  • 1 Post By PapaSmurf
 Old 08-19-2012, 10:50 AM   #1
Roddiy's Avatar
Posts: 5,388   (View Stats)
Groans: 279
Default Gen1/Gen2 Part throttle/cruise knock Discussion Thread.
@btstarcher @Stealth01 @G26
The discussion caught my attention, and it seems that it's not uncommon for your genJuans to get 5+ kr during crusing/part throttling.
I'm pretty sure this doesn't happen to GenPus.
ECU Logic perhaps?
something that crossed my mind was the "smiley" piston design. Maybe that helped?
Discuss.
mention edit: Because knowledge
@phate @rfinkle2 @Daddy Chinkus @driver311
@djuostein
2010 LSM Speed3
#BakeryTuned
 Old 08-19-2012, 10:52 AM   #2
exentix's Avatar
Posts: 1,568   (View Stats)
Groans: 46
subbing for further investigations. also, hopefully a solution.
 Old 08-19-2012, 11:06 AM   #3
The first generation MS3's definitely have more pt kr. I've heard various ideas about why Mazda designed the ignition maps that way, and although I'm not 100% sure, tend to agree with the idea that the ecu is hunting for max fuel economy.
breakfstincluded (08-19-2012)
 Old 08-19-2012, 11:08 AM   #4
3Gee Tee's Avatar
Posts: 1,533   (View Stats)
Would AP solve 100% of KR issues?
 Old 08-19-2012, 12:45 PM   #5
Stealth01's Avatar
Posts: 6,910   (View Stats)
Groans: 201
I have an AP and custom tune and I still get it.
Stealth01
2006 Mazdaspeed6 GT
The Following 3 Users Say Thank You to Stealth01 For This Useful Post:
3Gee Tee (08-19-2012), greenespeed (08-19-2012), rfinkle2 (08-23-2012)
 Old 08-19-2012, 12:53 PM   #6
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
With my built motor/fully mounted/no bsd. I see a shit load of PT knock around 3k (like 5.0 or so) when the engine is cold, when its warm its not as much (2.0-3.0)
My fix,
Dont watch knock. lol
I figure I'm putting no stress on the engine anyway, so why let it bother me when I'm cruising.
860whp/677wtq
2.7 V6 Ecoboost
helmetface (08-19-2012), rfinkle2 (08-23-2012)
 Old 08-19-2012, 01:06 PM   #7
NavySailorMS3's Avatar
Posts: 1,436   (View Stats)
NavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the worldNavySailorMS3 is the leader of the world
Groans: 47
Groaned at 31 Times in 28 Posts
The first thing i noticed when i got my AP was look at my knock and it was fine when i did some logs, but when i was cruising, i shit a brick when i saw i was getting around 5 counts of knock. I was scared of driving it at the time, but after talking with @p057 help told me it was common for the genwon.
NavySailorMS3 is offline   Reply With Quote
 Old 08-19-2012, 01:08 PM   #8
easy's Avatar
Posts: 539   (View Stats)
easy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the worldeasy is the leader of the world
Groans: 27
My fix,
your pistons are cold and hasn't expanded yet causing piston slap that gets picked up as KR, you have to warm her up a little before driving and you can set your kr sensor to come on at a hotter coolant temp so its not pulling timing from false knock on a cold motor.
aside from that, the last map im running i get no pt knock, even in high gear going up hill crusing ... only kr i got was usually noise from shifting and once in a while small blips of 2-3*, but i think that might be gas related
08 MS3
() Arias Pistons & Pauter Rods, P&P Head, Port match IM, DCR VVT, ARP Head Studs, Autotech CDFP internals, F2 BSD & Baffle, Cobb AP, Cobb SRI, PG TIP, CS Test Pipe, FMIC, Tial QR, JBR RMM/TMM, Oil spin-on Conversion, NGK iridiums IX
() Koni Yellows, Roadmagnet springs(6.5k Front, 6.4k Rear), Cobb RSB, TB trunk brace, AWR Rear Endlinks, SPC rear camber arms
() Centric Slotted Rotors/ Posi-Quiet pad
() Fidanza 11lbs. Flywheel, E4P STS, Cobb Shifter Weight, TWM Bushings, Redline MT-90
easy is offline   Reply With Quote
 Old 08-19-2012, 01:24 PM   #9
skiptowncat's Avatar
Posts: 1,592   (View Stats)
Little log I did of it, you can see the KR happen right after load/boost drop off and going part throttle. Ignition timing is advancing through the whole thing, it just can't be real knock otherwise we'd see the ignition retarding.
/thread
Tuned with by
The Following User Says Thank You to skiptowncat For This Useful Post:
exentix (08-19-2012)
 Old 08-19-2012, 01:28 PM   #10
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
subbed, I'll get this cruising 75-80 down I-5 south on my 80 minute trip.
I'll get a very slight less than 1 KR on acceleration after being at steady speed for a while. I lift off and it goes away.
It would make sense to me if it's for fuel economy.
 Old 08-19-2012, 04:43 PM   #11
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
show you're timing tables. this conversation is worthless without solid data points, and the tune will provide these.
I see no pt kr.
edit to add: changes to the kr sensor table too...
340hp / 371tq
 Old 08-19-2012, 05:11 PM   #12
410ms3's Avatar
Posts: 91   (View Stats)
410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future410ms3 has a brilliant future
I always get pt knock when i go on my first drive of the day no matter what the weather is like. I always let my car warm up but it seems once it reaches its peak temp i always have pt knock in 5th and 6th gear no matter wut. Anywhere from 5.9 to 7.0. If the motor only partially warmed up it wont do it but once coolant temps reach 175+ it starts. It will only do it a few times and then my pt knock subsides.
410ms3 is offline   Reply With Quote
 Old 08-19-2012, 05:14 PM   #13
speed14's Avatar
Posts: 527   (View Stats)
speed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the worldspeed14 is the leader of the world
I'll ad this as a data point.
Gen pu and i never see the dreaded 6.0 part throttle knock. However, when i am accelerating slowly (not WOT) i will sometimes get .7 to 1.0 KR right around 3k rpm as i get up to speed.
2010 Mazdaspeed 3 | Black Mica
COBB AP V3| HTP 3" Intake | CP-E TMIC | UR Turbo Back Exhuast | GS 3-Port EBCS | DO Meth Injection | Autotech Internals | Denso ITV22 | GFB Respons BPV | DDM 6000k lows | 3000k fogs | 18x8 TSW Nurburgrings | 235/40/18 Toyo Proxes | H&R Springs
speed14 is offline   Reply With Quote
The Following 2 Users Say Thank You to speed14 For This Useful Post:
CJM (08-23-2012), rfinkle2 (08-23-2012)
 Old 08-19-2012, 05:21 PM   #14
speed23's Avatar
Posts: 1,480   (View Stats)
On my 07 speed 3, I would get an event of KR starting at about 5 then decaying to zero as soon as it came up to operating temps everyday. It was only noticeable for me because I drive on the highway so it was always consistant speed, throttle, etc. This consistancy means that the ECU was asking for this.
Interestingly, this does not happen on my 06 speed6.
The Following User Says Thank You to speed23 For This Useful Post:
 Old 08-19-2012, 05:32 PM   #15
410ms3's Avatar
Same thing with my 08 ms3. Its like clockwork when i get on the highway. It use to freak me out but im use to it now.
 Old 08-19-2012, 07:31 PM   #16
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Don't get this pt knock very often. When it's colder in phoenix...i'll always get it in the same spot about 1mi from home...but I don't let my car warm up so i'm attributing it to possible engine noise (maybe piston slap). It's usually 2-3* then I let off...gone, after that I never get it.
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
The Following User Says Thank You to 86AmishMs3 For This Useful Post:
 Old 08-20-2012, 12:14 AM   #17
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
if its a 2010 genpu then your cursed!!!
 Old 08-23-2012, 11:13 AM   #18
easy's Avatar
Groans: 27
as per cobb help file:
"This ECU will constantly try to run more ignition advance than is necessary at part throttle conditions. It does this in order
to allow the ECU to detect MBT for each individual vehicle. Once the ECU exceeds MBT, the ECU will remove excess ignition
advance through the Knock Retard function. This is normal and should not concern you, cylinder pressures at part throttle
are not high enough to cause any damage. If consistent Knock Retard is reported or audible detonation is present, you are
welcome to remove ignition advance during part throttle conditions, although your fuel economy may go down during
these conditions."
08 MS3
The Following User Says Thank You to easy For This Useful Post:
 Old 08-23-2012, 12:04 PM   #19
kimura's Avatar
Posts: 170   (View Stats)
kimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the world
I used to get the typical PT KR all the time. especially getting on the highway in the morning before the car was fully warmed up. was an everyday occurrence to see 3-5* KR at PT
it went away completely after I did EGR delete, coolant bypass + gasket, TIG, injector seals, VTCS delete and OCC.
I run my DH all the time and I have it set up to alert me whenever I get KR over 1*
no more PT KR. I'm guessing the EGR is the culprit but I really don't know because I did so many mods at once
09 CWP MS3 Sport - ATP GT3071r on ~E30, ACT 6-puck, TR8 FMIC, Bilsteins, etc... sold
kimura is offline   Reply With Quote
Part throttle knock question??? cbspeed3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 63 07-27-2013 08:33 PM
Part Throttle Knock.. Silver Ecstasy MazdaSpeed 3/6 - ECU Computer Tuning 10 06-24-2009 12:34 AM
Part throttle knock solutions? dread
Cobb ATR Support
22 05-09-2009 07:47 AM
Knock at part throttle! SLOMS3 MazdaSpeed 3/6 - ECU Computer Tuning 7 04-13-2009 11:00 AM
Page generated in 0.40066 seconds with 36 queries
