![]() Join Date: Sep 2015
Rep Power: 0 ![]() Thanks: 2
Groans: 211
| Not Ranked : 0 score I would call DSS. If you can afford the downtime send your axles in to them for a rebuild.
![]() Join Date: Jun 2009
But, if it is already making noise or you know it has lost a good bit of grease, then replacement is what you need to do. If you can find a company that can rebuild it, they may be able to ship you a rebuilt unit, charge you a core charge and then you get the core charge back when you send yours back. I'm afraid I don't know anything about DSS, but if that is the company that made your axle, then check with them.
![]() Join Date: Nov 2016 Location: AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 550
Groans: 105
| Not Ranked : 0 score I had a tear in my OEM boot and just got it repaired locally with new oil/grease. I'm sure you can find someone local as well. Dudes here got it done in 2hrs.
__________________ Stockish |
| The Following User Says Thank You to Db09ms3 For This Useful Post: | memin (06-13-2019) |
| CV Axle Help | badorder81 | MazdaSpeed 6 - Engine, Transmission & Driveline | 11 | 05-27-2011 05:16 AM |
| American Axle opens truck axle plant in Lancaster, Pa. | Haltech | Automotive News | 0 | 03-25-2010 10:00 PM |
