 Old 10-04-2017, 12:14 PM   #1
1324Kyle's Avatar
Posts: 58   (View Stats)
1324Kyle is on a distinguished road
Groaned at 8 Times in 5 Posts
Default Cluth Petal Sticks
Hi Everyone,
I have a 07 Mazdaspeed3 and it has been driving completely fine till I ripped it home yesterday and attempted to start her later in the day. My clutch petal will stay in whatever position I put it in, till I flip it back with my hand manually. Yesterday I ended up having to roll my car back in my driveway a little and saw that it's clearly leaking something, therefore I would be surprised if they aren't related.
I'm planning on lifting her up today and try to figure this out.
Anyone have any previous experience with a situation like this? If so, any information would be greatly appreciated, like where I should be looking or really anything!
Thanks,
Kyle
UPDATE:
I found the leak, but I'm not sure what this is so please help me identify this part!
This video is when the clutch is in the normal depressed position
https://youtu.be/Y4ymB9EtMb0
This video is when the clutch is in the stuck to the floor position
https://youtu.be/yBnDKOZ4Css
I assume all I need is a new one of these things and some more fluid, but if I'm wrong please let me know!
1324Kyle is offline   Reply With Quote
 Old 10-04-2017, 01:23 PM   #2
pwdunmore's Avatar
Posts: 368   (View Stats)
You need a new clutch slave cylinder. Cheap and fairly easy to fix.
My car thread:
The Following User Says Thank You to pwdunmore For This Useful Post:
1324Kyle (10-04-2017)
 Old 10-05-2017, 10:20 AM   #3
1324Kyle's Avatar
Thank you for the quick reply, I just received my new one in the mail, I'm going to attempt to replace it soon. This may be a stupid question, but what fluid do I need to fill? I lost a good amount to driveway and assume I will loose even more when I try to replace the part.
Thanks
 Old 10-05-2017, 10:48 AM   #4
1324Kyle's Avatar
I'm going to replace it now but am having a difficult time finding instructions on how to replace it. Can I simply let the fluid leak out into a bucket when i take the part off, put the new one on and replace the missing brake fluid?
 Old 10-05-2017, 10:59 AM   #5
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
Dot 3 brake fluid.
Remove a clip located on the pipe seal where it goes into the old slave cyl.
Pull the hydraulic line out of the old slave. Unbolt the old one. Fill the new one up with fluid.
Bolt the new one in and simply insert the hydraulic line into the new slave. It should snap in.
Fill the brake reservoir to the top and start bleeding the system. The bleed valve is on the slave it self. You tube how to bleed brakes. Dont get any on the paint.
Its fun... brake fluid is lots of fun.
After you have brake fluid all over your hands use powdered clorine pool tabs to clean it off.....
MECP
2012 BM
Rfinkle tune in progress
The Following User Says Thank You to 5doorsoffury For This Useful Post:
1324Kyle (10-05-2017)
 Old 10-05-2017, 11:01 AM   #6
1324Kyle's Avatar
Dot 3 brake fluid.
Thank you very much, you have been very helpful!
 Old 10-05-2017, 12:34 PM   #7
Jonb82's Avatar
Posts: 416   (View Stats)
Boom!
Sent while probably pooping
 Old 10-05-2017, 01:11 PM   #8
1324Kyle's Avatar
I know this is a stupid question but where am i suppose to fill the new one and how much fluid should i put in there?
https://imgur.com/a/Fy6aS
 Old 10-05-2017, 02:25 PM   #9
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
The brakes and clutch share the same reservoir. The clutch fluid is contained in the rear of the reservoir. Just bleed and check often.
You don't "need" a SS clutch line. Its nice to have if you're running a heavier pressure plate vs. stock. An oem line is fine. If yours looks ok I wouldn't sweat it.
 Old 10-05-2017, 02:07 PM   #10
leo766's Avatar
Posts: 300   (View Stats)
leo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond repute
Groaned at 93 Times in 33 Posts
i strongly advise getting a 20$ endoscope from amazon for cell/tablet/pc and using it to see the slave cyl movement when this occurs, also if u got for new slave, plz do urself a favor and make sure u get a ss clutch line, their 25$ and u will save urself the intermitted sticking from hot days letting the line ballon up, besides tht i would check to see if u can stick the endoscope past the rubber clutch fork boot and make sure nothing funky is happening in there that stops the pedal being properly pushed back up... i have had this issue come and go forever, i actually have a line i want to install, i just got good at pulling the pedal up from under it with my foot when it occurs cuz it isnt too these days heh... i wish you luck, if i change the line and this still happens, i am going to be completely mindblown heh
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
 Old 10-05-2017, 04:29 PM   #11
shamie's Avatar
Posts: 952   (View Stats)
Make sure you get the little rubber nipple out of the old slave. The nipple comes with the line not the slave.
If your slave pops again and you haven't fucked up the plunger gasket you can reassemble it but it'll mean you're probably due for a clutch release/throw-out bearing (and a new clutch while you're in there).
2010 MS3 Cluth Engagement Really High sh4d0w 2010 MS3 - Troubleshoot/Diagnostics 14 09-08-2015 11:56 AM
Despite slow sales, Ghosn sticks with EVs Haltech Automotive News 0 04-08-2012 10:40 PM
BT and Dip sticks, is there a fix? crazyp MazdaSpeed 3/6 - Troubleshoot/Diagnostics 42 01-31-2012 05:45 PM
Torque Sticks Kick in the Box MazdaSpeed 3/6 - Wheels & Tires 8 04-15-2010 03:43 PM
My clutch petal tends to vibrate under certain conditions MATT DAMOND MazdaSpeed 6 - Engine, Transmission & Driveline 9 01-19-2010 03:06 PM
Page generated in 0.32308 seconds with 26 queries
