12Likes ![]() |
![]() Join Date: Apr 2019 Location: San Francisco
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score I am not looking to do any other mods besides the intake, maybe a Rear Motor Mount if necessary with the intake. Thoughts? Thanks in advance! |
![]() Join Date: Apr 2016 Location: TRACY CA
| Not Ranked : 0 score No a tune is not required unless you're going to a 3.0 or 3.5 in intake Sent from my Moto Z (2) using Tapatalk If you plan on modding it alot more. Next thing you should buy is hpfp internals then a accessport Sent from my Moto Z (2) using Tapatalk Last edited by Wcdfmt510; 05-31-2019 at 05:29 PM. Reason: MSF Database - Automerged Doublepost |
(Thread Starter) | Not Ranked : 0 score Man thank you so much for the quick response. I want to keep the car as reliable as possible but want to add the intake to get a little more turbo noise. Do you recommend a rear motor mount or anything else among getting the cobb intake? I do not want to get it if i am going to have to buy other mods or run into problems down the road. |
| Not Ranked : 0 score Imo buy the damond Motorsports mount.. best out there. . You will be fine with the intake without having to do the hpfp or accessport.. Sent from my Moto Z (2) using Tapatalk If you get the Cobb intake. Get the one with the turbo inlet pipe to Sent from my Moto Z (2) using Tapatalk Last edited by Wcdfmt510; 05-31-2019 at 05:49 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Jun 2009
I disagree regarding turbo inlet pipe. No power gain. Zero performance gain. Wasted money except for making juvenile noise. A good rear motor mount is a solid investment. There are many threads here about the choices. Choose one of the former than stock, but not really hard centered ones, or you will have noticeable cabin vibrations at idle, especially if the a/c is on and pulling idle rpm down. Look for the center to be made of 70 dura stiffness. 80 will produce a lot of shaking at idle on stock idle rpm. 60 is too soft. The official “sticky” on motor mounts (always begin by reading the stickies): The Motor Mount Thread Be sure to read the first page and the last, if you don’t want to go through all 9 pages, although they are excellent.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 06-02-2019 at 06:56 AM. | |
| Not Ranked : 0 score So what's the point of having a better flowing intake if your gonna leave the plastic OEM poorly shaped inlet pipe on it? Sent from my Moto Z (2) using Tapatalk |
| The Following User Says NO Thank You to Wcdfmt510 For This Un-useful Post: | MSMS3 (06-02-2019) |
Also, i have found a used cobb intake and turbo inlet pipe, $200 for both, should i go for this? Or should i just get a brand new intake without the inlet. And i will definitely check out the thread for the motor mounts, thanks again. | |
I'm unsure if you saw my response the other person responding, but i found a used cobb intake and inlet for $200. Should i go for it or buy new? He said he put around 20k on it, but bought it used himself as well. Thanks in advance, i appreciate the inputs. | |
| Not Ranked : 0 score Personally I would just get the intake with the inlet pipe. Not gonna loose any reliability.. there might be little to no performance gains, but it will help air flow and turbulence in the intake track Sent from my Moto Z (2) using Tapatalk |
Hook a fire hose up to it and it will still flow no better than the turbo can. Weird pancake shape notwithstanding, it flows quite well on the stock turbo. That’s why. Except it doesn’t. Doubt me, show me the proof.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 06-02-2019 at 02:23 PM. Reason: MSF Database - Automerged Doublepost | |
| Neutral : +1 score They are designed to have optimum flow at 15psi for stock levels. Now when up up the boos to 20-21, about Max for the ko4 then it be like a bottle neck. My car didn't like stock inlet pipe at 20psi Sent from my Moto Z (2) using Tapatalk |
I ran 17-18 psi tune at 4,000 with taper to 14 at 6,000 and maxed out the turbo at 300/310 whp at 17-18 degrees of timing up top, with the stock TIP, 3” catless dp/rp, upgraded pump internals and Mazdaspeed/AEM CAI. Do you have a data log or dyno pull? I’d love to compare.
__________________ 2017 Audi Q5 3.0 T (supercharged) Stage 2+ EPL tune, JHM overdrive crank pulley, EPL supercharger pulley, ZF8 TCU tune, aFe/034 intake, modified air box. 480 hp. Sunlight Silver '08 MS3 GT Mods: (Sold 1/25/2019 after 10+ years of ownership) BNR Stage 1 (to fix smoking K04 turbo), TurboXS 3" Catless DP/RP "Stealthback" into stock CBE, Vibrant 3 inch Ultra Quiet Resonator in RP section, Magnaflow 3 1/2" exhaust tip, Mazdaspeed CAI w/air straightener and K&N conical filter, NGK 6510 Iridium IX one step colder plugs, Hypertech tune, Autotech HPFP internals, Stock BPV (works perfectly), Yokohama Advan Neova AD08R's (stock size on stock rims); Hawk HPS pads; SURE RMM; Grimmspeed EBCS (2 port mode), Bilstein B6's, SPC rear camber arms. Last edited by MSMS3; 06-03-2019 at 12:25 AM. | |
There is no other single power mod that produces more horsepower per dollar on this car than an SRI or CAI. Period. Any intake designed for this car, provided it has the stock MAF housing diameter and has a good high flow conical filter, including Cobb, will be safe.
| Cobb AccessPort on a completely stock 2006 MS6.. worth it? | squale | MazdaSpeed 3/6 - Turbo Induction | 12 | 04-20-2010 03:41 PM |
