 Old 02-11-2012, 09:16 PM   #1
MSpeed34's Avatar
Posts: 20   (View Stats)
MSpeed34 is just really niceMSpeed34 is just really niceMSpeed34 is just really niceMSpeed34 is just really nice
Default fuel pump help!!
So I just bought some internals, and when i went to install them I noticed the bolts on the pumped looked worn! I think the previous owner might have installed them, I run 1700-1800 when wot should I return the ones I bought?
MSpeed34 is offline   Reply With Quote
 Old 02-11-2012, 09:29 PM   #2
dereeek's Avatar
Posts: 2,053   (View Stats)
Groans: 386
do you have an AP to verify your thoughts?
BNR3-FREEK-PU-398HP
 Old 02-11-2012, 09:34 PM   #3
Death-From-A-Mile's Avatar
Posts: 1,371   (View Stats)
Death-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the worldDeath-From-A-Mile is the leader of the world
Groans: 87
@MSpeed34
So, are you saying that you already have aftermarket internals? It is pretty easy to tell if you remove the pump....so remove the pump and check. Your thread really says nothing.
1 You bought internals
2 You took off the IC cover and saw the bolts have been touched
3 You stopped and thought well I must have internals
I would put a car back to stock if I was selling it or trading it in......tampered bolts mean nothing definitive.
BTW I hit mid 1700s on my stock pump at times.
Death-From-A-Mile is offline   Reply With Quote
 Old 02-11-2012, 09:55 PM   #4
MSpeed34's Avatar
Yes I do, ill post logs when i get home.
 Old 02-11-2012, 10:18 PM   #5
Daily Driver
Nitr0EngiE's Avatar
Posts: 2,614   (View Stats)
if you post pic of internals i can tell you if they are factory
The Following User Says Thank You to Nitr0EngiE For This Useful Post:
jack_hammer (02-11-2012)
 Old 02-11-2012, 10:22 PM   #6
Groans: 87
Yeah, logs do not really help. If you thought you had internals before why did you buy them? Just pull the damn pump.
 Old 02-11-2012, 10:30 PM   #7
frodaddyweez's Avatar
Posts: 988   (View Stats)
frodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the worldfrodaddyweez is the leader of the world
What mods do you have?
I would hit 1800s on stock pump fully bolted down here during the summer. Now when it got cold, thats when it started dipping below 1000psi.
2009 Mazdaspeed3: PTE 5857 25psi etuned by tooslow2010 --> SOLD
2011 Mustang Shelby GT500 w/SVTPP: 2.3L Trinity TVS w/2.4" VMP pulley, L&M NSR cams, JLT 123mm Intake, FRPP CobraJet Twin 65mm Throttle Body, 56# Injectors, VMP Fuel Pump Booster, AFCO Dual Pass Heat Exchanger, FRPP L Springs, BMR Adjustable Panhard Bar, Shaftmasters Aluminum One-piece Driveshaft, Lethal Performance Catless H-Pipe, Flowmaster Outlaw Axleback, 315 NT05r's
Lund Tuned 683whp/622wtq 11/11/16
Upcoming mods: Full-length Headers and ID1300s for E85
1995 Mazda Miata: Stock (daily)
frodaddyweez is offline   Reply With Quote
The Following User Says Thank You to frodaddyweez For This Useful Post:
Ms3_Miami (02-11-2012)
 Old 02-11-2012, 10:39 PM   #8
Groans: 87
PULL THE PUMP!
The Following User Says Thank You to Death-From-A-Mile For This Useful Post:
 Old 02-11-2012, 11:08 PM   #9
bigriver's Avatar
Posts: 1,123   (View Stats)
Maybe bolts are worn because prior owner installed internals and took them out before selling the car.
bigriver is offline   Reply With Quote
The Following User Says Thank You to bigriver For This Useful Post:
 Old 02-11-2012, 11:12 PM   #10
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
if you want to know if you have upgraded internals already or not, open the pump and look at the internals. don't waste your time with data logs.
it's fun to do bad things
 Old 02-11-2012, 11:14 PM   #11
Dmurray06's Avatar
Posts: 3,279   (View Stats)
Groans: 189
what they said
 Old 02-11-2012, 11:28 PM   #12
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
If he pulls the pump he'll still have to pull the internals to see won't he?
I'll prolly know the answer to this next weekend when I have my autotechs and do the install but right now I have no fucking clue.
 Old 02-12-2012, 12:21 AM   #13
Groans: 87
No, you can tell as soon as you pull the pump.
SJP0tato (02-12-2012)
Fuel Pump I_Heart_Haters 2010 MS3 - Engine, Transmission & Driveline 16 07-27-2011 02:02 PM
Issues with fuel pump pressures, aftermarket pump... ptperformance MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 0 10-04-2009 06:17 PM
PTP Fuel Pump Cornerfreak Mazdaspeed3/6 General Discussion 4 09-28-2009 09:35 AM
Page generated in 0.31986 seconds with 28 queries
