Like Tree25Likes
 Old 10-17-2015, 09:38 PM   #1
dale_gribble's Avatar
Posts: 4,720   (View Stats)
Neutral  :  -1 score
Default ETS TMIC v. CP-E FMIC MS6; guess I need a bigger intercooler
Been crunching data and making sense of this. These results for the FMIC are even after I hacked the crash bar/grille so the FMIC has full exposure to fresh air.
I guess it just goes to show you that even though the stock location TMIC heat soaks terribly at a stop, when it's getting fresh air shoveled in, it is better at holding bats down better than my CP-E FMIC IC which by CP-E's statement is rated to 400hp. This would even more significant for GENPUs since they have the massive hood scoop instead of Gen 1/Speed6 ducting. The CP-E doesn't heat soak nearly as bad as TMIC, but it doesn't hold temps down as well where I expected it to bury the TMIC. Flow is equivalent and the CP-E flows just fine. It just isn't as thermally efficient.
For the testing, conditions were similar, ~76 degrees, 29.9 baro pressure, ~80% humidity.
I want to share this because the advantages of FMIC aren't necessarily everything that people think they are for the work involved if the setup isn't optimized. So, now I'm going to start shopping for an upgraded FMIC for my MS6 CP-E kit.
EDIT: here is some additional information which makes more sense now that I crunched the numbers. The volume of the ETS TMIC core is 546 in^3 (3.25x12x14) and the volume of the CP-E FMIC core for the MS6 is 360 in^3 (20x6x3). So the ETS TMIC has 33% greater volume than the CP-E FMIC. So, I guess if you are sizing a FMIC, make sure it is probably around 546 in^3.
ItsNox likes this.
MINI H1 6.0 - CAR LED TAILS
The Following 30 Users Say Thank You to dale_gribble For This Useful Post:
Big Dog (10-27-2015), blackmicamps6 (10-21-2015), Bolted6 (02-12-2017), Caligula (10-17-2015), cyclist20 (10-20-2015), DaUberSchwebel (10-18-2015), DingoDave (11-27-2015), Easter Bunny (10-18-2015), Enki (10-30-2015), EvoFire (10-21-2015), frothy (10-17-2015), Hush (10-21-2015), lolwrx (10-18-2015), Malbosia (10-26-2015), Mazdazilla6 (10-20-2015), MD1032 (10-18-2015), mituc (10-20-2015), ms6mil (10-18-2015), Pu Manchu (10-17-2015), r3d (10-18-2015), rob ms6gt (10-18-2015), robbspeed (12-17-2015), snailD (10-31-2015), Spectrix (10-18-2015), speed23 (10-17-2015), sporkbomb (10-26-2015), Tokay444 (10-21-2015), torquemaniac (10-22-2015), Voltwings (10-18-2015), WAMBUSHHHH! (10-21-2015)
 Old 10-17-2015, 10:02 PM   #2
I found a Treadstone TRV1859 that is the same side design as the CP-E FMIC, but has a core volume of 582 in^3 (18.48 X 9.00 X 3.50). So, it's 3" taller and 0.5" wider than the CPE.
 Old 10-17-2015, 10:08 PM   #3
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
lol @ 80% humidity. The weather has indeed sucked royally.
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
 Old 10-17-2015, 10:10 PM   #4
Also, for anyone wondering, the Treadstone TR6 has a volume of 462 in^3 (6" X 22" X 3.5") and the TR8 has a volume of 600 in^3 (7.8" X 22" X 3.5"). I would say the TR6 is probably not the best option for FMIC setup for anyone on the fence. It appears the TR8 would better match the volume of the upgraded TMICs.
Malbosia (10-26-2015), Tokay444 (10-21-2015)
 Old 10-17-2015, 11:11 PM   #5
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
ETS also made a 3.5" TMIC. that along with a genpu hoodscoop is nice.
94 M
MS6
IS350
 Old 10-18-2015, 05:35 AM   #6
MD1032's Avatar
Posts: 2,624   (View Stats)
Groans: 143
Fantastic information, dale. Thank you. Why is there such a large discrepancy between the IAT's of the two runs? Also, did you take more than one log with each setup? I like to see multiple runs to verify that the test is precise within reason.
I wonder how CP-E's TMIC compares to their own FMIC. I have the CP-E TMIC and I'm aware that the ETS is regarded as being better than the CP-E.
Since you're on pump gas, were you able to run more timing with the ETS than the CP-E FMIC?
2007 Mazdaspeed3 GT
 Old 10-18-2015, 06:06 AM   #7
speedfreak44's Avatar
Posts: 1,391   (View Stats)
My theory, and I may be wrong, is that the air on those top to bottom flow fmics is that the air does not spend enough time within it to actually cool down enough. The side to side ones keep air in them longer allowing it to cool better. Before dismissing the fmic I believe a side to side version needs to be expiremented with.
The line up:
 Old 10-18-2015, 08:31 AM   #8
IAT variations have little to no difference on charge air temps and subsequently power, assuming ambient conditions are the same. This is why cold air intakes don't do squat for our cars. With the tmic ducting gone more fresh air gets into the intake. I've run multiple logs and the data is consistent.
This particular fmic setup didn't worsen performance but it didn't necessarily improve it either which is the takeaway here.
I am not dismissing fmic's. I am dismissing MY setup. There is a lot of data out there that suggests vertical flow units are superior for flow and that the first few inches of an ic do a majority of the cooling regardless of orientation. The fmic core is 33% smaller than the tmic core and I believe this is the driving factor.
ItsNox likes this.
Last edited by dale_gribble; 10-18-2015 at 08:31 AM. Reason: MSF Database - Automerged Doublepost
The Following 5 Users Say Thank You to dale_gribble For This Useful Post:
Big Dog (10-27-2015), chaser27 (10-21-2015), Easter Bunny (10-18-2015), MD1032 (10-18-2015), speedfreak44 (10-18-2015)
 Old 10-18-2015, 08:54 AM   #9
Voltwings's Avatar
Posts: 3,713   (View Stats)
I just have incidental data from being in dozens are cars tuning folks, but i'd have to agree with you; an ETS on a Gen2 is probably close to as good as you can get on these cars (on stock turbo, even though i ran my 3071 through the ETS before my 5th port).
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 10-18-2015, 08:55 AM   #10
How did the BT fair when comparing ets vs whatever you currently run?
The line up:
 Old 10-18-2015, 09:00 AM   #11
Voltwings's Avatar
I was running meth, so its not a fair comparison. Honestly though, the only reason i went to a FMIC was to get a 5th port. We were actually trying really hard to design a system using the Speed6 cold pipe for a TMIC 5th port, but the price just stopped making sense after a bit.
Past:
-Sold-
-Sold-
Current:
 Old 10-18-2015, 09:10 AM   #12
Also as you can see I have my setup wide open. There is no lack of high pressure cold air getting into this thing.
The Following 7 Users Say Thank You to dale_gribble For This Useful Post:
cyclist20 (10-20-2015), jdub (11-04-2015), Malbosia (10-26-2015), MD1032 (10-18-2015), SNOW_QN (10-18-2015), Voltwings (10-18-2015), WAMBUSHHHH! (10-21-2015)
 Old 10-18-2015, 10:00 AM   #13
Off topic
Your car is beautiful
The line up:
The Following 3 Users Say Thank You to speedfreak44 For This Useful Post:
dale_gribble (10-21-2015), Malbosia (10-26-2015), WAMBUSHHHH! (10-21-2015)
 Old 10-18-2015, 06:55 PM   #14
sheston's Avatar
Posts: 1,847   (View Stats)
@dale_gribble: That is some very interesting data. Sounds like especially for the Genpus, that upgraded TMIC may be the right answer unless you go all out for the FMIC (meaning crash bar replacement, etc).
Now you just need to figure out a way to calculate pressure drop, lag, and the benefits of Meth :-)
Does the TMIC have less drop? I've seen people say lag isn't any difference, but you seem to have dug in more, taking into account things like volume.....
 Old 10-18-2015, 07:33 PM   #15
Feline Führer
neganox's Avatar
Posts: 1,790   (View Stats)
Thought you ran meth dale.
dale_gribble likes this.
Easter Bunny (10-18-2015), ItsNox (10-20-2015)
 Old 10-18-2015, 08:11 PM   #16
I do. I was just tuning pump gas only up first to get a good baseline for all of the new changes. Meth tuning is so much fun. A degree of timing from 4k plus a little more boost give like 15-20whp jumps every iteration on my way up to optimized tune.
This 2.25" fmic setup provides no difference to me in response vs. tmic at all and I do have a point of reference since I ran the 2.5" cx fmic kit and I hated how that kit effected throttle response.
Last edited by dale_gribble; 10-18-2015 at 08:11 PM. Reason: MSF Database - Automerged Doublepost
Easter Bunny (10-18-2015), ItsNox (10-19-2015), neganox (10-18-2015)
 Old 10-20-2015, 12:03 PM   #17
I got my order in on that Treadstone TRV1859 unit. We'll see what happens. I'm expecting improvements since it's a little bigger than the ETS and 38% larger volume than CP-E FMIC. It's 38% larger in volume, so let's set the baseline at 20-30% improvement in BATs.
The Following 6 Users Say Thank You to dale_gribble For This Useful Post:
cyclist20 (10-20-2015), ItsNox (10-20-2015), Mazdazilla6 (10-20-2015), mituc (10-20-2015), mxlplx71 (10-20-2015), rob ms6gt (10-20-2015)
 Old 10-20-2015, 04:03 PM   #18
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Dale I might be interested in buying that Cp-e core off you if you're willing to sell.
When the time comes we can talk more and have it be "official" and per the fs rules. Just stating my interest currently.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
dale_gribble (10-21-2015), Easter Bunny (10-21-2015)
 Old 10-21-2015, 09:39 AM   #19
Sure dude. I'll post it up when it comes off.
Mazdazilla6 (10-21-2015)
 Old 10-21-2015, 10:51 AM   #20
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
I've been told that if you paint your core purple and coat it with glitter your BATs stay, on average, roughly 30 degrees cooler. Any chance you can test that for us as well and add that data?
Good information, man! Coming from my CPe TMIC to my current Cobb FMIC set-up, my results are much the same. I wish I still had my CPe TMIC logs to run a similar graph but such is the nature of blown hard drives. It's annoying to see some people spewing data like "my BATs were 25 degrees cooler with my FMIC compared to my TMIC". It's bullshit. On average I saw maybe a 10 degree drop, certainty nothing to change your current set-up especially if you already have an updated TMIC.
The Following 3 Users Say Thank You to WAMBUSHHHH! For This Useful Post:
dale_gribble (10-21-2015), Easter Bunny (10-21-2015), MD1032 (10-21-2015)
 Old 10-21-2015, 11:04 AM   #21
Jarods7920's Avatar
Posts: 1,415   (View Stats)
So, just to keep this in perspective your data is limited to your test subjects. For you to say that because these tests yielded these results does not lend itself to say that all FMICs are worse at holding down BATs.
As your data states the volume of the CPE is less than the ETS. The CPE has far less surface area than the ETS as well. 396 in^2 vs 505 in^2 So, you're not exactly comparing equal test subjects.
The Following User Says Thank You to Jarods7920 For This Useful Post:
silvapain (10-22-2015)
 Old 10-21-2015, 11:36 AM   #22
I mean, yeah in a perfect world this test would have been done with each set-up using cores with identical measurements. He's just simply testing two of the more popular intercooler brands we have for the platform. Not saying your comment doesn't have merit but he's testing real world options, that's all.
I don't think the take away is that ALL FMIC are worse, I think the take away from this is that between these two popular brands there really isn't a performance difference that's worth making the switch for one if you have the other. Or at least, that's my take away. Something I've hinted at for a while in similar conversations I've had about my CPe TMIC vs my Cobb FMIC. I've just never had the data nor the desire to swap out the FMIC to the TMIC to get new logs to make a similar comparison.
At the end of the day, if you want drastically cooler BATs, shoot meth. Only way I've seen BATs lower than ambient. Fuck those meth heads.
 Old 10-21-2015, 11:43 AM   #23
I bet a FMIC makes less of a difference on the street, but at the track there is no comparison; last graph here vs first graph here.
The Following 8 Users Say Thank You to Code Monkey For This Useful Post:
dale_gribble (10-21-2015), Easter Bunny (10-21-2015), ItsNox (10-21-2015), sporkbomb (10-26-2015), torquemaniac (10-22-2015), Vansquish (10-26-2015), Voltwings (10-21-2015), WAMBUSHHHH! (10-21-2015)
 Old 10-21-2015, 11:49 AM   #24
Yeah, probably should have stated that. I hard park my car and use my FMIC for rice points. I can't speak to the performance differences when tracking the car. While you guys are doing real race car things, I'm debating camber.
ItsNox likes this.
Code Monkey (10-21-2015), dale_gribble (10-21-2015), Easter Bunny (10-21-2015)
 Old 10-21-2015, 11:56 AM   #25
Thanks captain obvious. I guess you just read the top post instead of reading through.
I don't think fmics for street are what everyone thinks they are. It's not a guaranteed gainer as I showed from a supposed brand name 'engineered' setup if it isn't engineered right. People just have in their heads that fmics are superior across the board which I showed isn't necessarily correct.
Easter Bunny (10-21-2015), ItsNox (10-21-2015), MD1032 (10-21-2015)
 Old 10-21-2015, 12:25 PM   #26
engineered my ass
 Old 10-21-2015, 12:48 PM   #27
aviator79's Avatar
Posts: 3,934   (View Stats)
Same size core as my Spearco but end tanks are bigger on Spearco for 3" in/out vs 2.5.
 Old 10-21-2015, 01:46 PM   #28
That Spearco was on my list, but damn, $$$...
Do you have any datalogs on that intercooler?
 Old 10-21-2015, 03:54 PM   #29
Voltwings's Avatar
Whats funny is i was going to say that a FMIC wins if you're comparing BATs when cruising, but (on a Gen 2 at least*) at WOT i could show you two logs and you'd be hard pressed to tell me which was which .... but then you came along with this post haha.
Actually, now that i think about it, you're using your ETS core as a FMIC arent you... so you're essentially proving Dale's point, that the ETS is a superior core since you saw an improvement going FMIC than he did with the CP-E core.
Past:
-Sold-
-Sold-
Current:
The Following 5 Users Say Thank You to Voltwings For This Useful Post:
Code Monkey (10-21-2015), Easter Bunny (10-21-2015), ItsNox (10-21-2015), MD1032 (10-22-2015), WAMBUSHHHH! (10-23-2015)
 Old 10-21-2015, 06:07 PM   #30
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Glad my txs core is 793 cubic inches.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 10-21-2015, 06:15 PM   #31
Voltwings's Avatar
I miss my 302 Cubic inch core
Past:
-Sold-
-Sold-
Current:
 Old 10-21-2015, 06:16 PM   #32
Tokay444's Avatar
Groans: 793
And fits under the stock crash bar.
Demodded.
The Seals
 Old 10-22-2015, 07:11 AM   #33
Jarods7920's Avatar
I read the majority of the thread.
I agree with what you're saying in large part. But, again you make a blanket statement about FMICs and assume this broadly applied to all of them. I would love to see this test performed again with equal or nearly equal surface area on both systems.
As others have already alluded to, I dont know that this set up is as "engineered" as everyone thinks it is.
 Old 10-22-2015, 07:59 AM   #34
Voltwings's Avatar
Code monkey used the exact same core, took his ETS and made it a FMIC and saw massive improvement.
Dale says his FMIC did not do as well as his TMIC
Code Monkey's ETS TMIC works fantastic as a FMIC
Ergo - the ETS TMIC core is superior to the CP-e FMIC core
/thread.
udntknw likes this.
Past:
-Sold-
-Sold-
Current:
Easter Bunny (10-22-2015)
 Old 10-22-2015, 08:19 AM   #35
Jarods7920's Avatar
/thread.
I think that was stated by the OP that the CPE < ETS.
 Old 10-22-2015, 08:12 PM   #36
Tokay444's Avatar
Groans: 793
Fuck CP-e.
Demodded.
The Seals
 Old 10-26-2015, 04:20 PM   #37
Of course I am doing this test again with equal or near equal surfaces on both systems. ETS TMIC volume is 563 in^3 and treadstone FMIC is 582 in^3 (within 3%) so your wish will come true. I predict the Treadstone FMIC will do much better than CP-E FMIC core, due in large part to the increase in volume and lesser part denser core design.
I think most FMIC intercoolers have cheap cores or are too small. What I keep saying is that people take at face value that FMICs are a guaranteed power adder and I and others showed that they aren't. I have taken at gospel from people evangalizing FMICs here as a killer bolt on mod, and have twice been a little disappointed. It's not a matter of piping since piping is piping, it's a matter of the quality/size of core. Many have gone from CX cores to treadstone cores with much better results size for size.
New intercooler comes in Wednesday, I'll get mounts welded onto it on Thurs-Fri and bolt it on next weekend. Expect magic.
ItsNox likes this.
Easter Bunny (10-26-2015), Jarods7920 (10-26-2015), Voltwings (10-26-2015)
 Old 10-26-2015, 04:23 PM   #38
Tokay444's Avatar
Groans: 793
What's funny is people buying tr6's and thinking they're an upgrade.
Demodded.
The Seals
The Following 6 Users Say Thank You to Tokay444 For This Useful Post:
dale_gribble (10-26-2015), Easter Bunny (10-26-2015), faeker (11-02-2015), ItsNox (10-26-2015), mxlplx71 (10-26-2015), Voltwings (10-26-2015)
 Old 10-26-2015, 04:42 PM   #39
Exactly, especially for the guys getting the TR6 size intercooler but instead get a cheaper cx racing core or equivalent.
Here's a blanket statement for FMIC. If you go FMIC, get a Treadstone TR8 or volume/core equivalent. If you can't afford it or don't want to cut your crashbar, stick with an upgraded TMIC.
Easter Bunny (10-26-2015), macdiesel (11-02-2015), Voltwings (10-26-2015)
 Old 10-26-2015, 04:58 PM   #40
Jarods7920's Avatar
There is something to be said about buying a quality product. I am inclined to believe the FMIC of equal proportion to the ETS will out perform the ETS TMIC. I look forward to your results!
Going bigger FMIC core to support bigger power KCi 2010 MS3 - Turbo Induction 9 08-06-2015 10:07 AM
TMIC > FMIC > back to TMIC - my journey dale_gribble Mazdaspeed3/6 General Discussion 95 12-14-2012 04:58 AM
HP Gains- fully bolted w/stock TMIC vs. FMIC/bigger TMIC Chimmike MazdaSpeed 3/6 - Turbo Induction 6 07-04-2011 03:18 PM
Page generated in 0.62053 seconds with 35 queries
