![]() Join Date: May 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
| Neutral : +1 score According to Mazda parts counter (Dan at Ourisman Mazda in MD) any Speed3 produced *after* December 17, 2007 uses FL-22. Before that it *does *not use FL22. AllData contradicts this, and states I need FL-22. AllData isnt incorrect but there is a caveat. As per the TSB 01-033/07 in the above post, you CAN use FL-22 on older Speed3 but dont mix it with orange coolant because it will turn black. Dan sent me this Mazda Fluids Chart updated March 16 2019 is as follows: ![]() Pentonsin PENTOFROST A2 (GREEN) Antifreeze Specially Formulated For Asian Vehicles — CONCENTRATE- HOAT technology but does not have FL-22 according to the rep I spoke to at PENTOSIN but it does cross reference with Mazda 0000-77-501E-02. http://www.pentosin.net/specsheets/Pentofrost_A2.pdf Pentofrost A3 (BLUE) does have FL-22, according to the same guy at Pentosin but is only available in 50/50 mix but does NOT cross reference with Mazda 0000-77-501E-02 (confusing). http://www.pentosin.net/specsheets/Pentofrost_A3.pdf I had little trust in the expertise of the guy at Pentosin...he knew nothing about what FL-22 specs included, only that MAZDA had no cut off date for the need to use FL-22 or not. He was wrong about the cut off date. Pentofrost A1 (RED) is FOR ASIAN vehicles, CONCENTRATED, HOAT technology but isnt listed for MAZDA. http://www.pentosin.net/specsheets/Pentofrost_A1.pdf An inexpensive FL-22 coolant CONCENTRATE is RAVENOL J4D2092 Coolant Antifreeze - HJC Hybrid Japanese Coolant Protect FL22 Concentrate (5 Liter. $27 on Amazon. Last edited by Lex2007; 11-07-2019 at 08:16 AM. |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f505/engine-coolant-128395/ | ||||
| Mazda FL-22 Coolant Cross-Reference_Wiki Searcher | This thread | Refback | 04-26-2015 08:19 PM | |
| Coolant in engine bay | KillerAngel | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 21 | 05-23-2011 05:03 PM |
| Coolant boiling over exhaust in coolant | bcmurphy87 | MazdaSpeed 6 - Engine, Transmission & Driveline | 12 | 12-15-2010 02:39 PM |
| Video: Prestone melts GM 3.6-liter engine block with blowtorches to show importance of coolant | Haltech | Automotive News | 1 | 06-30-2010 11:13 AM |
| coolant | phillyb | MazdaSpeed 3 - Engine, Transmission & Driveline | 26 | 03-13-2010 06:24 PM |
