 Old 06-13-2019, 11:52 PM   #1
Meeks726's Avatar
Posts: 15   (View Stats)
Meeks726 has a little shameless behaviour in the past
Default Coolant Temp Can't Make Up It's Mind
Hello everyone, fairly new here in the forum and not really sure if I'm in the correct section or not but....
Recently, my CEL came on and read "P0126". My car wasn't fully warming up. Temp would stay at around 140 - 159 ish driving in town or the highway.
After doing some research, I decided to replace the THERMOSTAT.
The first time I replaced the Thermostat, I replaced it with one from AutoZone.
CEL went away but coolant temp were still around 140-159 after letting the car idle and after driving it around town and on the highway.
Since the coolant temps were still 140-159, I figured that maybe it's a faulty Tstat or AutoZone's is just shit. So I bought an OEM one from EdgeAutoSport.
The second time I replaced the Thermostat, I replaced it with an OEM one from EdgeAutoSport. CEL still didn't come back but the coolant temps were still around 140-159.
I let the car idle for about an hour with AC on full blast and then Heater on full blast, coolant temp still didn't go past 159~.
So I decided to take the car out for a drive around town and do some pulls on the highway.
When I got on the highway, I did a 3rd to 4th pull and suddenly, my coolant temp went back to normal after hitting 21psi of boost.... After that pull, my coolant temps were around 175-189 on the highway and 189-217 around town doing stop-and-go.
When I got home, I let the car idle for about 20 mins and the coolant temp stayed at around 210-217 and then I called it a night.
Btw, the fan does come on whenever temp reaches 217 or 219.
The next day, the car started fine and the coolant temps were fine. The car reached operational temp normally. When I got to the highway, I ripped the car again from 3rd to 4th and the coolant temp went back down to 144-159.... then I ripped it again and it went back up to normal... it seems to change back and forth every time I get on it or every time I hit full boost...??
So the car's coolant temp range seem to change whenever I do WOT pulls or hit high boost....???
Anyone have any ideas???
Stage 3 Mazda speed 3 2007
109k miles
Stratified Tune(For now, PD soon)
Cobb Intake
M2 Catless Downpipe
CXRaxing FMIC
TurboSmart Dual Port(full recirc)
Stock Cat back with everything removed except 1 res
RMM, PMM, TMM
And other little shit
Meeks726 is offline   Reply With Quote
 Old 06-14-2019, 05:01 AM   #2
Police - Grammarhead
Vansquish's Avatar
Sounds like you might not have burped the system fully.
 Old 06-14-2019, 01:03 PM   #3
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I would lean more towards an electrical issue. Possibly the sensor or the sensor connection.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
MSMS3 (06-14-2019), Vansquish (06-14-2019)
 Old 06-14-2019, 05:14 PM   #4
Meeks726's Avatar
Okay so I was driving my car today for about 2 hours rippin through gears and coolant temp stayed normal....... BUT CEL P0126 came back on...??
109k miles
Cobb Intake
M2 Catless Downpipe
CXRaxing FMIC
RMM, PMM, TMM
 Old 06-14-2019, 05:21 PM   #5
Fstrnyou's Avatar
Replace temp sensor/switch. A loose connection would cause the temps to swing from actual to max cold/hot instead of just reading inaccurately.
The sensor is probably fairly cheap and I believe it's easy to reach.
Other rides:
History:
 Old 06-14-2019, 05:25 PM   #6
Meeks726's Avatar
Would you be kind enough to direct me to a "How-To: Coolant Temp Sensor"? I can't seem to find it here or youtube
109k miles
Cobb Intake
M2 Catless Downpipe
CXRaxing FMIC
RMM, PMM, TMM
 Old 06-14-2019, 05:30 PM   #7
Fstrnyou's Avatar
I google searched and it was the first link to pop up.
Other rides:
History:
 Old 06-14-2019, 06:19 PM   #8
Posts: 2,826   (View Stats)
Come on, sir. At least try. What terms did you search? We get frustrated looking up stuff for people who should be able to find stuff. Not trying to be a hard ass, but trying to break people from tit sucking and eat real food with a fork, knife and spoon. Search is your utensil.
Db09ms3 (06-14-2019)
 Old 06-14-2019, 06:41 PM   #9
Meeks726's Avatar
Well sir damn I'm sorry
I didn't find a legit "How-To" but I found a thread showing where it's located. I'll give it a try tomorrow. Thanks
109k miles
Cobb Intake
M2 Catless Downpipe
CXRaxing FMIC
RMM, PMM, TMM
Last edited by Meeks726; 06-14-2019 at 06:41 PM. Reason: MSF Database - Automerged Doublepost
Creeping coolant temp CesariniAP MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 05-31-2017 10:28 PM
Coolant temp issues dubunderpar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 25 01-26-2016 07:55 PM
Coolant Temp iammike 2010 MS3 - Engine, Transmission & Driveline 12 09-07-2015 05:11 PM
CX-7 coolant temp high... bzwyatt CX-7 > Issues & Troubleshooting 8 06-14-2011 04:42 AM
Page generated in 0.29432 seconds with 23 queries
