 Old 02-16-2012, 03:27 PM   #1
Cdez's Avatar
Posts: 120   (View Stats)
Cdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond reputeCdez has a reputation beyond repute
Default Fuel cut or spark loss?
Hey Forum,
Semi-new to tuning however i had a stage 2 srt that i could just bolt everything on and not worry about tunning. It appears as tho things are a little different this time around with the speed 3. My first issue i have run into is that it appears at moderate speeds in a higher gear lets say 6th going 60mph if i am accelerating, in very rare cases it feels as tho the car may be slightly bogging out or loosing power and only for a second. A similar thing had happened in my srt in which i went to a step colder spark plug and better spark plug wires with less resistance. This case feels similar but the car only has 44k on it and i doubt i am running enough power to cause this.
I plan on running live data on my AP to see if its possibly a feul cut. I have heard that even with a few mods the feul pump in this car blows.
Any other suggestions or ideas of what it could be?
Thanks and Im excited to pick up as much information as I can on this forum.
Cdez is offline   Reply With Quote
 Old 02-16-2012, 04:34 PM   #2
TWOptSL0W's Avatar
Posts: 3,289   (View Stats)
Groans: 125
do you have an ap already? it might be a fuel pump slowly dying. also, are you flooring it? never floor in 6th unless youre over like 3500rpms is the general consensus. im not saying you will definitely blow up, but its more possible. pull your spark plugs and see if they need to be replaced too
 Old 02-17-2012, 07:04 AM   #3
Cdez's Avatar
Ya I have the ap. I'm not flooring it just speeding up a little to let's say pass someone, def shouldn't have to downshift. Should I have colder spark plugs anyways? I don't think I'm running enough power to need them. In my data logging what should I look for. I'm running a stage 1 93 tune
 Old 02-17-2012, 07:27 AM   #4
ak_spray's Avatar
Posts: 552   (View Stats)
ak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the worldak_spray is the leader of the world
I'm having this same problem. Always on the highway between 65-80mph. I have Denso step colder plugs gaped them to .027 but that was about a year ago and this is a new development.
I know fuel cut is more violent so you'd know if its that. I think it's probably blow out but I don't get my AP until today to check and if I even knew how to check I still don't think that I could diagnosis it as that.
One other thing I was thinking about is this.
How To: Ignition coil spring stretch mod
Not sure if its going to help but its a no cost option. There's so good info on blow out in that thread.
07 MS3 Sport
CPe: Stage2 RMM, XcelNANO Short Ram, Nviscid TIP, HPFP
SURE: AGS ATOM Shift Knob, ShortCut, CounterShift, TB/IM TIG, Injector Halos (Coming Soon)
JBR: RSB
Cobb: Accessport
Corksport: TMIC
CNT: Catted Downpipe
ak_spray is offline   Reply With Quote
 Old 02-17-2012, 07:35 AM   #5
The Angry Goose
Hectik1's Avatar
Posts: 3,219   (View Stats)
Hectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the worldHectik1 is the leader of the world
Groaned at 9 Times in 6 Posts
It sounds like spark. Check the gap on the plugs.
I had a hesitating problem. Checked the plugs and the gap was off. Regapped the plugs, and the problem went away.
Hector
2014 Mazda 3
2008 Mazdaspeed3-SOLD
1979 Mazda Rx7
Hectik1 is offline   Reply With Quote
The Following User Says Thank You to Hectik1 For This Useful Post:
ak_spray (02-17-2012)
 Old 02-17-2012, 07:47 AM   #6
It sounds to me like an overly aggressive load dynamics table, an aggressive boost dynamics table and a wgdc table that is a touch high. In 5th and 6th gears, the dynamics tables that allow the ecu authority to increase / decrease load have a tendancy to really wind up and over shoot / undershoot / overshoot, which makes your car feel as if it is studdering.
 Old 02-17-2012, 08:18 AM   #7
Cdez's Avatar
Ya Ill have to check the gaps in the plugs. I dont know if this matters but it also seems to only happen when my car first hits the highway. It is also occurs very seldom. Im going to try to replicate the issue while data logging. What in the log should I check to be off.
 Old 02-17-2012, 08:20 AM   #8
If you are blowing the plugs out, you will run silly rich... so log afr's.
I suspect you'll see heavy wgdc undulation though. (so log wgdc)
A standard wot log will probably do (includes afr, spark advance, wgdc, boost, load etc.).
 Old 02-17-2012, 08:45 AM   #9
Cdez's Avatar
For AFR im getting 14.7 at crusing and 11.7 WOT. Thats ok correct? For the rest i will need to check later today. What are the target numbers for these other fields?
Spark Adv, WGDC and load? Appreciate the insight. Mods are just cobb sri, corksport catback, and ap stage 1
 Old 02-17-2012, 08:49 AM   #10
Those afr's sound about right, but can you be sure the feeling you are getting is when the afr's are @ 11.7?
The target numbers for the other variables are not static, in that as the engine revs higher, boost rises and falls, etc... the values vary constantly.
Only a log would help us diagnose the issue.
If you can catch a log of it happening, I think we can nail it down.
 Old 02-17-2012, 10:16 AM   #11
Cdez's Avatar
Will do in a few hours this shitty massachuttes weather isnt WOT friendly right now
The Following User Says Thank You to Cdez For This Useful Post:
rfinkle2 (02-17-2012)
Fuel Range Loss After Installing SRI cshunter 2010 MS3 - Turbo Induction 48 01-16-2012 11:37 AM
WTF power loss and mpg loss ztnedman1 Gen2 MS3 General Discussion 10 11-07-2011 07:26 PM
Fuel cut or spark plug issue? ruf455 MazdaSpeed 3 - Engine, Transmission & Driveline 4 01-04-2011 12:23 PM
Maintenance on a 1973 I.H. Scout, Dangerous Car Has Exhaust Leak, Fuel Injector Cleaner, Ethanol and Fuel Grade, Is The Haltech Automotive News 0 07-10-2008 11:10 AM
Page generated in 0.31459 seconds with 24 queries
