 Old 09-03-2017, 07:08 PM   #1
Yao06ms6's Avatar
Posts: 20   (View Stats)
Yao06ms6 has a little shameless behaviour in the past
Default Help help sputter stutter
Recently had an oil leak from the turbo not bad but wanted to replace it. Found an xspower header and ko4 turbo deal. Got it put on and now the car sounds off. Loud stutter when cold start and when revving it does the same not matter high or low rpm. When going into wot vehicl. struggle to make boost. Never had this problem until i had the replacement done. Help stuck this is my vehicle to get from point a to b.
Yao06ms6 is offline   Reply With Quote
 Old 09-03-2017, 09:10 PM   #2
Djohns's Avatar
Posts: 3,944   (View Stats)
I'm going to assume it's probably the Chinese ko4 you put in it.
2010 black mica speed3
Soon:built motor
 Old 09-03-2017, 10:04 PM   #3
Yao06ms6's Avatar
Damn it fuck loose header bolt too
 Old 09-03-2017, 10:22 PM   #4
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
I'm leaning heavy towards something wasn't hooked back up correctly...or at all.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 09-03-2017, 10:44 PM   #5
Yao06ms6's Avatar
Im leaning towards that aswell
 Old 09-04-2017, 01:27 AM   #6
Djohns's Avatar
Hm. Check ebcs.
Soon:built motor
 Old 09-04-2017, 10:56 AM   #7
Yao06ms6's Avatar
My buddy is stopping by today to check on it again ill put an update might put up a video on youtube so you guys can hear how it sounds
 Old 09-04-2017, 11:08 AM   #8
Posts: 2,826   (View Stats)
Why was the exhaust manifold (header) replaced?
What other mods are on this car? Stock downpipe and cats? Stock ECU tune? Stock intake?
A leaking exhaust manifold either at the manifold to cylinder head side or at the turbo/downpipe side can account for the sputtering sound. Lots of potential reasons to not make proper boost.
Do you have a way to data log?
BTW: The dyno chart on the website for those headers, showing 316 whp and 363 torque is pure BS on an otherwise stock vehicle. That is a tuned engine running and holding 18 psi boost. It most probably has quite a few bolt-ons and may be running an ethanol blend. If that is a stock K04 it is maxed out with intake, probably aftermarket dp/rp catless or high flow cats and a custom AP or Versatune tune and upgraded high pressure fuel pump internals. It may have an upgraded turbo.
If you are expecting those numbers by bolting that manifold between the engine and a K04 on stock tune with stock downpipe and midpipe you are going to be sadly dissapointed. And, if it somehow raises boost to 18-19 psi, you will soon throw a piston through your block if you don't upgrade the fuel pump internals and get a tune that appropriately handles the increased flow.
 Old 09-04-2017, 11:36 AM   #9
Yao06ms6's Avatar
No data log. Dont know how to lol car is stock besides bov intake and oil catch can
Anyone here from cali bay area? I got money to get this car fixed
Last edited by Yao06ms6; 09-04-2017 at 11:36 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-04-2017, 11:37 AM   #10
Fstrnyou's Avatar
Header and intake...and possibly no tune...great.
Other rides:
History:
 Old 09-04-2017, 11:39 AM   #11
Yao06ms6's Avatar
Its ran fine with the leak got this problem after the replacement
 Old 09-04-2017, 05:14 PM   #12
There are several threads here about various versions of that manifold. Not very favorable. At your mod level (or any) it seems to not be producing any meaningful gains.
But, you need to get back up and going. Looks like you are going to need to carefully check the manifold for gasket leaks on both the cylinder head side and the turbo side.
My guess that the manifold and gaskets are not sealing for any one of several reasons. You may want to start over with new studs and nuts, new gaskets and torque properly. The manifold could be warped, too. You might want to put your stock manifold back on. Guys here are easily maxing out the K04 and also taking many other K04 flange turbos up to 400 whp on the stock exhaust manifold.
Where was your stock turbo leaking oil? Into the intercooler, into the exhaust, or on the ground? A new Chinese K04 might be beneficial, but I'd mount it on the stock manifold.
 Old 09-05-2017, 12:32 AM   #13
Yao06ms6's Avatar
Leaking a little oil from the return line
 Old 09-05-2017, 08:17 AM   #14
Djohns's Avatar
If that's all it was leaking oil from there was no need to replace the turbo.
Soon:built motor
MSMS3 (09-08-2017)
 Old 09-05-2017, 04:17 PM   #15
Thor Hammer's Avatar
Posts: 1,847   (View Stats)
Groans: 211
What is your location? I live in Santa Cruz and work in South San Jose. I could swing by in the evening and have a look. Your money isn't needed. Bet I could track down the issue quickly.
List your SPECIFIC mods. You would greatly benefit from acquiring a Cobb AP or Versatuner and getting a custom or OTS tune from Stratified or Freektune. Your car will run much better and you will haz more boost!
 Old 09-14-2017, 08:54 AM   #16
Yao06ms6's Avatar
Thanks bro its running now but now aother problem lol
My buddy knew i bought the wrong lca but customized it to put it on lmao no i cant drive it need it replaced i bought 4 new ones from autozone. Never again will i purchase parts online because you can never compare parts
Thanks everyone will post more update on the vehicle
 Old 09-14-2017, 10:18 AM   #17
Djohns's Avatar
What was wrong with it?
Soon:built motor
 Old 09-14-2017, 02:19 PM   #18
Groans: 211
Rockauto has them. I use the Beck Arnley ones.
You have to lower the subframe to get the bolt out on the front rear lower arms. Which one is incorrect? They're simple to change.
 Old 09-22-2017, 06:59 PM   #19
Yao06ms6's Avatar
Changing all front lca it has cracks so i decided to just get them done.
Sputter when clutch engaged between gears way2ez4u Gen2 MS3 General Discussion 4 07-24-2016 02:35 PM
Car sputter after 3k rpm rgrz 2010 MS3 - Engine, Transmission & Driveline 8 08-31-2013 09:14 AM
2013 MS3 sputter in 3rd gear under exceleration dubtastic 2010 MS3 - Troubleshoot/Diagnostics 12 04-02-2013 09:46 PM
Sputter/stutter while WOT redmnsterut MazdaSpeed 6 - Engine, Transmission & Driveline 19 06-28-2012 07:11 PM
Intake Sputter Praelior MazdaSpeed 3/6 - Turbo Induction 9 02-28-2009 04:28 AM
Page generated in 0.36572 seconds with 25 queries
