  • 1 Post By dale_gribble
 Old 03-11-2014, 04:25 PM   #1
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Default Can someone please measure OD of k04 and/or BNR S3 outlet neck?
I am guessing someone has a k04 and/or BNR S3 out of their car on the bench or something. I need the neck measurements of the cold side outlet to the intercooler; maybe 2-3" below where the boost tube would fasten to the turbo outlet; just above the boost fitting. I am guessing the OD is around 2.5" or so?
Thanks!
MINI H1 6.0 - CAR LED TAILS
 Old 03-11-2014, 06:57 PM   #2
Actually I'm thinking it's closer to 2" now.
 Old 03-11-2014, 07:00 PM   #3
Fjager's Avatar
Posts: 246   (View Stats)
Fjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the worldFjager is the leader of the world
you mean the outlet from the compressor side, yes it's 2 inches OD.
2013 White Pearl MS3
JBR SSP/bushings/RMM/EGR delete
Corksport 3ID Intake/Radiator
Cobb APV3/AT Internals
Grimmspeed 3 port EBCS/Matt Damond CC
FMIC W/DIY Sprayer
CPE DP
Fjager is offline   Reply With Quote
The Following User Says Thank You to Fjager For This Useful Post:
dale_gribble (03-11-2014)
 Old 03-11-2014, 07:02 PM   #4
FWIW, stock and aftermarket boost tubes are 2 and 1/8" ID on the cold side.
 Old 03-11-2014, 07:27 PM   #5
Awesome. I'm going to build a custom ebcs mount that will install aftermarket 3-ports in stock k04 ebcs location on BTs.
It's a great spot and I'll be able to keep vacuum lines very short like stock.
Fjager (03-11-2014), jdmage_mx5 (03-11-2014)
 Old 03-11-2014, 08:56 PM   #6
Posts: 2,235   (View Stats)
k04
smallest part for the tube install is 2.125''
The edge to prevent the tube to slide out under boost is 2.2''
where the tube end larger parts (stopper) is 2.43''
if you want the effect of reduced vaccuum line you could remove the turbo pill from the turbo and just install it inside a vaccuum tube closer to the solenoid...
I'm curious if you had run a solenoid on k04, can you expect better results from the stock k04 with a 3port sol ?
 Old 03-11-2014, 09:11 PM   #7
I'm not making this mount for the k04; I'm focused on making it for my soon to be installed BNRS3. I just happened to know the neck sizes are probably about the same between the two. A lot of guys put their ECBSs on the battery box or firewall, requiring longer runs of vacuum line.
I don't think the stock 2 port EBCS has much of an issue managing the k04 so I doubt a 3 port would do much for it IMO.
ItsNox likes this.
ItsNox (03-13-2014)
 Old 03-11-2014, 10:58 PM   #8
i was just wondering because i already replaced the k04 and i don't want to put it back just for fun to see if i could get more out of it
Just playing with the rod lenght on my new gt28 make a big difference and the pill size was a pita to set but i'm still with the oem sol. on the garrett. some here seem to find more use of their k04 than i could expect to be possible so i was wondering if the sol. could be a clue...I have ordered one 3ports, i will see what it could do for my gt28
Head and Neck Restraints Twofer Auto-X / Road Racing / Time Attack 12 05-16-2013 11:52 AM
Injection Marks on Jackson's Neck Haltech Celeberty Smut 0 07-10-2009 10:10 AM
Dell Outlet Coupon Code 15% off Refurb Inspiron Laptops $599+ (starting at $509.15) at Dell Outlet Haltech Hot Deals Section 0 04-12-2008 02:50 AM
Dell Outlet Coupon Code 15% off Refurb Inspiron Desktops (starting at $237.15) at Dell Outlet Haltech Hot Deals Section 0 04-12-2008 02:50 AM
Page generated in 0.28153 seconds with 23 queries
