 Old 12-30-2018, 09:01 AM   #1
The_big_dill's Avatar
Posts: 38   (View Stats)
The_big_dill has a spectacular aura aboutThe_big_dill has a spectacular aura about
Default Damaged valve, what could have caused this?
Hey all,
Was wondering if I can get some experienced member help on what these cars could do to cause such a valve failure:
This valve holds 20PSI in this cylinder (3) And only 1 of the valves is damaged like this. Cylinder and pistons are undamaged.
It was misfiring in this cylinder, but I attributed that to low compression.
Any advice is appreciated.
Thanks,
Phil.
The_big_dill is offline   Reply With Quote
 Old 12-30-2018, 09:49 AM   #2
08mzr's Avatar
Posts: 641   (View Stats)
08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world
Looks like a burned exhaust valve. Usually caused by the valve not properly sealing.
My gen 2 with 220k had a burned exhaust valve on cylinder 3.
2008 Metro Gray Mica Speed 3-SOLD
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
SPC rear camber arms
Hawk HPS pads front and rear
FREEKTUNE OTS+
1998 Civic - SOLD
2011 Speed3 200k+ miles Stock -Daily
08mzr is offline   Reply With Quote
 Old 12-30-2018, 10:15 AM   #3
Thanks for the reply.
I am going to see if this head is salvageable, but what failing components do you think would cause this problem? I am a little concerned because this car is stock.
 Old 12-31-2018, 09:20 PM   #4
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
what sort of symptoms got you to dig into it?
94 M
MS6
IS350
 Old 12-31-2018, 09:27 PM   #5
08mzr's Avatar
Dead miss. Compression check showed about 10psi on cylinder 3, using a scope and pressure transducer showed pulses in both exhaust and intake during compression stroke on cylinder 3.
I bought it with a misfire, but it was cheap, very cheap.
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
FREEKTUNE OTS+
1998 Civic - SOLD
The Following User Says Thank You to 08mzr For This Useful Post:
Pu Manchu (12-31-2018)
 Old 12-30-2018, 10:21 AM   #6
08mzr's Avatar
I am not the most knowledgeable on this. But from my understanding when an exhaust valve burns it's due to it failing to seal as I've previously stated. They can fail to seal due to carbon, tighter clearances, possibly running lean. I'm sure there could be some other reasons, but I'm not familiar enough with these issues to know them.
Since you've owned the car have you cleaned the valves at all?
Usually the head can be saved. I'd recommend all new exhaust valves to be safe, and also have a good machine shop do the work otherwise you'll be doing it twice. You should also send the injectors out for cleaning and flow testing.
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
FREEKTUNE OTS+
1998 Civic - SOLD
 Old 12-30-2018, 10:29 AM   #7
Unfortunately I bought these problems, never owned a speed, this is the first. The previous owner said he was revving high with low load on the engine when it misfired once or twice. Then the following day, was misfiring at idle.
Thanks for the advice, I will get the injectors cleaned and tested as well.
 Old 12-30-2018, 10:36 AM   #8
08mzr's Avatar
Kind of the same story with mine from the previous owner. He told me he was driving on the expressway when it started misfiring.
As for injector cleaning look through the forums to see who can do them. Most places that clean/test injectors cannot do them at the high pressures Direct Injectors operate at. They may seem ok at the lower pressure and not be OK at high pressures.
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
FREEKTUNE OTS+
1998 Civic - SOLD
 Old 12-30-2018, 12:10 PM   #9
eroler1's Avatar
Posts: 133   (View Stats)
eroler1 is just really niceeroler1 is just really niceeroler1 is just really niceeroler1 is just really nice
was just reading about a post in the other forums
injectorRX and cleveland injectors
they both clean GDI injectors and they have the shipping option
i heard the cleveland changes the filter inside too
planning of going to send mine soon
eroler1 is offline   Reply With Quote
 Old 12-31-2018, 01:43 PM   #10
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I used injector RX. I don't have any evidence to show they replaced the filter, so they probably didn't. I've heard of some injector places shipping back the old filters in a bag so you can see how cruddy they were, lol.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 01-02-2019, 03:02 AM   #11
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
With that much carbon all over that cylinder it's hard to determine what happened. That valve looks burnt butit's possible it shattered after a big chunk of carbon flew off of an intake valve and was caught between that valve and the valve seat. Once chipped it will just continue to go.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-07-2019, 12:48 PM   #12
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
The stock exhaust valves are pretty awesome, and in the 10 years I've been screwing with this platform I've maybe seen 3 instances of them failing. You have a lot of gunk buildup in that head, so a flake may have wedged itself in and it leaked over time and burnt. I'd expect other signs of failure on the other valve if the injector was screwed up.
I'd probably just pick up a used head from a junkyard and rebuild it/milled flat.
-06 MS6
-Corn fed 07 MS3 - Sold
What mount has caused you the most NVH. KamloopsDan MazdaSpeed 3 - Engine, Transmission & Driveline 9 06-15-2017 09:11 AM
valve guides? valve seal? valve stem? WHAT IS BLOWN?!?!?! eroler1 Gen2 MS3 General Discussion 32 12-29-2016 03:29 AM
Intake Valve Cleaning using valve overlap and DI injection window shift Vansquish MazdaSpeed 3/6 - ECU Computer Tuning 33 05-06-2014 07:00 PM
Can this be caused by dirty bpv? Zdraveca 2010 MS3 - Troubleshoot/Diagnostics 40 03-22-2013 06:44 PM
What Caused This Stealth01 Mazdaspeed3/6 General Discussion 20 07-21-2011 07:34 PM
Page generated in 0.32172 seconds with 27 queries
