 Old 12-23-2019, 03:27 PM   #1
StopaOcean's Avatar
Posts: 14   (View Stats)
StopaOcean is on a distinguished road
Default Heavy deceleration after letting off throttle
Hi guys,
Since I bought my car I've noticed that when I left off the throttle in 1-3 (mainly 1st and 2nd) the car decelerates kind of jerky.
I understand it's going to decelerate more when letting off gas than say an auto, but it's very jerky.
I recently cleaned my CAI filter and after that the jerkiness stopped for a little bit and then started again.
I also noticed after doing so most of the pop back from the exhaust had stopped, but again that is back as well.
My car is 2008 with 80k and a Cobb CAI and a Freddy CBE. There's no AP, but I'm curious if the previous owner had one and was running a time.
Any ideas?
I've seen people complain of jerkiness when letting off and other recommend a RMM (which I plan to do) but cleaning the CAI has nothing to do with that and it helped.
Any help is appreciated!!
I should have titled it jerky deceleration not heavy...sorry
Last edited by StopaOcean; 12-23-2019 at 03:27 PM. Reason: MSF Database - Automerged Doublepost
StopaOcean is offline   Reply With Quote
 Old 12-25-2019, 03:09 PM   #2
Posts: 2,826   (View Stats)
Neutral  -1 score
@StopaOcean; How much experience do you have with manual transmission cars? Is this your first? How long have you been driving it?
danb (12-25-2019)
 Old 12-26-2019, 07:41 AM   #3
StopaOcean's Avatar
@msms3 this is my first manual car, however, I've driven manual probably around 20 times before on friends cars. I know that isn't a whole lot though.
I understand there is going to be heavy deceleration, I worded that kind of bad. My issue is just how jerky it is. I just feel like it's odd that as soon as I cleaned the intake the jerkiness disappeared for a bit. Maybe this is just how these cars are and I'm not that experienced.
That's why I wanted to hear from others.
The Following User Says Thank You to StopaOcean For This Useful Post:
MSMS3 (12-28-2019)
 Old 12-26-2019, 09:26 AM   #4
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
Check your rear motor mount. If it's bad, you can actually rock the engine fore and aft by just grabbing the oil pan.
Stockish
 Old 12-26-2019, 10:40 AM   #5
StopaOcean's Avatar
Thank you, will do.
 Old 12-28-2019, 05:37 AM   #6
Letting up on the gas completely in first gear will be abrupt, a little less so in second.
Given your explanation, I’m inclined to agree with the suggestion that you have a failed rear motor mount. It’s a relatively inexpensive part and easy to replace. There are how-to instructions on that here.
If the car runs just fine, otherwise, your CAI filter cleaning has nothing to do with it. Just coincidence.
Excessive engine breaking/jerking when letting off throttle. shawnmos Mazdaspeed3/6 General Discussion 12 09-12-2019 08:42 AM
HELP! P1680 code sputtering under heavy throttle alphamfc1 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 01-31-2019 03:02 PM
High voltage now struggling under heavy throttle njdurkin MazdaSpeed 3/6 - Troubleshoot/Diagnostics 8 11-24-2018 11:39 AM
Heavy Stumble Only After Prolonged Deceleration Fulkrum MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 06-26-2018 06:19 AM
KR when letting off throttle radioflyer MazdaSpeed 3/6 - ECU Computer Tuning 5 03-06-2012 10:39 AM
Page generated in 0.27500 seconds with 22 queries
