 Old 06-06-2019, 11:18 AM   #1
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
Default Front Axle Nut Coming Loose
For the first time in my life I have a weird problem. Front passenger axle nut keeps coming loose. I replaced the wheel bearings on both sides in December of 2017 with Timken units. And just about every other suspension component at that time.
A couple months ago noticed a noise from front wheel. Upon inspection I noticed the axle nut was loose. Properly torqued to 202 ft/lbs. and staked the nut. Well, I went a little tighter to 220.
Two days ago noise reappeared. This morning I had to tighten the nut again and noise is gone. WTF?
Can a bad hub cause this to occur? They should last the life of the car. How would I know the hub is compromised and not just the bearing?
Drivers side is fine. No issues.
Even though its tight again now, I have play from left to right but not up and down when grabbing the tire. Drivers side has zero play.
I belive the lower ball joint on the front lower control arm in the knuckle is shot. I have all new bearings/hub, and control arm due Saturday to install.
Thoughts anyone?
 Old 06-12-2019, 12:00 PM   #2
Posts: 2,826   (View Stats)
@Thor Hammer; Forgive the late reply. But those nuts are "one time use" items. They should be replaced and not reused. They lose tensile strength once torqued and do not hold torque properly if reused.
Get a new OEM nut. They are cheap. Torque and stake the new nut and you should be golden.
 Old 06-12-2019, 12:06 PM   #3
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Yeesh I reused mine. Looks like I'll buying OEM soon enough.
Stockish
 Old 06-21-2019, 11:56 AM   #4
Groans: 211
Havent been on here much lately so no problem. Thank you for the sage advice.
I don't know why it came loose that first time. It was of course a new nut. I know not to re-use them.
A couple weekends ago, I ended up installing a new OEM hub, bearing, and axle nut. Good as new now. The hub and bearing were absolutely destroyed. Lucky it lasted as long as it did.
MSMS3 (06-21-2019)
Front CV Axle Installation Help GohanX MazdaSpeed 6 - Engine, Transmission & Driveline 10 01-24-2019 11:26 AM
Loose change sound from front suspension alden MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 08-28-2018 04:05 AM
New Front CV Axle-Pulls To Right Thor Hammer MazdaSpeed 6 - Engine, Transmission & Driveline 5 03-22-2017 04:04 AM
Loose rattle Front Driver's side mikelevi MazdaSpeed 3/6 - Suspension & Brakes 10 03-10-2012 05:52 PM
klunking in driver front stealership told me front axle carrier never heard of such a part gotgrip MazdaSpeed 3/6 - Suspension & Brakes 6 02-25-2011 11:34 AM
Page generated in 0.24781 seconds with 22 queries
