 Old 10-20-2011, 05:47 PM   #1
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Default GTX3076R logs
Here are a couple logs and a map. I messed with ignition timing a little big. I think there's more to be had.
I've since tried to adjust the points down where the knock occurred, did so in the OL high throttle (no knock) map as well as the Max A and Max B tables.
This is on MBC. Grimmspeed goes on this weekend.
Lotta tuning left to do, if you plug into Virtual dyno, log 2's curve at smoothing 3 is pretty bad, haha.
Once the clutch gets installed hardcore tuning CAN BEGIN!
NOTE: Ignv1.2 is the map with the corrections made to timing based on these logs.
07 MS3
The original Genpoo Hater
crazyp (10-20-2011), Manny3 (03-03-2012)
 Old 10-20-2011, 07:18 PM   #2
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
looking good man
 Old 10-20-2011, 08:45 PM   #3
jracer's Avatar
Posts: 1,706   (View Stats)
Groans: 89
You don't have a speed6 silly !
Post in your own section !!
H&R springs/H&R 15mm spacers
MAP catless testpipe
MAP UICP
Grimmspeed 3 port
Cosworth filter
SSP relay kit
TWM Desert Eagle shift knob
AEM wideband gauge
Prosport boost gauge
EvoX piller pod
30%Tint
Slowpoke Tuned 339hp/336tq
**** SOLD *****
2006 speed6
Bullet Bitten, wallet empty. GTX3076R project begins Chimmike MazdaSpeed 3/6 - Big Turbo Builds 102 10-13-2011 06:25 AM
First AP logs robertof MazdaSpeed 3/6 - ECU Computer Tuning 1 07-27-2011 04:14 AM
first logs reidclark MazdaSpeed 3/6 - ECU Computer Tuning 13 07-26-2011 10:26 PM
Can someone please look at these logs bcmurphy87 MazdaSpeed 3/6 - ECU Computer Tuning 2 12-26-2010 10:42 PM
My Logs Eskareon MazdaSpeed 3/6 - ECU Computer Tuning 5 11-09-2010 10:54 AM
Page generated in 0.27111 seconds with 23 queries
