![]() | | #41 | ![]() |
![]() Join Date: Mar 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 68
| Not Ranked : 0 score Sorry can't edit after 2 min. I was thinking a good example might be Summer vs Winter Gas. It's a small enough change that it won't break anything but it will affect certain parameters. -mk |
![]() | | #42 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: LaLa Land
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,321
Groans: 57
| Not Ranked : 0 score I want the stage 2 set to 18 psi that holds till redline....if that is possible and some sort of proof is shown with a fully bolted car ill buy it asap. |
| The Following User Says Thank You to Laloosh For This Useful Post: | NYpest (03-25-2008) |
![]() | | #43 | ![]() |
| Banned ![]() Join Date: Mar 2008 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 6
![]() I re-read it too, lol. Why would you want to alter the PSI? In anyway, you CAN alter boost, by MBC or EBC. Think of this as a regular PCM update from your dealership, that you paid for, and drove off with a smoother, faster, safer ride. Yes, I will be giving you a call soon as I get free | |
| The Following User Says Thank You to Performance Racing For This Useful Post: | mk_slayr (03-24-2008) |
![]() | | #44 | ![]() |
IE: the Bentley continental on the same reflash gained I think 30hp on race fuel vs 93octanne, I think?
I don't know if I already posted this, but those who purchase Stage 1 will have the opportunity and priority, to upgrade to Stage 2 at exceptional pricing, once it is available. | ||
![]() | | #45 | ![]() |
| Well if will allow the ECU to set the boost to 18 psi, no one has to bother running a Boost Cut Defender or Map Clamp Pat!
![]() | | #46 | ![]() |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score i might be interested in this depending on how much it costs. |
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score It will be less than any PNP EMS system available with the exception of the Unichip. Pricing will be similar to Unichip (Speed6 only). The thing with unichip is it is costly to tune for each mod you add, it is hard to find a tuner, and you won't be able to control throttle, doesnt hold boost as well. Holding 18lbs to redline is not yet feasible, but we have been able to hold boost much better than any other tuning solution. When we release our Stage 2/2+ with the MrlilGuy CDFP, we will be working to hold boost as high possible , with fuel pump specific tuning in the software. |
![]() | | #48 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,016
| Not Ranked : 0 score Score !!!! |
![]() | | #49 | ![]() |
Groans: 45
| Not Ranked : 0 score man $700 that is a bit pricey to me. guess i'll just stick with my standback. |
![]() | | #50 | ![]() |
![]() Join Date: Mar 2008 Location: Navarre, FL
Rep Power: 4956 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,585
Groans: 370
| Not Ranked : 0 score Ya it's around 700-800 for unichip I thought? How discounted will it be for people going from Stage 1 to 2 etc. Rough estimate? |
![]() | | #51 | ![]() |
| Not Ranked : 0 score good question |
![]() | | #52 | ![]() |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score so the reflash has full throttleplate control? that would lead to full boost till 7k
__________________ |
![]() | | #53 | ![]() |
Groans: 45
| Not Ranked : 0 score if this was around $400 or so i could see doing it but that price just seems like much to me especially since its not a specific tune for certain mods. |
![]() | | #54 | ![]() |
(Thread Starter) | Not Ranked : 0 score No idea on the going from Stage 1 to 2, but it will be as low as we can. Being the only option available, and considering they are charging $890 as their intro price Overseas, and $1000msrp, this is a pretty fair estimate. Still waiting to hear from Piasini Engineering on possible price reduction. |
![]() | | #55 | ![]() |
Groans: 45
| Not Ranked : 0 score i would only assume it would get cheaper as you go on, i mean if you are doing them then you would only have to by one flashing hardware tool and then if its the same map over and over there really isn't much more too it. |
![]() | | #56 | ![]() |
| Not Ranked : 0 score ^ Sorry, let me see if I can rephrase my question, The Ecu learns and adapts depending on changing variables to try and maintain certain values. While learning will it eventually override the flash to try and correct to the original values? Or will it learn towards the flashed values as they replaced the stock values as the new "orignal" values? Thanks, and sorry for any confusion. -mk |
![]() | | #57 | ![]() |
Groans: 45
| Not Ranked : 0 score from the way i see it is that the flash over writes the stock values so now any learning would be off the new values so it has no way of knowing what the stock ones were to begin with. |
![]() | | #58 | ![]() |
![]() Join Date: Mar 2008 Location: Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,050
__________________ 2007 Sunlight Silver MS3 Graphite RX8 Rims · 235/40R18 Kumho SPTs BC Coilovers · Cobb Swaybars · DBA 4000 Slotted Rotors · Technafit SS Brake Lines · SU Rear MM · TRZ Trans Mount · TopSpeed Passenger MM Cobb AP · MS CAI w/ AEM Straightener · Cobb Turbo Inlet · Cobb FMIC · Black HKS SSQV (recirc) · PG Exhaust Manifold · Corksport Downpipe · Vibrant Exhaust mrlilguy CDFP · Denso ITV22s plugs · Cobb STS, Shift Knob, & Shifter Weight · F2 Balance Shaft Delete & Oil Baffle | |
| The Following User Says Thank You to SLS MS3 For This Useful Post: | mk_slayr (03-24-2008) |
![]() | | #59 | ![]() |
MSF -The HARDCORE Of Mazda High Performance Tech! Flex Limited Ecoboost - Not Stock ![]() Gen1 MS3 - COBB FMIC V2.0 | COBB SRI | COBB AP Stage 2 W/MSF_V1.08y | COBB 3" Downpipe | COBB CBE | Devil's Own Stage 2 Meth Injection | AST 4300 Coilovers | Haltech Fuel Pump Internals | Rota Torque 18x8 w/ 235/40/18 | ACT 6 PUCK Sprung/Streetlite ![]() | ||
| The Following User Says Thank You to Haltech For This Useful Post: | mk_slayr (03-24-2008) |
![]() | | #60 | ![]() |
| Not Ranked : 0 score ^^ That's what I was thinking but I wasn't sure, thanks for the info. -mk |
![]() | | #61 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks for answering the questions ![]() It is correct. And if one even chooses, they can install a zerod out Piggyback on top of a reflashed ECU. I don't know what they'll get BUT, there are some things a Piggyback can do, that a reflash cannot, like Map switching (most don't need this), Meth Injection tuning (not required). I am not sure if throttle control will enable FULL boost to redline, but we have seen 15lbs at 5500rpm on a 16lb tune! remember, we will be incorportating throttle control in the future, maybe the first ones to have this available, so it seems ![]() Revo and APR start their base Stage 1 reflashes at $599 and $699 as well. They are cometing with GIAC, Forge, and several others out there. Our pricing is not that different at all and is VERY reasonable. This is the one and ONLY option, so the company who has created this software and made reflashing possible is substantial. We all wanted a way into the ECU, well.... we're in ![]() A time goes, MORE possibilities and capabilities will arise. We hope to pretty much have complete control of the motor. |
![]() | | #62 | ![]() |
![]() I want to thank the few who have already gotten on board with this offer. These first people will have priority to updates, upgrades, etc. The engines in a Speed3 vs Mazda3 MPS are exactly the same... an Aussie/Auro reflash would yield the same exact results as posted in the beginning of this thread. The datalogs anf dynos are in that post as well | |
![]() | | #63 | ![]() |
Groans: 102
| Not Ranked : 0 score sweeeet!!!
![]() | | #64 | ![]() |
long time comming | |
![]() | | #65 | ![]() |
| i think the results will be quite interesting.
![]() | | #66 | ![]() |
| Not Ranked : 0 score thumbs up to me and Performance Racing getting specific software together, to take advantage of both products to their upmost capabilities.
__________________ Black Mica '07 Mazdaspeed3 Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing Reppin' ProtegeGarage for life! |
![]() | | #67 | ![]() |
| Not Ranked : 0 score 2 thumbs up !! |
![]() | | #68 | ![]() |
Groans: 57
| Not Ranked : 0 score seeing 15psi when dialing in 16 is not a big deal. I do that right now on the stock boost control system. Make that 15 hold till 6500 and you got something. |
![]() | | #69 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
| Not Ranked : 0 score there was a test done on our turbo that said it was effecient from like 21-23 somthin like that i think laloosh or driver311 posted it up awhile back |
![]() | | #70 | ![]() |
| Not Ranked : 0 score |
![]() | | #71 | ![]() |
Groans: 57
| Not Ranked : 0 score According the map that i posed over on 247 20ish was efficient untill about 5200 rpm |
![]() | | #72 | ![]() |
(Thread Starter) | Not Ranked : 0 score Really... According to Dyno4mance tuning sessions, they gained more hp at 17lbs than at 19lbs on several cars, which led me to that conclusion. |
![]() | | #73 | ![]() |
Was the car from that dyno running an aftermarket intercooler?
![]() | | #74 | ![]() |
Groans: 57
| Not Ranked : 0 score darksun gained 22whp going from 17 to 19 psi with nothing else changed.... |
![]() | | #75 | ![]() |
(Thread Starter) | Not Ranked : 0 score Hmm, again, pretty interesting. Rican may want to chime in, or in another thread to try and keep it on topic, but it was his car the tuning was done on. He has the Corksport FMIC I think. |
![]() | | #76 | ![]() |
![]() Join Date: Mar 2008 Location: North America ;)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 60
| Not Ranked : 0 score With my boost controller i'm holding 17psi for a bit(midrange) then it drops around 15-16psi around 5900rpms... I am interested as well in this. It would be nice to have a extra "1000" rpms in every gear
__________________ 08 Cosmic Blue MS3 Autox pwns j00!!! |
![]() | | #77 | ![]() |
| Not Ranked : 0 score M3F is gang'n up on me lol i might have mentioned im on board with this in a new thread ...and WOW |
![]() | | #78 | ![]() |
| What do you mean? That forum is fuckin lame.
![]() | | #79 | ![]() |
![]() | | #80 | ![]() |
| A real tuning solution? | occschemguy | MazdaSpeed 3/6 - ECU Computer Tuning | 69 | 05-21-2013 07:14 AM |
| Reflash vs. COBB AP | ikillforfunok | MazdaSpeed 3/6 - ECU Computer Tuning | 4 | 04-14-2008 02:50 PM |
| Hennessey performance expanding tuning to include ZR1, GT-R and IS F | Haltech | Automotive News | 0 | 04-12-2008 06:50 PM |
| Performance Racing Intro Sale! Speed3/6 Parts in here! | Performance Racing | Mazdaspeed3/6 General Discussion | 12 | 04-02-2008 03:08 PM |
| Welcome Performance Racing as a Authorized Vendor | Haltech | Mazdaspeed3/6 General Discussion | 4 | 03-14-2008 11:32 AM |
