 Old 01-21-2020, 07:17 PM   #1
Roman-dude's Avatar
Posts: 56   (View Stats)
Roman-dude will become famous soon enoughRoman-dude will become famous soon enough
Default headlight goes out and back on - bulb?
my left headlight (low beam) is mostly out but sometimes comes on for periods of time (could be a day or so) and there's a flicker when I turn the lights on. Was going to replace the bulb but can it really be a faulty bulb if at times it works fine? Any ideas on what this may be are appreciated. thx
2008 gen1
Roman-dude is offline   Reply With Quote
 Old 01-21-2020, 08:25 PM   #2
Tres3's Avatar
Posts: 61   (View Stats)
Tres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to beholdTres3 is a splendid one to behold
Do Gen 1s have HIDs? (I have a 6)
If so, change the bulbs first (both sides). If it's still acting up, the connector or the ballast is the next suspect.
_____________
2006 Platinum MS6 GT
zzb at 156k - stock 2013 gen2 replacement - Cobb APv3, Fidanza LW Flywheel/Luk clutch, CorkSport BPV, Cobb SRI
Tres3 is offline   Reply With Quote
 Old 01-21-2020, 08:51 PM   #3
Roman-dude's Avatar
they are HIDs. I am not used to the bulbs sporadically working - always thought they either work or they don't but I guess I was wrong. I'll start with replacing the bulbs, thx
 Old 01-22-2020, 01:46 AM   #4
blackmica6's Avatar
Posts: 11   (View Stats)
blackmica6 will become famous soon enough
Also check the connectors for dust/rust, spray some contact cleaner if they're dirty.
Stock 2006 MS6 - daily driven
blackmica6 is offline   Reply With Quote
 Old 01-22-2020, 07:10 AM   #5
Posts: 2,826   (View Stats)
If you have an ‘08 Sport, it’s halogen, if it is a GT, low beams are HID xenon. Intermittent outage usually means plug/socket/connection corrosion. Clean and apply dielectric grease to the contacts to keep moisture out.
 Old 01-22-2020, 08:23 AM   #6
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
If they are HID, check connections to the ballast and to the bulb.
If all that checks out then It's probably the ballast or bulb is failing. What you can do is swap the left and right bulbs and see if the problem moves to the other headlight.
HIDs work by sending an electric arc between two electrodes. For whatever reason the system can't start or maintain that arc it will shut off.
2018 Audi RS3
2007 Acura TSX 6MT
How To Change A Headlight Bulb | Autoblog Wrenched Haltech Automotive News 0 10-26-2016 01:30 PM
Headlight Bulb Tiner Mazdaspeed3/6 General Discussion 8 07-26-2015 08:26 PM
2011 tech package headlight bulb chintastic Exterior 24 08-18-2012 04:33 PM
headlight bulb size MSPmemelvin Appearance - WHITE 4 11-10-2010 06:22 AM
Headlight out... it's not the bulb Eazy MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 02-11-2009 12:57 AM
Page generated in 0.26741 seconds with 24 queries
