 Old 12-21-2018, 12:38 PM   #1
Rezwalker's Avatar
Posts: 16   (View Stats)
Rezwalker has a little shameless behaviour in the past
Question Engine Damaged. Can we identify the issue with this video?
Hi all,
So my 2007 MS3 engine died last week. I'm trying to figure out if it's worth saving or if I need a swap. It may have missed some oil at some point, due to the fact that it just burns off soooo much, it was near impossible to keep up.
So 3 months ago I noticed a rattling sound from the engine on startup only. It got gradually worse, to the point where it would rattle really loud while I was driving, especially before shifting as you will be able to see on this video:
Video here. Noise starts @ 0:05 until shift.
Is that just knock? Or something else?
Thanks for any info, much appreciated, as I am without a car right now and it's really difficult...
Rezwalker is offline   Reply With Quote
 Old 12-26-2018, 07:02 PM   #2
08mzr's Avatar
Posts: 641   (View Stats)
08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world08mzr is the leader of the world
I would recommend engine/turbo replacement. If the engine was already consuming oil to the point where you couldn't keep up, likely impossible, then its not worth fixing. Also, it was run low on oil to the point where its making noise. Yes it can be fixed, but it'd be a ticking time bomb unless completely rebuilt.
The reason the turbo is recommended is for a couple of reasons. The first being it could've been the cause to the oil consumption, the second being it was most likely damaged from low oil.
2008 Metro Gray Mica Speed 3-SOLD
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
SPC rear camber arms
Hawk HPS pads front and rear
FREEKTUNE OTS+
1998 Civic - SOLD
2011 Speed3 200k+ miles Stock -Daily
08mzr is offline   Reply With Quote
 Old 12-26-2018, 07:40 PM   #3
Rezwalker's Avatar
Thanks for the reply. So what is a good way to go about and replace the engine? Where do you guys source it?
 Old 12-26-2018, 07:46 PM   #4
08mzr's Avatar
I have a yard local to me that buys "sports cars" and they had a lower mile used engine with turbo. I was able to replace my engine myself as its what i do for a living. If you have the time knowledge and space, its not a difficult job, but can get pricey.
If going the used engine route, i highly recommend checking compression if at all possible, if not do it as soon as you get it running since most reputable places have a warranty on their engines. After that, replace the timing chain/VVT, clutch, rear main seal and clean the valves. That's all a lot easier while the engine is out of the car.
Corksport SRI
Corksport TIP
JBR 80 duro RMM
Cobb AP v3
Autotech internals
CX Racing FMIC
FREEKTUNE OTS+
1998 Civic - SOLD
 Old 12-26-2018, 10:32 PM   #5
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
what noise? the mic clipping? or the knife against the wine glass?
94 M
MS6
IS350
BMW planning Chinese recall for engine part issue [w/video] Haltech Automotive News 0 03-17-2014 05:10 PM
Mystery MX5 Engine - Can you Identify it? wireaddict Miata - Engine, Transmission, Driveline 9 11-18-2013 06:19 PM
Can anyone identify this engine noise? Lex2007 Mazdaspeed3/6 General Discussion 32 08-28-2013 04:33 PM
What got damaged when my engine grenaded? cplensdorf MazdaSpeed 3 - Engine, Transmission & Driveline 18 01-09-2012 07:17 PM
Toyota deepens roots in quake-damaged Japan with new engine plant Haltech Automotive News 0 07-19-2011 10:00 PM
Page generated in 0.26276 seconds with 22 queries
