![]() Join Date: Jun 2009
| Not Ranked : 0 score
Given your explanation, I’m inclined to agree with the suggestion that you have a failed rear motor mount. It’s a relatively inexpensive part and easy to replace. There are how-to instructions on that here. If the car runs just fine, otherwise, your CAI filter cleaning has nothing to do with it. Just coincidence.
| Excessive engine breaking/jerking when letting off throttle. | shawnmos | Mazdaspeed3/6 General Discussion | 12 | 09-12-2019 08:42 AM |
| HELP! P1680 code sputtering under heavy throttle | alphamfc1 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 17 | 01-31-2019 03:02 PM |
| High voltage now struggling under heavy throttle | njdurkin | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 8 | 11-24-2018 11:39 AM |
| Heavy Stumble Only After Prolonged Deceleration | Fulkrum | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 06-26-2018 06:19 AM |
| KR when letting off throttle | radioflyer | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 03-06-2012 10:39 AM |
