 Old 11-17-2013, 12:20 PM   #1
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Default Dales k04 ported and polished (PNP) Intake Manifold results
Ok, so I am wrapping up my last set of bolt on mods... I recently did an exhaust manifold and a CP-E DP. I had a good baseline from those mods with good gains so it was time for my port and polished (PNP) intake manifold. This is the one from NJSPEED3.
The install is a ton easier then the DP or exhaust manifold. It's just one of those things that you take your time on and it just happens. Not a ton of fighting the thing. My IM valves looked great, so I didn't even bother cleaning them. The hardest time I had was lining the EGR nut up with the new IM.
In terms of results, I am a little confused. The datalog data isn't matching my ass dyno. My ass dyno thinks the car had some gains from the IM. The datalog basically says there was virtually no change in HP/TQ.
Here's what the VD looks like. It basically shows no difference; this was true for all of my new runs compared to the baseline runs. This actually shows that I lost a little HP up top from the IM, but that's probably in the noise for the data I think. If there were gains, it is basically in the noise. Kind of a bummer.
Here's the normalizing data; you can see boost, IATs, and BATs are all relatively close for the comparison. All data was taken at 60F ambient.
Maybe you tuners can help out with this because I am scratching my head a little. The car did show gains in calculated load for the same boost, and it picked up 10 g/s up to redline. Why didn't this translate to HP gains on the VD?
EDIT: Logs attached (excel spreadsheet)
MINI H1 6.0 - CAR LED TAILS
The Following 13 Users Say Thank You to dale_gribble For This Useful Post:
CWP_MS3 (11-18-2013), Easter Bunny (11-17-2013), El_Diablo (11-18-2013), Hush (11-17-2013), ItsNox (12-21-2013), JgamB (11-17-2013), kish89 (11-17-2013), lilred (11-17-2013), magicka (11-17-2013), redboat (12-21-2013), RichieRichness (12-26-2013), Tokay444 (11-17-2013), trancehead (11-18-2013)
 Old 11-17-2013, 12:22 PM   #2
lilred's Avatar
Posts: 5,792   (View Stats)
I need a ride in your car...
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
The Following 2 Users Say Thank You to lilred For This Useful Post:
dale_gribble (11-17-2013), trancehead (11-18-2013)
 Old 11-17-2013, 12:22 PM   #3
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
any air temp difference from the runs?
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 11-17-2013, 12:28 PM   #4
You can see in the normalizing chart that the IATs were within 5F and BATs were relatively close. They aren't dead on, but that's what I am saying is the gains are in the noise. In all of my testing, I have been able to identify gains/trends from changing parts, even with small variations in normalizing data like this.
tapafuck
Grass, gas, or ass, nobody rides for free.
Last edited by dale_gribble; 11-17-2013 at 12:28 PM. Reason: MSF Database - Automerged Doublepost
sho (12-21-2013), trancehead (11-18-2013)
 Old 11-17-2013, 12:30 PM   #5
lilred's Avatar
I release a lot of gass from my ass from the food I eat when I smoke grass...
tapafuck
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
dale_gribble (11-19-2013)
 Old 11-17-2013, 12:37 PM   #6
How was the timing? If you moved load you may have been in a different region for timing.
Easter Bunny (11-17-2013), El_Diablo (11-18-2013), trancehead (11-18-2013)
 Old 11-17-2013, 12:45 PM   #7
Here's the Spark advance comparison @Lex;.
 Old 11-17-2013, 12:46 PM   #8
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I wouldn't look to a pnp stock manifold for much in the way of power adding.
At least not on what seems to be a maxed out k04, but more for engine longevity wih a more balanced air flow.
"Exclusivity" - CP-enis
Demodded.
The Seals
The Following 10 Users Say Thank You to Tokay444 For This Useful Post:
alphasaur (11-17-2013), breakfstincluded (11-18-2013), dale_gribble (11-17-2013), Easter Bunny (11-17-2013), El_Diablo (11-18-2013), Javi (12-26-2013), Micha (11-18-2013), redboat (12-21-2013), silvapain (11-17-2013), trancehead (11-18-2013)
 Old 11-17-2013, 12:48 PM   #9
Ya, I guess so. I expected a little something, something, especially after opening the exhaust side up, but I guess the moral of the story is the stock IM flows sufficiently for a k04 running ~21psi tapering to 18.
 Old 11-17-2013, 12:48 PM   #10
Tokay444's Avatar
Groans: 793
But still, tic another box on the gearhead requierment list for Gribble.
Demodded.
The Seals
The Following 9 Users Say Thank You to Tokay444 For This Useful Post:
breakfstincluded (11-18-2013), Crarrs (11-17-2013), CWP_MS3 (11-18-2013), dale_gribble (11-17-2013), Easter Bunny (11-17-2013), El_Diablo (11-18-2013), lilred (11-17-2013), speed23 (11-17-2013), trancehead (11-18-2013)
 Old 11-17-2013, 12:50 PM   #11
Another thing to keep in mind here. Flow is not everything to power. The mixture of air and fuel is very important and generating enough swirl and tumble is important as the air and fuel have very little time to mix in the combustion chamber.
 Old 11-17-2013, 12:56 PM   #12
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
A ported IM balances flow. The stock IM is not a restriction on the K04.
A ported IM will actually hurt engine efficiency when cold, as the VCTS has been removed.
The Following 6 Users Say Thank You to silvapain For This Useful Post:
Agent_Orange (11-17-2013), breakfstincluded (11-18-2013), CWP_MS3 (11-18-2013), El_Diablo (11-18-2013), Micha (11-18-2013), redboat (12-21-2013)
 Old 11-17-2013, 02:10 PM   #13
NOW you tell me... J/k. Some data/posts out there suggests the PNP is a power adder for k04s.
It's still a good thing I reckon. I must have found my mechanical KR source because my phantom KR is gone now which is awesome. Plus I got to inspect my intake valves and had easy access to rebuild my power steering pump o-ring.
 Old 11-17-2013, 04:02 PM   #14
scubasteve711's Avatar
Posts: 1,238   (View Stats)
Groans: 70
Just my opinion, but the gains of the manifold will be more recognized when you get more turbo u der the hood. Not to mention with more even flow, your cylinder 3 will be happy...
07' Speed6 Velocity Red Mica
scubasteve711 is offline   Reply With Quote
The Following User Says Thank You to scubasteve711 For This Useful Post:
 Old 11-17-2013, 04:16 PM   #15
ckMS3's Avatar
Posts: 1,112   (View Stats)
ckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the worldckMS3 is the leader of the world
Thought it would've added some power at least. Thanks for doing the research.
BNR S3 // E85 Mix // Freektune
348tq/367whp -21.5 psi
Now - 25-26 psi + JBR 3.5 Intake
ckMS3 is offline   Reply With Quote
 Old 11-17-2013, 09:08 PM   #16
mtosofsky's Avatar
Posts: 543   (View Stats)
mtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the worldmtosofsky is the leader of the world
A couple of Nator FL guys have ported manifolds and they say they felt some gains. To me, im more than okay with just increasing the balance of airflow and better efficiency. Even though some say the stock manifold isnt an issue with the ko4. But for people who run meth injection like myself, this should help with dispersion to each cylinder a little better. Going for a ported manifold/valve cleaning next week. If @dale_gribble; doesn't mind, ill take some before and after logs to post up as well.
2008 MS3 GT GTX//Relentless Customs//Voltron Approved//Nishan Tuned
mtosofsky is offline   Reply With Quote
 Old 11-18-2013, 10:07 AM   #17
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
I think that if you had started with the IM you would have had an easier time defining it's gains. Now that you've improved the exh flow so much with the mani & dp the improvements from the intake just aren't enough to be easily seen on a VD graph.
Much like the old argument about DP or Exhaust on the Speed6.
340hp / 371tq
El_Diablo (11-18-2013), lilred (11-18-2013), Tokay444 (11-18-2013)
 Old 11-18-2013, 10:15 AM   #18
This is one of the more concrete and well done tests on a manifold without other variables being changed. A lot of us want to see gains but instead of hypothesizing when and under what conditions we see these gains I'd like to see more proof done like this.
The Following 9 Users Say Thank You to Lex For This Useful Post:
almcbs (11-18-2013), dale_gribble (11-18-2013), Easter Bunny (11-18-2013), El_Diablo (11-18-2013), ItsNox (12-21-2013), lilred (11-18-2013), mxlplx71 (11-18-2013), redboat (12-21-2013), TiGraySpeed6 (11-18-2013)
 Old 12-21-2013, 11:49 AM   #19
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
will going to a log style IM like JMF see more of a increase HP with a free flowing exhaust?
redboat is offline   Reply With Quote
The Following User Says Thank You to redboat For This Useful Post:
breakfstincluded (12-22-2013)
 Old 12-21-2013, 11:57 AM   #20
msantana101's Avatar
Posts: 1,517   (View Stats)
Subbed
FreekTuned
 Old 12-22-2013, 11:26 AM   #21
mxlplx71's Avatar
Groans: 128
I'd say it does. I didn't do any testing, just put the JMF intake and FullRace Em on at the same time. my car is lots faster.
evening out flow imbalance for long term durability. peace of mind. = good idea.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
Last edited by mxlplx71; 12-22-2013 at 11:26 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to mxlplx71 For This Useful Post:
redboat (12-22-2013)
 Old 12-22-2013, 11:40 PM   #22
redboat's Avatar
Did you have to change your tune for the improved flow?
 Old 12-23-2013, 12:07 AM   #23
Ya. Depending on your tune: MAF cal, load targets, wgdc.
redboat (12-23-2013)
 Old 12-26-2013, 09:38 AM   #24
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
The only thing I'm wondering is why @atvfreek;'s results were so much different than yours. I can't remember what turbo he was running though. It may have been the BNR or the GTX28, which would account for the differences.
 Old 12-26-2013, 10:11 AM   #25
Yatta's Avatar
Posts: 1,862   (View Stats)
Dale, do you have wgdc logs for the before and after runs?
Glad you did this, I have a spare manifold and have been resisting it so far.
Ported polished intake with/ darkcherry MazdaSpeed 3 - Engine, Transmission & Driveline 0 11-20-2011 10:00 PM
Page generated in 0.42777 seconds with 34 queries
