 Old 02-23-2014, 02:19 PM   #1
2006MS6's Avatar
Posts: 271   (View Stats)
2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of2006MS6 has much to be proud of
Groaned at 8 Times in 5 Posts
Default Cleaned valves, throwing codes
Went out to the fl mayor install meet yesterday and cleaned my intake valves. Got it all back together, and started heading home (a little Over an hour) and my cel and traction control light came on. Codes are p0108, p0097 and p2178. I did do some searching and found out in general what it was, but no sure way to solve the problem. I did go out and check the connectors and didn't see anything off hand. I did unplug the maf and blowing out to be safe, but nothing changed. Any help would be appreciated.
What it's doing is that when you let off the gas and re apply it, there is a huge delay from when you press the pedal to when you feel the car catch. Like it's bogging really bad. Rpms also seem to rise quite slow as well :/
06' Speed6
Cobb SRI | Eibach Pro Kit | JBR SSP | JBR RMM
Last edited by 2006MS6; 02-23-2014 at 02:19 PM. Reason: MSF Database - Automerged Doublepost
2006MS6 is offline   Reply With Quote
 Old 02-23-2014, 02:49 PM   #2
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Your intake manifold is probably leaking somewhere. Did you re-use the gasket? Clean the mating surfaces? Ensure all sensors, vac lines, purge valve etc. are all connected?
 Old 02-23-2014, 02:50 PM   #3
r3d
r3d's Avatar
Posts: 182   (View Stats)
r3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond repute
I think one of the sensors in the manifold got fucked, when you were cleaning it with b12 plus some rain water))
Building it from ground up:
r3d is offline   Reply With Quote
The Following User Says Thank You to r3d For This Useful Post:
Agent_Orange (02-23-2014)
 Old 02-23-2014, 02:52 PM   #4
2006MS6's Avatar
Yes we reused the gasket. I wish there was a way to pinpoint where the issue is, without just going in the and replacing things lol.
06' Speed6
 Old 02-23-2014, 02:53 PM   #5
2006MS6's Avatar
Yea unfortunately I was cleaning the intake mani with b12 and it did happen to rain in it lol
06' Speed6
 Old 02-23-2014, 04:26 PM   #6
2006MS6's Avatar
Don't mean to sound like a retard, but what coulda happened?
06' Speed6
 Old 02-23-2014, 02:53 PM   #7
Groans: 665
Including details such as these might help.
btstarcher (02-23-2014)
 Old 02-23-2014, 04:56 PM   #8
Boostin'likeAboss's Avatar
Posts: 1,792   (View Stats)
I would start off by checking that all your sensors are plugged in correctly
08 cwp ms3
 Old 02-23-2014, 05:12 PM   #9
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
You have a leak somewhere as agent said 2178 if a too lean or rich at issue
Idle, I d ont remember which most likely lean
Also it is bogging because the leak is so bad the car is compensating so much fuel that it's going to make the car run like shit as it has to over compensate
 Old 02-23-2014, 05:17 PM   #10
Groans: 665
Start simple. Check the MAP sensor and ensure everything is plugged in and tight on and around the IM. If that doesn't work, pull the mani back off and check the gasket and mating surfaces.
ItsNox (02-24-2014)
 Old 02-23-2014, 05:51 PM   #11
2006MS6's Avatar
Ok I'll check all this stuff out. I don't daily the car so it's not a huge issue. I just don't want it to permanently mess anything up
06' Speed6
 Old 02-24-2014, 12:27 AM   #12
Big Dog's Avatar
Posts: 730   (View Stats)
Big Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the worldBig Dog is the leader of the world
Groans: 89
Groaned at 9 Times in 9 Posts
Although some say you can reuse it, the gasket should be replaced as a CYA. I'll bet you're running lean. Check over your intake system. Maybe when you put it back on a coupler wasn't seated right and has slipped off. Stranger shit has happened.
Big Dog is offline   Reply With Quote
 Old 02-24-2014, 11:12 AM   #13
quad4svtspeed6's Avatar
Posts: 82   (View Stats)
quad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond reputequad4svtspeed6 has a reputation beyond repute
May be far fetched, but check the connection to the throttle body..since its drive by wire and it controls part of the traction control system, could possible be an issue, leaky gasket should not light up tcs.
Current Mods>>>>>CPE-Nano..CPE TMIC...TIP....Ebay Test Pipe...Forge V1 BPV...ITV22 Plugs....HyPeRtEcH TuNe
quad4svtspeed6 is offline   Reply With Quote
 Old 02-26-2014, 03:55 PM   #14
2006MS6's Avatar
So I'm a fucking retard and forgot to plug the MAP sensor back in lol
06' Speed6
 Old 02-26-2014, 04:05 PM   #15
Big Dog's Avatar
Groans: 89
It can happen to the best of us.
 Old 02-27-2014, 12:26 AM   #16
Hargarbl's Avatar
Posts: 642   (View Stats)
Groans: 51
This my me giggle like a fool, mainly cause it reminded me of basically the same stupid mistake I made. When I had my sentra spec-v I put an intake on it and for about a week I couldn't figure out why my cel was on and the car was running like crap, turns out I forgot to plug the maf in when I installed it. After that any chance my friends would get they would go in and unplug it when I wasn't paying attention.
 Old 03-02-2014, 05:50 AM   #17
2006MS6's Avatar
It's still sputtering and bogging a little in low rpms, but the tip needs to be replaced. One of the little nipples on the back by the turbo broke off, so there's a leak. Do you think that would cause this issue?
06' Speed6
Cleaned my intake valves polysynth MazdaSpeed 3 - Engine, Transmission & Driveline 154 08-01-2013 07:42 AM
Cleaned my intake valves at 40K miles [R]usty Gen2 MS3 General Discussion 46 06-26-2013 06:18 PM
cleaned valves and egr car won't start tddvrrn MazdaSpeed 3/6 - Troubleshoot/Diagnostics 49 06-18-2012 08:15 AM
cleaned valves and egr car won't start tddvrrn MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 06-16-2012 05:03 PM
Page generated in 0.36934 seconds with 27 queries
