![]() Join Date: Sep 2017
Rep Power: 0 ![]() Thanks: 0
Groaned at 3 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score Okay so I loaned some friends my car. While they had it a radiator hose popped off and they drove the car till it stopped. I removed the spark plugs to find cylinders full of antifreeze. I turned the car over and the engine could barley spit any of the water out. At this point I'm cutting my loses and swapping the engine the car is a 2007 Mazda 3 with a 2.0L automatic transmission. I was wondering if anyone has a guide or step by step instructions on removal and installation. Also a list of parts/gaskets that I should swap along the way obviously I think to do the timing water pump plugs wires and coils but idk what other gaskets Or parts to replace as well. Any help I can get would be awesome I want this to go smoothly as possible I don't have a lift so the engine will have to come out from the top. |
| The Following 3 Users Say NO Thank You to Lilrobbie1127 For This Un-useful Post: |
Groans: 211
__________________ 2007 MS6- H&R Coilovers/ C-PE Catted DP/Corksport HPFP Internals/ AEM CAI/ ETS TMIC/ CPE Austenite Dual CBE/ CPE TIH/ Synapse Synchronic/ Freektuned/ AP Short Shifter/ AWR RMM and OEM TMM with CS Inserts/ Southbend Stage 2 Endurance/Stop Tech Slotted Rear and DBA T3 4000 Series Front with EBC Reds/CPE xFlex Rear Diff Mount/ Whiteline Rear Sway Bar/DSS Level 2.9 Rear Axles | |
(Thread Starter) | Not Ranked : 0 score Well these websites aren't exactly mobile friendly I searched the Internet for days for this info I just ended up buying myself a Haynes manual |
![]() Join Date: May 2017
Rep Power: 0 ![]() Thanks: 3
I can sum up the Haynes manual and save you $21. "Take all the bolts out. Installation is reverse of removal." Ta-da. Free! | |
| Gen 2 Ms3 Engine Swap into a Gen 1 Ms3 | 550bomb | MazdaSpeed 3 - Engine, Transmission & Driveline | 63 | 09-21-2015 05:30 AM |
| swap engine from one MS6 to another | aviator79 | MazdaSpeed 3/6 - Build Diaries | 24 | 11-17-2012 04:30 PM |
| Engine Swap | caykilla | MazdaSpeed 3 - Engine, Transmission & Driveline | 2 | 10-15-2009 05:03 PM |
