![]() Join Date: Aug 2018
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Update: so I went and put in 4 new plugs looked like they haven’t been changed in a long while cylinder 1 looked the worst gapped them to .30 iridium plugs also cleaned the MAF sensor when I did the intake drive about 60 miles today and never had that problem come back even after the car sat for a couple hours and was cold which is when I was noticing it the most so hopefully that’s another problem solved thanks for the help! A follow up question however noticed two things first thing was I noticed that the most boost I get is around 14.5-15 but the tune says target is 16.5 is that normal for stage 1+ tune with a cai or should I be looking for something like a small boost leak? Also realized there was some oil on the cold side of the inter cooler not tons of oil but there was enough that I could see it inside the coupling to the throttle body...once again is that normal from an older car or should I be saving to get the turbo rebuilt? Thanks any advice would be appreciated! |
| The Following User Says Thank You to jtimms6 For This Useful Post: | Db09ms3 (08-31-2018) |
| A weird end to a weird F1 season | 2016 Abu Dhabi Grand Prix recap | Haltech | Automotive News | 0 | 11-28-2016 07:30 AM |
| Bucking off-throttle | Speed2006 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 2 | 07-30-2015 07:17 PM |
| Car is bucking | JAGspeed6 | MazdaSpeed 3/6 - ECU Computer Tuning | 11 | 11-17-2013 03:58 PM |
| car bucking after 5000rpm | Rich990 | 2010 MS3 - ECU Computer Tuning | 16 | 11-07-2012 10:42 AM |
| Car bucking/jerking with ECT less than 140* | bmylez | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 11 | 03-13-2012 10:14 AM |
