 Old 02-25-2009, 10:08 PM   #1
nobmood's Avatar
Posts: 18   (View Stats)
nobmood is an unknown quantity at this point
Default Externally Wastegated Turbo Manifold vs Tubular Turbo Manifold
I am a noob in the mod world so this might be a silly question:
What is the advantage of the Externally Wastegated Turbo manifold since the power gains look to be the about same as the tubular but the price difference is $200.
Thanks
2008 Black MS3, CP-E CAI, RPMC Turbo Inlet
nobmood is offline   Reply With Quote
 Old 02-25-2009, 10:19 PM   #2
motocrosser614's Avatar
Posts: 687   (View Stats)
motocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the worldmotocrosser614 is the leader of the world
stock turbo- tubular manifold aftermarket turbo- EWG Your stock turbo ko4 spools quickly so boost creep is not too much of an issue. If your mods meet your sig id say go tubular manifold and dp and you will feel quite a difference in power across the board plus quicker spool time.
motocrosser614 is offline   Reply With Quote
 Old 02-25-2009, 10:32 PM   #3
nobmood's Avatar
Thanks I am also just curious as to what the external wastegate adds to the manifold.
 Old 02-25-2009, 11:51 PM   #4
wassup61's Avatar
Posts: 1,232   (View Stats)
external wastegate adds just that... an external wastegate, you wont have boost creep with your setup now; however, we can get you setup with a manifold at a great deal, and package it with our new fuel pump internals and an EMS!
Feel free to PM me with questions/orders.
-Jeff at PG
All wagon, No traction
The Following User Says Thank You to wassup61 For This Useful Post:
nobmood (02-26-2009)
 Old 02-26-2009, 11:42 AM   #5
nobmood's Avatar
I can't pm yet
 Old 02-26-2009, 11:42 AM   #6
nobmood's Avatar
because I don't have 15 posts
 Old 02-26-2009, 11:43 AM   #7
nobmood's Avatar
but i am working on it
 Old 02-26-2009, 11:46 AM   #8
nobmood's Avatar
Is boost creep caused by changes in pressure?
 Old 02-26-2009, 11:49 AM   #9
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
It's from the inability to bleed off boost.
The Following User Says Thank You to bova For This Useful Post:
 Old 02-26-2009, 12:15 PM   #10
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
nobmood what is 1+1?? (more posts?)
 Old 02-26-2009, 02:28 PM   #11
nobmood's Avatar
Basically
I suppose I will go with the tubular manifold because it doesnt seem like the externally wastegeted mani will be of benefit to me.
 Old 02-26-2009, 02:40 PM   #12
ChrisK's Avatar
Posts: 1,168   (View Stats)
ChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the worldChrisK is the leader of the world
Groans: 56
correct.
ChrisK is offline   Reply With Quote
 Old 02-27-2009, 09:55 PM   #13
MStempted's Avatar
Posts: 199   (View Stats)
MStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the worldMStempted is the leader of the world
I feel like this place is turning in telemarketing / RadioShack kind of thing...
(no offense, business is business)
|| CP-E CAI || CP-E Inlet || CP-E FMIC || CP-E Catback || SU TurboSmart BOV || PG Turbo Manifold || CDI/PG Fuel Pump internals+spring || Denso 1step colder plugs || ATP DP || ATP FCD || ATP CEL trick || TWM stage2 SS+bushings || AWR Engine mount || SU rear diff mount || TT rear diff Rear mount || Whiteline anti-sway bar || AWR Endlinks || BC racing CO's || matt black OZ Ultraleggeras + Kumho ASX || Cobb AP || VEI boost || VEI oil Pressure/Water Temp. || AEM wideband || ApexI Turbo Timer || N2MB WOTbox || SM catchcan || BS delete+baffle kit || Spin on Oil filter conversion + Prosport sandwich ||
Other: Other mods are BS!
Sponsored by: STREETUNIT.COM check them out :thumbsup:
MStempted is offline   Reply With Quote
 Old 02-28-2009, 01:03 AM   #14
wassup61's Avatar
I simply intend to provide information and a solution that is viable for the OP, I am here not only to sell (options) but to provide technical support.
To answer nobmod's question, no, it is not necessary nor a wise expenditure of your money to go external wastegate on stock turbo. However, if you get the EWG now , you can futureproof for big turbo later.
-Jeff at PG
 Old 02-28-2009, 02:57 AM   #15
nobmood's Avatar
It's good to know when the EWG is necessary and I would also like to know if someone can get me a good deal on parts since I already made up my mind to use PG for my manifold. That is why I came to there section.
 Old 02-28-2009, 03:12 AM   #16
nobmood's Avatar
Can PG powder or ceramic coat the manifold?
 Old 02-28-2009, 01:26 PM   #17
MStempted's Avatar
Put the mani on the car let it turne bronze color and wear in, then take it off and get it jet coated. If you coat fresh polished manifold, overtime most coats come off.
PS Jeff that was not personal what so ever, I like PG and really appreciate your effort towards the community. If you knew me personally you would'nt take half of the shit I say seriously
The Following 2 Users Say Thank You to MStempted For This Useful Post:
nobmood (02-28-2009), wassup61 (02-28-2009)
 Old 02-28-2009, 10:13 PM   #18
wassup61's Avatar
Well FUCK YOU TOO <---no hard feelings seriously.
The Mani's can be Jet Hotted and guaranteed to hold fast! However, the manifolds are being redesigned for better clearance and flow. This new design will be released in time for mod season, and will have EWG option. They will also have erm... flange OPTIONS!!!!
We are also considering a top loader design if there is enough interest in the community.
IMO, EWGs are not necessary unless going with an upgraded turbo option.
-Jeff at PG
 Old 03-01-2009, 08:14 PM   #19
MStempted's Avatar
-Jeff at PG
THERE YOU GO!! lol
Turbo Manifold..... mrjoshyman MazdaSpeed 3/6 - Turbo Induction 43 02-28-2009 10:29 AM
Built Cylinder Head - 8700RPM Redline - Tubular Turbo Manifold (Pics) jhershorin MazdaSpeed 3 - Engine, Transmission & Driveline 36 07-23-2008 04:10 PM
DNP Turbo Manifold aviator79 Mazdaspeed3/6 General Discussion 24 04-15-2008 01:55 PM
Turbo manifold SSinstaller Mazdaspeed3/6 General Discussion 3 03-30-2008 02:50 PM
Page generated in 0.37516 seconds with 26 queries
