012 08:49 PM
Does my engine sound okay? Qtip MazdaSpeed 3 - Engine, Transmission & Driveline 2 04-05-2010 08:16 PM
Unusual Engine Sound mordxp MazdaSpeed 3 - Engine, Transmission & Driveline 22 03-15-2010 06:53 PM
Page generated in 0.27474 seconds with 24 queries
