![]() Join Date: Jul 2019
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Thanks |
Rep Power: 3745 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| In all seriousness, if you cannot find your car's throttle body, you probably shouldn't be trying to clean it.
| Not Ranked : 0 score i agree with the above and if you are chasing a car problem, you won,t solve it for cheap by cleaning your throttle.... more chances that you make it even worst.
| The Following User Says Thank You to Jeff23spl For This Useful Post: | MSMS3 (07-08-2019) |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Why do you want to clean it? FYI just follow the output side hose from the intercooler. It attaches to the throttle body. If you are not throwing a code, I suggest you leave it alone.
(Thread Starter) | Not Ranked : 0 score General PM...not my car, so I'm not familiar with it....with attitudes like this I'm glad I don't have to deal with this forum. Porsche and Lexus are much more civilized. But you do get what you pay for. |
| The Following 2 Users Say NO Thank You to shmelvin For This Un-useful Post: | Bertospeed3 (07-08-2019), MSMS3 (07-08-2019) |
"In all seriousness, if you cannot find your car's throttle body, you probably shouldn't be trying to clean it." It doesn't matter that you're not familiar with the car. If you can't look at an engine, find the intake tract, and discern which bit of it is the throttle body, then you shouldn't be working on the car. Moreover, your evident lack of automotive/mechanical knowledge also suggests that you don't understand for what, if any, reason the throttle body might need cleaning. This makes me (and I'm sure, others here as well) question what you might do in any attempt to clean a car's throttle body; whether you would use an appropriate solvent, whether you would properly protect the engine while cleaning and afterwards, and so forth. Again, it doesn't sound like you should be touching the car at all, much less dismantling part of the sensor and actuator suite controlling the engine.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! Last edited by Vansquish; 07-08-2019 at 10:38 AM. | |
| The Following User Says Thank You to Vansquish For This Useful Post: | MSMS3 (07-08-2019) |
| Not Ranked : 0 score well, before blaming us, just step back and think about your question... We gave polite advice to save you further problems. If peoples from Porsche or Lexus aren,t doing it, i.m glad to be part of a better forum. you dont need to be a full time mechanic to work on a car but i have seen so much wrong being done by peoples attempting to work by themselves that i had no choice to warn you. even on youtube there is a lot of wrong videos and advices.... in a logic order of difficulty and risks, figuring where is the tb would be few steps easier than being able to clean it....it would probably take less time to figuring out where it is on an unknown engine than it would take to register to a forum and ask... we also felt free to ask you why you wanna do it, because there is some sayings about cleaning a tb to solve any problems when it often don,t do much and could mess the learning curve of the ecu....all this if you don,t break anything while doing it.
| The Following 3 Users Say Thank You to Jeff23spl For This Useful Post: |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score Relax, your porsche is only worth 18 grand.
__________________ 94 M MS6 IS350 |
![]() Join Date: May 2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
here ya go... | |
We don't have throttle body problems on this engine. Very low occurrence rate, at least not without throwing a CEL code. The guys here are seriously, deeply into pushing the limits of these cars. The knowledge base about these cars is the most robust on the planet. There is, however, a tendency to look askance at someone who does not know where to locate the throttle body on a modern engine of any make or model. That would cause one to pause about the degree of "grease under the fingernails" experience of someone wanting to service the throttle body. It does not help your cause to start throwing around other forums of supposedly more civilized user groups. FWIW, I do currently drive a bought new by me '17 low 12 second Audi, but that does not make me better than anyone else. The Audi user groups I participate in are no different that this one in terms of alleged "civility." You asked for help, receive it, didn't like the "way" we provide the help, and then engage in ad hominem attacks on us. And somehow, we are the problem? Sounds like you've been consuming "snowflake" pills. I am sorry that I may have offended your delicate sensibilities.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 07-08-2019 at 01:03 PM. | |
| The Following 3 Users Say Thank You to MSMS3 For This Useful Post: |
![]() Join Date: Aug 2013
| Not Ranked : 0 score I came across this thread as I am having issues with my 2007 MS3 taking a long time to start (3-7 secs). After checking the battery the two most common solutions are cleaning the erg and throttle body. This thread wasn't quite what I was looking for, but valuable nonetheless. As someone put it, I don't have a lot of grease under my nails, so I take it that this is not something a novice mechanic should take on? |
| Not Ranked : 0 score I changed them 6 months ago, ~4k miles. |
![]() Join Date: Nov 2016 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 549
Groans: 105
| Not Ranked : 0 score What was the gape?
__________________ Stockish |
| Not Ranked : 0 score With what plugs and at what gap? Might not be your problem, but it matters for many issues, including hard starting. When diagnosing a problem start with the obvious and simple and work to the less likely and complex. You have either weak spark or improper fueling. Does it run fine, including pedal to the floor to redline once it starts, or do you encounter any misfires or other problems when the engine is under load?
| Not Ranked : 0 score Seems to run fine other than the starting, but I haven't pushed it too hard recently. I installed NGK LASER IRIDIUM Spark Plug ILTR6A-8G with a .028 gap. |
Next question: Is the hard starting only on a cold engine, or is this even when restarting a fully warmed up engine?
| Not Ranked : 0 score Definitely not just when it is cold. I haven't done any systematic testing to this point. It is intermittent and has happened when cold and warm (sitting for an hour or two). I don't think it has done it when I restart after a few minutes. |
| Opening Throttle Body to Clean Actuator | stokes620 | MazdaSpeed 3 - Engine, Transmission & Driveline | 12 | 08-17-2015 05:21 PM |
| anybody here clean their throttle body? | steven88 | MazdaSpeed 3 - Engine, Transmission & Driveline | 14 | 07-19-2009 06:14 PM |
