  • 1 Post By Omega
 Old 04-27-2018, 04:10 PM   #1
Mazduhspeed6's Avatar
Posts: 157   (View Stats)
Mazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to allMazduhspeed6 is a name known to all
Default Corksport built Dankai
I am getting ready to replace the trans in the speed6 with a nice used one and the motor in it is still running good, compression test results are never good but it puts power down like crazy.
Anyways I have recently seen Corksport added built Dankai blocks to their repertoire. Anyone have any experiences with this yet, or are they just so new nothing is known, I mean I'd have to imagine there are a few out there already. I have already bought remaned and rebuilt 2x, my next route was just going to be OEM longblock but I'm curious about these motors. I have always used Corksport parts in my Speed6 and I absolutely love them. I currently have their injector seals, ebcs, fuel pump internals and their turbo which I believe their turbo is why the engine in the car still runs like it does because it performs so well it adds enough compression to have it run decent. So anyways I love their parts.
If Corksport is listening or reading and is interested in having a tester or a guinea pig willing to give an honest review upon installing and break in and then updates further down the line I would love to be part of that. I understand things have to be paid for so if there's a discount that could be worked out that'd be great. My main caution is that as far as it seems no one else has one yet or has reviewed it if they do and I don't see anything about their mileage and how well they hold up? Secondly are their blocks prepared with a torqueplate?
2007 Mazda Speed6 GT
Power: rebuilt stock motor*
JBR full power path stage II intake w/JBR TIP*
ATP catted downpipe w/ second cat delete*
Corksport HPFP internals*
Corksport BeCuse injector seals*
Corksport Turbo*
Corksport 3.5 Bar MAP sensor*
Corksport EBCS*
Treadstone Tr8 w/ RPM CX racing piping kit*
Suspension: Corksport Lowering Springs
Brakes: Still stock
Driveline: Sure Motorsports R6*
Sure Motorsports Juggernaut*
Sure Motorsports Dreadnaught*
Sure Motorsports shifter bushings*
Corksport weighted Black shift knob
Electronics: Cobb Accessport V3 w/ tune by Will at PD tuning*Purple Drank Tuning*
Mazduhspeed6 is offline   Reply With Quote
 Old 04-27-2018, 07:44 PM   #2
Omega's Avatar
Posts: 441   (View Stats)
It's a block by a builder who reviews tolerances. Corksport hasn't always had the best quality control due to outside suppliers fuckups but they have amazing customer service and have always been stand up. They have a warranty on their blocks which is awesome, I wouldn't hesitate to go with them.
There's a few out there in the wild people have bought but haven't seen any online forum reviews on their blocks. They do come with their camshafts so you can expect to make more power everywhere.
2006 Super Clean BCM MS6
 Old 04-27-2018, 08:47 PM   #3
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
i'm in the market for a motor, and have many questions but corksport was completely unresponsive to my initial inquiry, maybe you'll have better luck getting info out of them.
with no history of building engines, and an unwillingness to communicate, it's hard to seriously consider them when the bill is $7500-$9000.
94 M
MS6
IS350
 Old 04-29-2018, 08:58 AM   #4
LenSpeed6's Avatar
Posts: 164   (View Stats)
^ Did you try calling on the phone?
I've called twice now to inquire on parts and someone always picked up by the second ring, was very friendly and personable and willing to answer any questions the I had.
06 Speed6
White/Black interior
 Old 04-29-2018, 09:00 AM   #5
Omega's Avatar
I usually email them and have no problem in getting a response in less than 24hrs. Their customer service for me has always been awesome and everyone here will pretty much agree. They're about the only vendor you don't have to fight with to warranty shit, recalls their products if issues are found, etc. without a community upset to make it happen.
LenSpeed6 likes this.
 Old 04-30-2018, 01:29 PM   #6
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Might want to give Jordan Keefover of Overspeed Motorsports in NOLA a call. Lots of guys running his builds and he is top notch. Will not be as expensive as CS, and has a history of solid reliable builds.
There is also EBTEC, and Speed Solutions that are doing great things! Good luck with whoever you choose.
 Old 05-10-2018, 02:43 PM   #7
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
I would suggest that he has a history of standing behind his builds, instead of the history of solids. Shit happens, but how its handled is importanter.
 Old 05-10-2018, 02:33 PM   #8
Joshywahloves's Avatar
Posts: 12   (View Stats)
Joshywahloves has a spectacular aura aboutJoshywahloves has a spectacular aura about
I second Jordan @ Overspeed. Running his oem reman longblock with 10k miles on it and has been nothing but sunshine and daisies!! I bought the longblock 2nd hand from a gentleman that often gets motors rebuilt by Jordan but it hadn't been installed or ran yet and I paid 2600 bucks shipped to my door. Jordan was also really helpful with the break in
Joshywahloves is offline   Reply With Quote
The Following User Says Thank You to Joshywahloves For This Useful Post:
Thor Hammer (05-10-2018)
That Dankai Krystorr Mazdaspeed3/6 General Discussion 55 03-16-2018 07:50 PM
Dankai Engine Builds Luke@corksport CorkSport 1 03-14-2018 10:07 AM
Build my engine or built longblock? Built trans? Mustangkr500 Mazdaspeed3/6 General Discussion 24 07-22-2016 12:17 PM
Page generated in 0.31260 seconds with 26 queries
