![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
(Thread Starter) | Not Ranked : 0 score I did pull the c-clip off the stock k04 and it fit over it but not very snug so i pulled it off and then bent it with a plyers and now it's kind of snug, not sure i feel to comfortable with that just in case the clip were to fly off. Thoughts on this or should I just keep the car parked until i can get a replacement c-clip?
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package |
(Thread Starter) | Not Ranked : 0 score Delete thread found some at auto zone. They are called e-clips not c-clips weird. Sent from my SCH-I535 using Tapatalk 2
Rep Power: 3167 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,400
Groans: 221
| Neutral : +1 score 1/8" right? I have a few packs at home. yea e-clips, found mine at home depot, 3 pack for like 0.89. I wont delete, I searched like a mofo when I dropped mine (way too easy to lose), but I'll fix the title to make it easier to find.
| Not Ranked : 0 score I tied a piece of wire around the groove on mine.
__________________ |
| Not Ranked : 0 score |
| NEW Turbosmart Internal Wastegate | cletusb | MazdaSpeed 3/6 - Turbo Induction | 2 | 09-10-2012 06:05 AM |
| Is my internal wastegate broke? | jiveturkey | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 28 | 07-22-2012 02:28 PM |
| can you utilize and internal AND external wastegate? | TWOptSL0W | MazdaSpeed 3/6 - Big Turbo Builds | 2 | 07-14-2011 09:29 PM |
| the ultimate internal wastegate | cbspeed3 | MazdaSpeed 3/6 - Turbo Induction | 2 | 09-12-2008 02:40 PM |
