  • 1 Post By sharksinspace
 Old 12-27-2017, 05:39 PM   #1
turbskies's Avatar
Posts: 178   (View Stats)
turbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to beholdturbskies is a splendid one to behold
Groaned at 9 Times in 6 Posts
Default Halp me
Got a jbr short shift kit with solid shifter bushings and shit,but I don't know what this is...
Sent from my SM-N950U using Tapatalk
turbskies is offline   Reply With Quote
 Old 12-27-2017, 07:50 PM   #2
Orangatang's Avatar
Posts: 466   (View Stats)
Orangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the worldOrangatang is the leader of the world
Looks like a bolt and spacer to me.
I don't know know my ms6 at all but take a look at page 5. Page 5 Here...Not that hard to google and find.....even on a phone
Should you be installing it if you can't google the instructions or find them on the site?
Corksport stage 2 sri/tip, Autotech Internals, RSB,
CBE, Forge bpv, Koni FSD, Mazda Sport Springs,
ITV22, JBR PMM, JBR TMM, JBR RMM, Damond SSP
JBR SSB, CX piping with TR6, DM OCC
Dizzy Tuned
" I just don't need a stage 6, 16 puck, teflon diamond plated clutch that can snap a femur downshifting." -Raider
Orangatang is offline   Reply With Quote
The Following 2 Users Say Thank You to Orangatang For This Useful Post:
monkey.bones.007 (12-29-2017), sharksinspace (12-28-2017)
 Old 12-27-2017, 07:52 PM   #3
turbskies's Avatar
Already looked at instructions and that hardware is no where to be found, guess they gave me the wrong thing.
 Old 12-27-2017, 07:56 PM   #4
Orangatang's Avatar
Holy fuck did you read it? Do you know what a 55mm long bolt is?
Taken from the instructions from google from the link i sent from the page I said.
Remove the 2 bolts holding the cable mounting bracket to the transmission
with a 12mm socket and socket wrench (6 point socket is recommended)
Caution!! These bolts can be very tight! Take care when removing
them not to damage the shifter cable or anything else in the
surrounding area.
 Insert the 2 provide spacers under the cable mounting bracket as shown
below.
 Apply 1 lock washer 55mm long bolts and re-attach the cable mounting
bracket to the transmission and tighten using a 13mm socket and socket
 Reinstall the battery tray, battery, and battery terminals; positive terminal
first and the negative terminal last.
 Place 1 lock washer on each of the 8mm hex cap bolts, install the counter
weight along with both hex cap bolts and tighten using a 6mm hex wrench.
 Center the shifter cable over the new ball stud mount and push down until
you here it snap in place.
It should now look like this
Dizzy Tuned
The Following User Says Thank You to Orangatang For This Useful Post:
monkey.bones.007 (12-28-2017)
 Old 12-27-2017, 07:59 PM   #5
turbskies's Avatar
surrounding area.
below.
Sry mr. Orangadick I only read the shifter bushings one because they were attached outside the short shift kit box.
 Old 12-27-2017, 08:14 PM   #6
Orangatang's Avatar
Short shift kit and shifter bushings are two different things.
You said short shift kit and bushings. Obviously they are not bushings are are part of a kit.
I also told you where to look and a link and told you what page they were on and you said " Already looked at instructions and that hardware is no where to be found, guess they gave me the wrong thing." Which tells me that you didn't read anything or take time to look at the link. the instructions also told you where that part goes.
Dizzy Tuned
The Following 3 Users Say Thank You to Orangatang For This Useful Post:
g00s3y (12-28-2017), monkey.bones.007 (12-28-2017), sharksinspace (12-28-2017)
 Old 12-27-2017, 08:15 PM   #7
turbskies's Avatar
Read my opening post again plz.
The Following User Says NO Thank You to turbskies For This Un-useful Post:
g00s3y (12-28-2017)
 Old 12-28-2017, 07:22 AM   #8
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
lol
turbskies likes this.
Genpoo stuff
 Old 12-28-2017, 12:03 PM   #9
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
I would ask if OP is a fucking idiot, but being unable to spell "help" correctly, basically tells all.
 Old 12-28-2017, 12:08 PM   #10
turbskies's Avatar
Touche Mr. "g00s3y"
 Old 12-28-2017, 08:02 PM   #11
monkey.bones.007's Avatar
Posts: 3,853   (View Stats)
Originally Posted by turbskies View Post
Touche Mr. "g00s3y"
Well, it looks like Captn Awesome has arrived and his knowledge is even more under whelming than 3 Asian dudes in a sword fighting contests. Do you get paid to be this stupid or does it come naturally?
crapatalk it sucks for free
 Old 12-29-2017, 12:30 PM   #12
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
Re-read the opening post. Parts from short-shit kit need a home. Clicked link, bam...parts are for the cable bracket. Done and done. I'm confused why is OP still confused?
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
monkey.bones.007 (12-29-2017), shaneski (12-29-2017)
 Old 12-29-2017, 10:28 PM   #13
shaneski's Avatar
Posts: 505   (View Stats)
He seems like an illiterate fucktard. Someone must of made the account for him. Want's people to read his OP back to him cause he himself doesn't seem to have a fucking clue what it says or what he is actually asking.
It was clearly pointed out to the cock nozzle exactly what the parts were and he was still a clueless cunt about everything.
The Following User Says Thank You to shaneski For This Useful Post:
 Old 12-30-2017, 07:18 AM   #14
Posts: 2,825   (View Stats)
OP should have been held back in elementary school until he developed some basic reading comprehension skills. Wait . . . no, some idiot administrators thought they were doing "good" by socially promoting him. Now, he's probably out in the work force as a Mazda tech. We're stuck with him and so many more. Shit, guys what are our fucking PC school administrators doing to our country? Rant over.
monkey.bones.007 (12-30-2017)
 Old 12-30-2017, 07:21 AM   #15
turbskies's Avatar
Jee glad we can all be friends here.
Alright I think I'mma just end this thread
Last edited by turbskies; 12-30-2017 at 07:21 AM. Reason: MSF Database - Automerged Doublepost
 Old 12-30-2017, 07:25 AM   #16
Fstrnyou's Avatar
"No child left behind" was interpreted by the teachers as "if any of your students don't pass, you must be a bad teacher".
It's a very basic mentality on this forum. All you gotta do is say, "sorry everybody. I dun fucked up", offer a few handies, and don't repeatedly fuck up. Then you're golden.
Other rides:
History:
Last edited by Fstrnyou; 12-30-2017 at 07:25 AM. Reason: MSF Database - Automerged Doublepost
monkey.bones.007 (12-30-2017), MSMS3 (12-30-2017)
 Old 12-30-2017, 09:53 AM   #17
Everyone gets a participation medal. Failure is not an option despite how much you lack the ability to do what is requested of you.
MSMS3 (12-30-2017)
Halp! SoldierofTwilight MazdaSpeed 3/6 - Suspension & Brakes 13 03-21-2013 12:40 PM
Mittens halp! rb_ms3 Gen2 MS3 General Discussion 55 03-16-2013 10:19 PM
Page generated in 0.38477 seconds with 27 queries
