 Old 04-10-2019, 06:57 PM   #1
here.n.there's Avatar
Posts: 89   (View Stats)
here.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud ofhere.n.there has much to be proud of
Default Downpipe and turbo replacement
I'm contemplating the easiest way to replace my stock dp and turbo.
It might be easier to remove the stock downpipe and turbo as one unit and install the replacements the same way.
...just because you're paranoid doesn't mean they're not after you...
...what do I call my car?!!
I call it...RAGE...
...I'll lead with a straight, follow with a hook, then I'll step to my right...if you don't know these steps, you shouldn't dance with me...for those who do recognize these steps, you'd know that I can dance with the best of them...in my prime, anyway...
here.n.there is offline   Reply With Quote
 Old 04-10-2019, 09:11 PM   #2
andale927's Avatar
Posts: 193   (View Stats)
andale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant future
Not sure if that is possible... definitely easier to remove and install separately.
2013 Mazdaspeed 3 w/ Tech - Purchased Jan 2017
Power:
BNR S4 v2 Turbocharger | JBR 3.5" Aluminum Intake | JBR Battery Box | GFB Respons BPV |Depo Racing Catless Downpipe | Bosch 3 BAR MAP | JBR 3 Port EBC | Treadstone TR8 Kit w/ Piping | Autotech HPFP Internals | Ultimate Racing Catback | Cobb Accessport V3 | Devils Own Meth Kit (D05) | Custom Tru-Cool Oil Cooler | FREEKTUNED E30 Mix+Meth
Handling:
KW V3 Coilovers | CS Camber Plates | SPC Rear Camber Arms | Michelin Pilot Sport 4S 235/40/18 | Full Damond Motor Mounts | JBR Weighted Shift Knob | JBR Shift Bushings | JBR Rear Sway Bar | Damond Short Shift Plate
Other:
Cobb Polyurethane Exhaust Hangers | Speedline Hood Struts | Corksport CF Hood Scoop | Damond OCC Stage 1 | Corksport E-Brake | Corksport Steering Wheel | Avid.1 AV-20 Wheels 18x8 +35
andale927 is offline   Reply With Quote
The Following User Says Thank You to andale927 For This Useful Post:
here.n.there (04-10-2019)
 Old 04-10-2019, 10:04 PM   #3
Just not lookin' forward to bustin' the nuts loose from the downpipeto the turbo.
Just wondering if it's possible to drop it from the turbo down.
Might not fit on the way out down below being one piece.
Could also be that I might get the turbo hung up them being duck together like that.
I don't know.... just throwing it out there and hoping that maybe it worked for someone before.
I call it...RAGE...
 Old 04-12-2019, 08:49 AM   #4
Loophole35's Avatar
Posts: 59   (View Stats)
Loophole35 is just really niceLoophole35 is just really niceLoophole35 is just really niceLoophole35 is just really nice
It won't come out that way unless you hang the motor with a engine cradle and drop the sub-frame (not worth it).
The DP fasteners are not that difficult as long as you have the right tools. It took me literally an hour and a half to do my CPE back in December (though I have access to a lift would have taken maybe 30 more minuets on jack stands).
The stock turbo can come out the driver side of the engine bay if you remove the battery box (you normally remove this to remove the TIP anyway) and remove the EGR. It slides right out of the hole made there.
Just soak all the fasteners with WD40 while the engine is warm like an hour prior to starting work. This will go a long way to making the job much easier.
Another tip is to use a quality 6 point socket. Do not use a 12-point.
2008 True Red Mazdaspeed 3
Mod list:
Cobb RMM, TIP, SRI w air box, CBE and AP3
Corksport Short throw plate w/ shifter bushings, TMIC and BPV
CPE catted DP
Tune done by Will at PD-Tuning (still slow need BT)
150k miles on original motor and turbo
H&R sport springs w/ Koni yellows
17x9 +48 6UL with 245/45R17 Flaken Azenis
Loophole35 is offline   Reply With Quote
The Following User Says Thank You to Loophole35 For This Useful Post:
here.n.there (04-14-2019)
 Old 04-14-2019, 02:33 AM   #5
Many thanks.
Your suggestions are sound and makes sense.
I call it...RAGE...
Last edited by here.n.there; 04-14-2019 at 02:33 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-14-2019, 08:59 AM   #6
Loophole35's Avatar
Another thing I would suggest is watch a few videos. Cobb’s install video on the downpipe is very good. Edge has a video on YT that is nice for the turbo.
Mod list:
CPE catted DP
 Old 04-15-2019, 05:39 AM   #7
Posts: 2,826   (View Stats)
Many thanks.
I agree with the suggestions you have been given, having installed a 3” catless dp/rp and removed and replaced the turbo twice over a span of ten years of ownership.
I would suggest a solvent stronger that WD-40, though. It is more of a lubticant and water displacer. You need a penetrating solvent.
Try PB Blaster. Inexpensive and works much better. Let it really soak. Warm engine and and let it soak at least an hour, preferably overnight. And absolutely make sure you use six point sockets only.
86AmishMs3 (04-18-2019)
 Old 04-15-2019, 06:20 AM   #8
Posts: 2,235   (View Stats)
with an air impact it wasn't a problem. Someone could try to loosen the DP studs right after a long wot pull when the thing is cherry red if some bolt doesn't came out.
removing the DP first will make room to take out the turbo bottom bracket
 Old 04-18-2019, 01:16 PM   #9
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
If you drop the whole engine, it will be extremely easy to take off the turbo and DP as one piece.
But honestly a torch will be your friend. It's not too bad once all the shields are removed.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
Turbo heatshield replacement Gr@y_F0XXX MazdaSpeed 3/6 - Turbo Induction 6 04-14-2015 09:36 AM
DIY turbo replacement '07 CX-7 MFE CX-7 > Turbo Induction & ECU Tuning 14 12-19-2014 01:02 PM
replacement IWG for atp turbo? ryein7 MazdaSpeed 3/6 - Turbo Induction 1 04-13-2012 04:32 PM
Downpipe replacement question ChicagoMike 2010 MS3 - Engine, Transmission & Driveline 5 08-30-2011 01:04 PM
Page generated in 0.30197 seconds with 25 queries
