 Old 02-15-2020, 01:11 AM   #1
Solarsurge's Avatar
Posts: 577   (View Stats)
Default Fuel Pressure Issues
There is no part number because Mazda calls for replacing the entire fuel rail, which comes with the sensor pre installed. But I think you just answered your own question. Lowest common denominator is the sensor if you’re getting 3 different readings from 3 different sensors. NORMAL fuel pressure readings are as follows:
KOEO (Key On Engine Off) : 55-70 psi
Idle : 400-500 warmed up to normal operating temps (can be slightly lower or higher, varies with conditions)
WOT : ALWAYS, ALWAYS, ALWAYS above 1600
Keep in mind fuel pressure at KOEO WILL taper off once the evap system kicks on. It should be 60 psi from a fresh prime COLD and it should hold fairly steady for a few minutes.
Edit: On a side note... NEVER trust eBay parts for critical components of your fuel system! You may be the lucky one and it may work out great and you get to brag that you saved a few bucks. OR you can sit and watch your car roast in flames because a cheap ass part failed and fuel sprayed all over a hot engine bay. That sucker is holding 1800+ psi at WOT. That requires quality materials, precision machining, and “higher than eBay” testing and quality control.
Fuel pressure issues - fed the hell up with this Xtrinsic1337 2010 MS3 - Troubleshoot/Diagnostics 15 07-10-2016 06:43 PM
High pressure fuel pump issues andrew1501 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 11-28-2015 02:17 PM
fuel pressure issues RogerH MazdaSpeed 6 - Engine, Transmission & Driveline 12 12-05-2013 02:58 PM
Need Help: Intermittent fuel pressure issues. speed31982 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 1 06-30-2012 04:18 PM
Need Help with Fuel Pressure Issues!! CCC Gen2 MS3 General Discussion 60 09-23-2011 05:36 PM
Page generated in 0.22728 seconds with 21 queries
