 Old 09-02-2019, 09:56 AM   #1
LoveToCamp's Avatar
Posts: 52   (View Stats)
LoveToCamp is a jewel in the roughLoveToCamp is a jewel in the roughLoveToCamp is a jewel in the roughLoveToCamp is a jewel in the rough
Default Help identifying mods and exhaust system
Just bought a 2013 gen 2 speed 3. I need help identifying whether it has anything done to the exhaust. I'm not sure because I never got this far on my old one other than simple bolt on mods.
Also need some help identifying mods. I haven't had a speed in a bit over 2 years but I think I got most of them down. Previous owner was a big fan of cobb, it seems.
All the mods I've identified are as follows. Did I miss anything else? Pics below in link, [IMG] tags aren't working with imgur.
1. HPFP Internals <-- I'm asumming it has this, pretty sure it would have blown up by now if it didn't.
2. Cobb SRI+ Intake
3. Cobb FMIC
4. CS RMM
5. GFB BOV
6. Cobb DP (didn't take a pic behind heat shield, but I clearly saw the big COBB letters)
https://imgur.com/a/2GpKkGJ
2013 MazdaSpeed 3 - 88K Miles
Mods:
1. HPFP Internals
2. Cobb SRI+TIP
3. CS RMM
4. CS Shift Plate
5. Cobb FMIC
6. Cobb DP
7. GFB Blow Off Valve
8. Ultimate Racing Catback
9. AP v3 w/ Custom Freektune
LoveToCamp is offline   Reply With Quote
 Old 09-02-2019, 12:12 PM   #2
JSmith's Avatar
Posts: 707   (View Stats)
Groans: 106
CS shift plate as well from the pictures.
Check for a rear motor mount and rear sway bar too.
The Following User Says Thank You to JSmith For This Useful Post:
LoveToCamp (09-29-2019)
 Old 09-02-2019, 03:40 PM   #3
lazza151's Avatar
Posts: 50   (View Stats)
lazza151 has a spectacular aura aboutlazza151 has a spectacular aura about
Regarding the HPFP I would still advise you to check.. or take your fuel pressure readings with a AP.
Really you need to confirm that your fuel pressure gets into the 17 or 1800's and does not drop below 1600 at WOT
2010 Gen 2 Velocity Red
- Freektuned
- AP V3
- HPFP
- Cobb RMM
- Damond PMM
- Turbo Back Custom SS Race Pipe
- K&N Drop in Air Filter
- Bov
- Raiden by Lenso Forge Type Monoblock 18 x 8 ET/ 35 Wheels
- Falken Azenis FK510 235/40 Tyres
- Webasto Sunroof.
lazza151 is offline   Reply With Quote
The Following User Says Thank You to lazza151 For This Useful Post:
The Following User Says NO Thank You to lazza151 For This Un-useful Post:
Vansquish (09-03-2019)
 Old 09-03-2019, 11:20 AM   #4
Bertospeed3's Avatar
Posts: 149   (View Stats)
Bertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant futureBertospeed3 has a brilliant future
i would recommend physically pulling hpfp and look at them to confirm
2010 MS3 - Tuned By Nishan
Autotech Fuel Pump Internals
OBX R Custom Exhaust
Cobb SF Intake & TIH w. Blitz Filter
CP-e TMIC
Corksport Dual VTA BPV
JBR 88 Duro RMM
Bertospeed3 is online now   Reply With Quote
The Following 2 Users Say Thank You to Bertospeed3 For This Useful Post:
LoveToCamp (09-29-2019), Vansquish (09-03-2019)
 Old 09-03-2019, 06:07 PM   #5
Police - Grammarhead
Vansquish's Avatar
There is no way to confirm whether you have upgraded HPFP internals except physically removing and examining the pump internals.
You should definitely do this, as you are at risk of blowing your motor without them.
LoveToCamp (09-29-2019), MSMS3 (09-03-2019)
Identifying mods? Marshy 2010 MS3 - Troubleshoot/Diagnostics 18 06-27-2015 06:24 PM
Help Identifying the Exhaust Parts zehnder.eric Mazdaspeed3/6 General Discussion 6 08-04-2011 10:49 PM
Best First Mods To My MS3 - CAI, Downpipe, Exhaust? cocktailfruit MazdaSpeed 3/6 - Turbo Induction 27 12-19-2010 03:58 PM
My first speed6 mods, exhaust/TP. What am i getting into? KruV Mazdaspeed3/6 General Discussion 10 12-08-2010 07:50 PM
PTP's CAT back exhaust system, soon to be TBE system. ptperformance Mazdaspeed3/6 General Discussion 56 10-05-2008 02:08 PM
Page generated in 0.25602 seconds with 24 queries
