![]() Join Date: Apr 2010 Location: Elizabeth /NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,623
(Thread Starter) | Not Ranked : 0 score I have spoke to guys at CFM today about making Adjustable Camshaft Gears for are motor and there answer was we need a 100 people to buy in to it. They current make this Adjustable Camshaft Gears for the MZR N/A motors and Duratec motors Now what the advantage Factory camshaft timing differ between engines causing performance to vary. Machining differences in aftermarket camshafts and variances between installations will also cause performance to vary. CFM Performance adjustable cam gears allow optimization of camshaft timing to maximize engine performance. They can also be used to shift the engine's power band to different RPM ranges to meet different driving needs. They feature billet aluminum slides which are anodized black, precision cut steel ring gears, and six bolts for positive position retention. The slides are machined every two degrees for a total of +/- 10 degrees of adjustment. |
| The Following 7 Users Say Thank You to SPEED6 KILLAH For This Useful Post: | BobtailedSnail (02-08-2012), i8urgti (02-09-2012), Ingle (02-09-2012), kmac (02-12-2012), NJSPEED3 (02-09-2012), rfinkle2 (02-09-2012), TexasSpeed3 (02-10-2012) |
![]() Join Date: Apr 2011 Location: Millsboro, De
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,597
| Not Ranked : 0 score What would their average price be? and Is there any difference with the CDFP? Also I'm guessing this does away with the VVT??
__________________ 2006 Mazdaspeed 6 GT-unDISI swap in progress 1969 Nova-540BBC-S400's-TH400-sitting on 29.5x10.5 Skreets be calling... [SIGPIC][/SIGPIC] |
(Thread Starter) | Not Ranked : 0 score The average price would be $250.00. CDFP will still be working the same. Yes the take way your vvt. But you will also able to adj you exhaust side with this cam gears too. |
| The Following User Says Thank You to SPEED6 KILLAH For This Useful Post: | rfinkle2 (02-09-2012) |
| Not Ranked : 0 score Sounds pretty awesome to me. I'm not well versed on our VVT system, but what would the drawback be to this? No matter how larger or small the disadvantage.
| Not Ranked : 0 score There is no point to have an adjustable cam gear on the intake cam because you already have an adjustable one not just that but control over it while driving. |
(Thread Starter) | Not Ranked : 0 score Yes you do have a point we do have a vvt on the intake side and it already adjustable now what about the exhaust side ? Last time I check we don't have a vvt there. Plush you will always have that constant powerband around. |
| Not Ranked : 0 score That's what I needed to hear. I was sort of confused at to why we needed this when we have VVT but that's only on the intake. Would we still keep the VVT and just have an adjustable exhaust cam gear or would the whole system have to be replaced?
| Not Ranked : 0 score i would say exhaust cam only this would be a decent idea but we could benefit from new cams much more then a cam gear. i like where your head is at pablo! keep these ideas coming!
| The Following 3 Users Say Thank You to superskaterxes For This Useful Post: |
Now as for cams I'm currently working on something that you guys will really like. But that another soon to come thread. | |
| Not Ranked : 0 score Yeah he's got a couple awesome threads floating around here.
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 1135 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 977
| Not Ranked : 0 score I dont think these are necessary at all. If you want to adjust the exhaust cam phasing just loosen of the center bolt of the exhaust cam gear, rotate the cam and tighten back up. All you would need to do is get the back side of the stock gear etched with the degree markers. They would have to be etched 360 degrees around the sprocket and the cam would need just one mark. This way after you time your motor, you can dial in the amount of advance/retard is in the cam. Aside from having to do it, I don't think its totally necessary. Most cars havew the VVT on the intake cam and that is where it is useful. I doubt there would be little gains if any playing with the cam phasing of the exhaust cam. It's not like we have NA motors and we are trying to squeeze every last HP ou of them like some Honda motors. I would say if you want to push the limits of the platform, money will be well spent and your best return on investment will be in fuel control, and fuel management. A reliable port injection setup or further advancements in the current DI setup should be where most of us are concerned at this point.
__________________ Fueled by the haters. |
One thing the VVT does do well is help to spool the larger turbos, but from the intake aspect... as discussed, I'm not sure what the exhaust phasing would result in. | |
Groans: 433
| Not Ranked : 0 score @SPEED6 KILLAH Call Unorthodox Racing, they're up in NY, might be willing to do it for less guaranteed sets
| The Following 3 Users Say Thank You to Chimmike For This Useful Post: |
Groans: 793
We have a VVT that shits the fucking bed right around 50k. So I agree. This is a great idea.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals | |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score ahem ... DCR .... PTP both have bullet proof VVT |
| Tripple OG ![]() Join Date: Dec 2008 Location: North Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,643
Groans: 113
| Not Ranked : 0 score Ohh you mean real cams and not some bullshit regrind job? awesome cant wait to hear... |
| Not Ranked : 0 score Just upgrade if you have VVT problems. If you feel like it is a lack luster system try driving around without it, just unplug the solenoid and see what happens. This should give you a test to determine if you want to lose it for cam gears with fixed positioning. My money is on you wont go more than one wot pull without plugging the solenoid back in. The gains VVT offers are incredible and only get better with bigger cams trust me I know this one for a fact. |
Groans: 793
| Not Ranked : 0 score I've already ordered the dcr. Well, trying anyway. They haven't returned my last couple emails.
![]() Join Date: Jul 2010
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19
Groaned at 22 Times in 15 Posts
| Not Ranked : 0 score word. cams and injectors |
| Not Ranked : 0 score Exhaust cam phasing is for ricers that want something bling on their exhaust cam. Exhaust is pushed out of the cyl by the piston so it doesnt need much to keep up with the intake side. The only thing that really helps the exhaust side is larger valves, head porting, or longer duration/ bigger lift cams and adjustable cam spockets dont help with that. The intake side is a different animal, air is being pulled into the cyl by the piston or its being pushed in by the turbo. When it is being pulled into the cyl the intake cam phasing is critical because you want the max cam lift to be slightly after tdc and extend as close to bdc as possible. When air is being pushed into the cyl around the 20psi that alot of us run, I dont know that it makes a hill of beans worth of difference what the cam phasing is. Since we have a vvt, we really dont need a non adjustable cam gear, its pretty low tech compaired to what we have.
![]() Join Date: Sep 2011 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
Groaned at 16 Times in 7 Posts
Variable exhaust timing is for emissions. It can be used for an "EGR effect" eliminating the need for an EGR system. An adjustable exhaust sprocket would be pointless. Also guys, there's nothing wrong with the Mazda VVT...it's a revised part and doesn't have the failure problem anymore. | |
| The Following User Says Thank You to timjs For This Useful Post: | Tokay444 (02-10-2012) |
Groans: 433
| Not Ranked : 0 score Also, the stock VVT has been fixed. Still don't know why people still think the new oem vvt actuator shits the bed. It's pretty much 2007-earlier VVT's, maybe a couple 2008's.
Groans: 793
| Not Ranked : 0 score I hope you're right, because Darrel Cox Racing doesn't like to answer emails more than once a week, and even when they do, it's doesn't include answers to the perdinent questions I posses about buying one. You'd think if someone shows interest in your product, you'd bend over backwards to sell it to them.
![]() | | #24 | ![]() |
Groans: 793
| Not Ranked : 0 score Thanks. But it's still 100 bucks more than the dcr.
![]() | | #25 | ![]() |
| Not Ranked : 0 score I was referring to anyone who has an updated VVT already and is thinking of "upgrading" to an aftermarket one. |
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score Of course the dcr and PTP will work because no one have try to rev over 8k |
![]() | | #27 | ![]() |
| Not Ranked : 0 score What exactly is holding us back from revving higher? I know we have a long stroke but that can't be the majority of the reason.
![]() | | #28 | ![]() |
Groans: 793
| Not Ranked : 0 score Valve float.
![]() | | #29 | ![]() |
Groans: 239
| Not Ranked : 0 score lol why is this in the 3 section, should it not concern both?
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
![]() | | #30 | ![]() |
Groans: 113
| Not Ranked : 0 score move it |
![]() | | #31 | ![]() |
| Not Ranked : 0 score for higher power fuel runs out for you guys as well at higher Rpm's. The stroke isn't that much of an issue, for something like 8,000Rpms. Could possibly push it to 8,500 Rpm's without to much special modding. I wouldn't push these engines to 9,000Rpm though. I do know of some race teams pushing the bottom end with upgraded internals obviously to 14,500RPM but that is a full race engine worth more than these cars fully loaded off the showroom floor. |
![]() | | #32 | ![]() |
Groans: 239
| Not Ranked : 0 score moved
![]() | | #33 | ![]() |
| Not Ranked : 0 score you nvr know. this may be a really big area we should try to get to.. |
![]() | | #34 | ![]() |
| Not Ranked : 0 score Our stroke is too long for high rpm use, 8000 rpm is really high for the street. Also our tb, head, and cams choke for high rpm use. Our injectors cant support much at those rpms, and our trans syncros have a tough time shifting that high.
| Broke a piece off of my CAMSHAFT!!! | RiceBurn2.3T | CX-7 > Engine, Transmission & Driveline | 19 | 08-14-2011 08:01 PM |
| Does anyone know where to find the Camshaft position sensor!!! | gt5 | MazdaSpeed 6 - Engine, Transmission & Driveline | 9 | 02-28-2010 07:36 PM |
| Camshaft Position Sensor Retarding | dukebrown | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 08-01-2009 01:06 AM |
