![]() | | #201 | ![]() |
![]() Join Date: Dec 2009 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,256
| Not Ranked : 0 score
__________________ PERM'D/FORGED - EFR 7163 Street Sleeper ![]() | |
![]() | | #202 | ![]() |
| Axle Breaker ![]() Join Date: Mar 2008 Location: Rio Rancho, NM
Rep Power: 4000 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,595
Groans: 162
Many people aren't having issues with a proper build either without the need for hokus pokus BS. Ask @Realgib3; how far listening to john got him.
__________________ | |
![]() | | #203 | ![]() |
Just tossing out the idea
![]() | | #204 | ![]() |
Groans: 136
I have not heard of or seen any examples of the cranks walking on our engines.
| The Following 11 Users Say Thank You to silvapain For This Useful Post: | 06Speed6 (02-25-2013), Alpha (02-24-2013), Celestspeed3 (02-24-2013), Dano (02-25-2013), jmhinkle (02-24-2013), ms3blackmica (02-24-2013), phate (02-24-2013), Realgib3 (02-24-2013), SilverDemon (02-24-2013), Tomas (02-25-2013), TWOptSL0W (02-24-2013) |
![]() | | #205 | ![]() |
| Not Ranked : 0 score ^ This. They are called crank straps. You use longer main studs with metal plates under them on each bank for 2 studs each. Common on other engines with weak blocks. IMO not needed at all for us. And besides that, those crank straps aren't going to do anything as far as the crank pulley or the sprockets slipping. I don't think crank flex is the problem. Crank flex leads mostly to main and thrust bearing damage or the crank snapping in half. Not slipping of the crank pulley. Even if our crank where to flex you would have to have really massive amounts of it for the crank pulley to bend itself longitudinally to a degree where the pulley oscillates past the lip seal and rubs on the bore of the cover plate. That should be at least 4-5mm. IMO not possible. The crank would snap in half before it flexes that much. Oh and if the crank really were to flex to that point you should see the lip seal completely torn to shit and I don't think the people who have slipped timing have reported that. I don't think a bent or snapped crank has ever been seen here unless I am mistaken. That drag team with the port injection MZR DISI block doing over 1000 hp does not alter the block or crank at all. I think it's safe to say the block and crank can handle much more than what anyone here is throwing at it. Forget block crete, straps or any other silly thing of that nature.
__________________ Last edited by Tomas; 02-25-2013 at 01:47 PM. |
| The Following 15 Users Say Thank You to Tomas For This Useful Post: | 06Speed6 (02-25-2013), Alpha (02-25-2013), Boosted Beluga (02-25-2013), Celestspeed3 (02-25-2013), Dano (02-25-2013), jmhinkle (02-25-2013), Monotonous ONE (06-10-2013), ms3blackmica (02-25-2013), phate (02-25-2013), silvapain (02-25-2013), SilverDemon (02-25-2013), superskaterxes (02-25-2013), timjs (02-25-2013), Tokay444 (02-25-2013), TWOptSL0W (02-25-2013) |
![]() | | #206 | ![]() |
| Not Ranked : 0 score More info about the ARP crank bolt - The most awaited build in MSF history
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
![]() | | #207 | ![]() |
![]() Join Date: Jun 2008 Location: Bowling Green, Kentucky.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 909
| Not Ranked : 0 score I have crank pulley slip after replacing the chains, VVTA, guides and tensioner. I used all new washers and bolt. I even ordered another crank pulley bolt and washer and had a local shop torque to 73lbs + 90 degrees a 2nd time and I'm still slipping. My question is can I just add more torque or should I get all new washers and an ARP bolt and start over?
__________________ EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14 ____________________________________________Dragon Slayer _________________________________________________ |
![]() | | #208 | ![]() |
Groans: 433
| Not Ranked : 0 score How much boost? What setup? Sent from the depths
![]() | | #209 | ![]() |
![]() Join Date: May 2011 Location: Winston-Salem, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 890
| Not Ranked : 0 score Scott, Jeff told me about the ridiculous tension that the new Dayco belt put on the pulleys. Said the belt tensioner barely moved when he released it. With the constant movement of the pulleys while the engine is running paired with the large amount of tension created by the belt, it MIGHT have something to do with the issue you're seeing. Did you ever discover the cause of your shredded belt? I hate you're having these issues. I'd love to know the solution when you get there.
__________________ I literally drive the wheels off Mazdaspeeds. Come at me, bruh! 2007 Mazdaspeed3 GT Black Mica -~CORN!!! - Corksport PMM, CBE, SRI, & TIP - UR TP - Ebay DP - ETS TMIC - PnP IM - CPE SafeSeals - Autotechs - Forge V1 - NGK IX - Cobb AP, RSB - JBR TIG's + CB, Knob, SSB, & 88a RMM - GT-Spec chassis bracing - Hawk HPS/Stoptech Posiquiet - Technafit Lines - DBA T3 - ATE TYP200 - Moog Endlinks - Koni Yellows - Rota Grids 18x8.5 - Michelin PSS 245/40~- [SIGPIC][/SIGPIC] |
![]() | | #210 | ![]() |
| Not Ranked : 0 score Check if there is a ridge on the two chain sprockets, I have two used ones with ridges where the washer sits on the sprocket and it probably isnt clamping them enough because the sprockets are hitting. Edit: On my motor the 76'lb alone is enough to hold timing.
| The Following User Says Thank You to 06Speed6 For This Useful Post: | phate (06-10-2013) |
![]() | | #211 | ![]() |
| Not Ranked : 0 score 21lbs 20% e-85 320/380 at the wheels. mods in sig.
Thanks, I'll look at the sprockets when and if I have to open it back up. Do you need new sprockets or can the ridges be filed off?
__________________ EBTEC Manley Built // GT3071R // FreekTuned // Freek 3.5" Intake // Ported IM // Perm Plate Dual CC // Catless DP // CNT CB // Tokay V 1's // Autotech // AEM Failsafe // TR8 IC// GFB // JBR 88 RMM // DM PMM // JBR 70 TMM // ACT 6 puck prolite fly // Cobb RSB // 6 pc chassis braced // Koni FSD's // Cobb Springs // EGR Full delete // SWAS switch // SS brake lines // 100% Methanol Injection D14 ____________________________________________Dragon Slayer _________________________________________________ Last edited by 08cosmic3; 06-09-2013 at 08:05 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #212 | ![]() |
| Not Ranked : 0 score I filed mine off very carefully. There wasnt a ridge on the crank or damper pully so those must be a different metal.
![]() | | #213 | ![]() |
Groans: 136
![]() | | #214 | ![]() |
| Not Ranked : 0 score I guess I'm going to order new washers, ARP crank bolt, open it up and try again. I'll be very careful to clean everything and inspect the sprockets for ridges. Thanks for the info and if there is anything else I should look for or consider let me know.
![]() | | #215 | ![]() |
Groans: 793
| Not Ranked : 0 score methanol will help with removing any oil residue left on the sprockets, before reassembly. are you not driving the car right now, or have you reset timing?
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() | | #216 | ![]() |
![]() Join Date: Jul 2009 Location: Sardinia, Ohio
Rep Power: 4725 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,721
| Not Ranked : 0 score One word...... Loctite..... 500+ hp with almost 500 lb ft of torque, no slippage
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. |
![]() | | #217 | ![]() |
Groans: 136
| Not Ranked : 0 score Are you saying you applied Loctite to the crank bolt threads, or to the surfaces of the friction washers?
| The Following User Says Thank You to silvapain For This Useful Post: | SilverDemon (06-10-2013) |
![]() | | #218 | ![]() |
Groans: 793
| Not Ranked : 0 score both i think scott had some face loctite with a very high shear strength for the sprockets. not sure how he'll get them apart if needed.
| The Following 2 Users Say Thank You to Tokay444 For This Useful Post: | Chimmike (06-10-2013), SilverDemon (06-10-2013) |
![]() | | #219 | ![]() |
| Not Ranked : 0 score 680 I believe. Its a retaining compound, not a thread locker, so its used on the faces of everything. Something like 4000psi shear strength. You need a torch for removal I think, but hopefully removal is just never necessary. |
| The Following User Says Thank You to Realgib3 For This Useful Post: | SilverDemon (06-10-2013) |
![]() | | #220 | ![]() |
![]() Join Date: Jul 2011 Location: Fayetteville, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,655
| Not Ranked : 0 score I also used loctite retaining compound lol. sent to you from me We use a bearing puller at work to break thw stuff loose. I dont no if that would work on thw car tho. sent to you from me
__________________ [SIGPIC][/SIGPIC] Last edited by StayBroke; 06-10-2013 at 08:38 AM. Reason: MSF Database - Automerged Doublepost |
| The Following 2 Users Say Thank You to StayBroke For This Useful Post: | Realgib3 (06-10-2013), SilverDemon (06-10-2013) |
![]() | | #221 | ![]() |
I de-greased the washers and all the mating surfaces. Then applied the primer and finally the loctite 680 to faces of all mating parts. I assembled everything with the motor in time with just the old crank bolt putting pressure against the assembly. Let it set up overnight, removed the old crank bolt, installed the timing cover then installed a new bolt and torqued it to the service manual specs. All along checking that the motor is still in time. Yes, a torch (small map gas) will be needed to remove the assembly if I have to take it apart.
__________________ I am my own After Market Company. A common mistake that people make when trying to design something completely idiot proof is to underestimate the ingenuity of a complete idiot. - Douglas Adams Better to remain silent and be thought a fool than to speak out and remove all doubt. - Mark Twain Cops carry guns to protect themselves, not to protect you. READ THIS---- 2nd Amendment A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed. I've learned that pleasing everyone is impossible, but pissing everyone off is a piece of cake. | |
![]() | | #222 | ![]() |
And on another note, I just looked down to thank your post and saw Silvapain, but at a glance it looked like SilverDemon...and I thought you thanked your own post. Wow that was trippy. Maybe I needed to sleep more this weekend. wow. | |
![]() | | #223 | ![]() |
Not to sound like captain obvious but also make sure the friction washers on the cams are between the sprockets/ VVT and the cam shoulder. Not under the bolt.
| The Following 9 Users Say Thank You to Tomas For This Useful Post: | 06Speed6 (06-10-2013), 08cosmic3 (06-10-2013), BigRedSpecial (06-10-2013), Boosted Beluga (06-10-2013), Chimmike (06-10-2013), ms3blackmica (06-10-2013), Realgib3 (06-10-2013), timjs (06-10-2013), Tokay444 (06-10-2013) |
![]() | | #224 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score Fwiw using an arp bolt I just torqued 85 ft lb on crank pulley then 90 and another 45. I don't know how much torque that is but I never want to slip I did basically the same thing two years ago with oem bolt and never had the crank slip and I ran the shit out of my car before turbo took A shit |
![]() | | #225 | ![]() |
Groans: 793
| Not Ranked : 0 score I wouldn't advise that at all.
| The Following 3 Users Say Thank You to Tokay444 For This Useful Post: |
![]() | | #226 | ![]() |
![]() Join Date: Sep 2011 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 360
Groaned at 16 Times in 7 Posts
Not to mention the threads in the crankshaft.
__________________ '06 Mazdaspeed 6 | |
| The Following 3 Users Say Thank You to timjs For This Useful Post: |
![]() | | #227 | ![]() |
| Not Ranked : 0 score That's how I did it before and it worked very well I am just sharing what I did for information purposes. I am not un doing it I will run it like that. There is no real proof of the perfect way to do it other than key the crank which is what I will do next time I take it apart. I'm not looking for approval, simply sharing info and there are other people here who says they did it to 300 ft lb and no body says anything negative like everyone is saying to me now. Take note of what I did for comparison or pretend like I'm a moron and have but done it previously which every it does not matter to me |
![]() | | #228 | ![]() |
Groans: 793
| Not Ranked : 0 score Who torqued to 300lbs?
![]() | | #229 | ![]() |
| 708 ![]() Join Date: May 2008 Location: Maple Valley, WA
Rep Power: 45886 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 21,982
| Not Ranked : 0 score We simply made sure everything was clean and torqued to shop manual specs. It is also important to make sure motion is maintained through both the initial to the torque spec (forget what the actual spec is) and the 90 degree (think it is 90 degree, but again not sure as it has been a while) follow up.
__________________ 2 years after hitting 700hp and still running strong. Happy to see others joining the club. |
![]() | | #230 | ![]() |
Groans: 793
| Not Ranked : 0 score Anyone every slipped timing on a factory motor?
![]() | | #231 | ![]() |
| Not Ranked : 0 score I'm interested in this answer as well. Of all the disi engines I've replaced, (shoot, any of mazdas non-keyed engines for that matter) none slipped timing on their own. All of the head jobs I've done where the timing was off and bent valves, an outside shop had recently did a timing chain replacement. Basically, the factory procedure is very good when done properly.. Personally I don't see the need for changing a thing unless you increases loads on the chain. Springs and cams mainly. Although even an upgraded HPFP or thicker oil are indeed a higher load on the chain but negligible I'm sure.
| The Following 6 Users Say Thank You to timjs For This Useful Post: | Boosted Beluga (11-20-2013), Celestspeed3 (11-20-2013), phate (11-20-2013), Roddiy (11-20-2013), silvapain (11-20-2013), Tokay444 (11-20-2013) |
![]() | | #232 | ![]() |
![]() Join Date: Feb 2011 Location: Vaughan, Ontario, Canada
Rep Power: 1135 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 977
| Not Ranked : 0 score On that topic, I recently ordered a Cosworth dry sump kit, and I needed to make some modifications to the oil pump gear. They told me they no longer key the cranks, that was only done at the beginning when they weren't sure if they could trust the friction washers. There billet cranks I believe are keyed because that's how they were designed.
__________________ Fueled by the haters. |
| The Following 4 Users Say Thank You to Celestspeed3 For This Useful Post: | Boosted Beluga (11-20-2013), Mauro_Penguin (11-22-2013), silvapain (11-20-2013), Tokay444 (11-21-2013) |
![]() | | #233 | ![]() |
| Not Ranked : 0 score I've yet to see proof the crank needs keyed. What I have seen is that the factory setup leave VERY little room for error and if you do mess up even the slightest bit, it will mean the difference between holding timing at 700+whp and holding 50whp. That means keying the crank can eliminate the assembly error which means you'll never slip no matter what. Basically it looks like it's not a necessity but is good for piece of mind. |
| The Following 6 Users Say Thank You to Realgib3 For This Useful Post: | Boosted Beluga (11-20-2013), Downmented (11-23-2013), Mauro_Penguin (11-22-2013), silvapain (11-20-2013), timjs (11-21-2013), Tokay444 (11-21-2013) |
| Mazda crank pulley tool vs Ford crank pulley tool | SPEED6 KILLAH | MazdaSpeed 6 - Engine, Transmission & Driveline | 52 | 03-11-2017 09:46 AM |
| slip light randomly comes on? | nick779 | 2010 MS3 - Troubleshoot/Diagnostics | 6 | 07-08-2011 12:30 AM |
| Mazda3 Crank vs Speed3 Crank | relenger | MazdaSpeed 3 - Engine, Transmission & Driveline | 36 | 12-19-2010 08:22 AM |
