Like Tree17Likes
 Old 10-07-2013, 11:57 AM   #161
Police
ganque's Avatar
ganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the worldganque is the leader of the world
Groaned at 9 Times in 9 Posts
This is how bad it sounds on cold start... then took the camera to the inside so you guys can see what the AP reads
SOLD MS3 GT 2009 - Garret GTX3076R -CP-E 4' TIP // CP-E big MAF intake // Turbosmart compact BPV // Lamin-X yellow fog covers // Hella Xtreme yellow fog bulbs // Eonon 7" screen // Prosport Boost Gauge // Ventpod Single Gauge Pod // CPE TowPlate // MSD Dashhawk // COBB AccessPort // USDM ECU // CM Downpipe // Ingalls Torque Damper // Denso ITV24 // GV style front lip // TRZ rear motor mount // PG/Godspeed FMIC // Magnaflow CBE // COBB counter shiftweight // CPE PMM // CPE TMM // Autotech HPFP internals // PERM tune in progress // COBB EBCS // HPFPupgrade injector seals // Apex-i TT // PERM tune // Final numbers: 427 WHP - 471 WTQ
SOLD: BMW 325ci coupe Formula 1 package 2001 - Daily driven FTW!
MS3 vs Focus ST vs Camaro LS1 ---> Click here
TEH MEXICAN'T PERM!
Current whip: 2013 BMW 135i ///M Sport - BMW Performance Exhaust System - BurgerTuning JB4 - Golf Tee Mod - COBB Charge Pipe - BMW Blackline taillights - BMW Performance CF rear spoiler - 8K LED Angel eyes
ganque is offline   Reply With Quote
 Old 10-07-2013, 12:13 PM   #162
btstarcher's Avatar
Posts: 4,852   (View Stats)
Raise your idle to 1000? LOL
Is that misfiring at idle? What are your plugs gapped at again? I know you've swapped coilpacks but what about plugs?
SnailTune in progress
 Old 10-07-2013, 12:14 PM   #163
Car needs air fuel and spark. You covered spark by looking at plugs and swapping coils. The next would be air and fuel.
I would do a leakdown test just to make sure all is well and then look at the injector, seals and valves next.
Was VVT replaced?
btstarcher (10-07-2013)
 Old 10-07-2013, 12:38 PM   #164
Police
ganque's Avatar
Was VVT replaced?
not yet. and I don't know anyone who has the tool to run the leakdown test
TEH MEXICAN'T PERM!
 Old 10-07-2013, 04:44 PM   #165
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Maybe it's just me but your fuel pressure seems high. Mine is only in the 400-500 psi area at idle.
About a month ago I had an issue where I kept getting a P0303 code but my idle fp was 200-300 psi and wot fp was down to 1600ish where it was normally 1800. I narrowed it down to it either being an injector issue or my relief valve.
I'm mostly sure it was my rv because fuel pressure dropped when the engine was off and warm. I never resolved the issue though because my fp returned to normal right before I was going to buy a replacement rv. I haven't had any issues since and there haven't been any codes.
Also here's what Mazda says about P0302
If I was in your position I'd check all the wiring again to see if anything is amiss. If it all checks out then try something like this to check injectors.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
Tokay444 (10-07-2013)
 Old 10-07-2013, 06:11 PM   #166
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Nice. Mazda can control individual injectors with their scan tool.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 10-07-2013, 11:21 PM   #167
Police
ganque's Avatar
Attachment 130314
Attachment 130315
Fuel pressure under idle is normally around 440-450. Maybe the ECU is requesting more gas to the injectors which means is trying to send more fuel pressure.
:S
TEH MEXICAN'T PERM!
 Old 10-08-2013, 03:27 PM   #168
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Also as a quick check if you haven't already done it: take out the #2 coil and swap it for another cylinder. See if the misfire moves. Pull the plugs and see if #2 shows any damage; if not, clean them up and move the plug to a different cylinder. See if the misfire moves.
 Old 10-08-2013, 03:34 PM   #169
btstarcher's Avatar
He swapped coils but not plugs yet....
silvapain (10-08-2013)
 Old 10-08-2013, 06:35 PM   #170
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
I'm going to speak for ganque in case it might move along the discussion, but he has already moved coils and replaced plugs.
Originally Posted by ganque View Post
Hey guys, sorry for bringing this thread back... I rather using this one since it might or might not be related...
Another issue. P0302 constalty (Misfire on cyl #2 ), no matter how many times I delete it it pops up again...
Symptoms:
- Car hiccups randomly all the time on idle. Sounds worst on cold start.
- Car runs extremely fine during regular driving, it actually spools up normally and feels quite strong. Some KR comes randomly.
- AFRs are again oscillating between 14.4 and 15.2 on idle (so it´s leaning).
- STFTs are kinda low on cold start but they eventually hit -0.16 on idle, STFT are good I think..
Things that have been done already:
- Swapped coils between cyl #1 and #2 , issue remains on cyl 2.
- Replaced the spark plugs. Had a brand new NGK 1 step colder and used an old Denso ITV24... same issue
- Tried to do a compression test but my friend's tester gauge wasn't working properly.... but he is a very qualified mechanic and he said that the engine looked good....
So.. what do you guys think? I'm thinking on a bad injector? bad ECU harness wiring somewhere?
Sent from my LG-MS770 using Tapatalk now Free
it's fun to do bad things
The Following User Says Thank You to jack_hammer For This Useful Post:
 Old 10-08-2013, 06:41 PM   #171
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
im no expert at all, but in the vid i see your temp gauge is at the cold side. was the fp higher because the idle was higher to warm up the car? it came down a bit in the vid as i assume idle was settling with temp
 Old 10-10-2013, 03:26 PM   #172
azazelthegreat's Avatar
Posts: 596   (View Stats)
azazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the worldazazelthegreat is the leader of the world
Correct me if im wrong but cant you still half ass a leakdown test just to see if air comes out of places that it shouldn't
(hooking up a air compressor to cylinders etc)
id message daafisch, i remember him mentioning that his compression results werent to far apart or something, then it turned into a catastrophic mess
azazelthegreat is offline   Reply With Quote
 Old 10-10-2013, 03:46 PM   #173
Tokay444's Avatar
Groans: 793
Same here. Compression is +/- 2psi.
Leak down 31% on cyl 3. Lol.
Demodded.
The Seals
 Old 10-11-2013, 08:36 PM   #174
Tokay444's Avatar
Groans: 793
Are you consuming any oil homie?
Demodded.
The Seals
azazelthegreat (10-11-2013)
 Old 10-11-2013, 09:27 PM   #175
btstarcher's Avatar
I think he found a bad injector.
 Old 10-11-2013, 10:35 PM   #176
Groans: 549
That's got to be disconcerting to anyone who takes comfort in good compression numbers
 Old 10-12-2013, 06:31 AM   #177
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
A compression test just shows that the engine can compress the air and fuel where a leak down test will tell you if it can hold that pressure as well as where its bleeding off.
 Old 06-09-2014, 04:05 AM   #178
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
Going to resurrect this shit b/c I'm throwing p0302s all day, rando p0300s and I'm on my 2nd qrt of oil between oil changes (not a full 2nd qrt tho, just up to 1.5L with 2200km's to go before next oil change).
What would this extra oil consumption mean besides something bad?
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
 Old 06-09-2014, 08:21 AM   #179
Tokay444's Avatar
Groans: 793
BESIDES something bad? Nothing. It's something bad.
ganque and Marcus like this.
Demodded.
The Seals
Dizzy Turbo (06-09-2014), Easter Bunny (06-09-2014), ganque (06-11-2014)
 Old 06-09-2014, 02:38 PM   #180
Marcus's Avatar
Balls.
 Old 11-04-2014, 01:03 PM   #181
phecker410's Avatar
Posts: 143   (View Stats)
phecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant futurephecker410 has a brilliant future
Another thread revival.
I'm displaying similar symptoms that are worsening recently (possibly colder weather)
My exception is that I have a warranty replacement motor from mazda with ~4000 miles on it sooo I'm assuming that the cylinders hold pressure just fine and that the valves are pretty clean.
Dealership mentioned that I might need injectors prior to swap but never replaced/mentioned it again.
Time to check injectors?
06 MS6 Sport,ZZB and warranty motor replacement 8/9/14
SU SRI w/ COBB MAF:::JBR TIP:::JBR 80aTRILOGY:::Strat+ Base Map:::MATT DAMOND FULL EGR DELETE:::VTCS Delete:::CP-E SafeSeals
phecker410 is offline   Reply With Quote
 Old 11-14-2014, 02:32 AM   #182
Marcus's Avatar
What was the mileage on the injectors/old motor?
 Old 11-14-2014, 08:40 AM   #183
phecker410's Avatar
68,xxx. I've had it looked at and I don't think it's anything to do with the injectors at this point but we'll see
 Old 11-14-2014, 02:10 PM   #184
Marcus's Avatar
I'll re-reference my recent thread for some moar infos:
How I (seem to have) fixed my Early Speed6 Misfire Issue
Is yours the early model speed6 or post 2006.5?
 Old 11-15-2014, 08:34 AM   #185
phecker410's Avatar
Thank you I just read through that.
And at risk of sounding like a brownie fuck-tard, I didn't know there was a difference with the ms6
 Old 11-16-2014, 06:53 PM   #186
Marcus's Avatar
Easiest way to check besides your vehicle # would be pop your hood, find our cold pipe. If the stock oem plastic pipe is straight you have an early model speed6. If it's a bent elbow, you have a 2006.5+.
Mazda made a few changes mid production.
 Old 06-24-2019, 12:18 PM   #187
ghost-rider's Avatar
Posts: 10   (View Stats)
ghost-rider will become famous soon enoughghost-rider will become famous soon enough
sorry for posting in your old thread, but we didnt get the answer to these problems.
did you solve the startup misfire you posted years ago??
got the same issue and already changed coils, spark plugs and injectors and tested compression.
I got spark and suspect the already changed clean injector to bei failing.
but idk for sure if something bad is happening in this cylinder for some reason.
greets from germany
ghost-rider is offline   Reply With Quote
 Old 06-24-2019, 01:04 PM   #188
Posts: 2,826   (View Stats)
greets from germany
Which member are you attempting to respond to? You might want to try to send a PM to that person. Chances are pretty high that he is not following this thread all these years later.
Vansquish (06-24-2019)
 Old 06-24-2019, 01:09 PM   #189
i tried before, but dont have permission with only 1 post on my account.
Would you mind, send a pm to him for me and help some buddy from overseas
 Old 06-24-2019, 03:55 PM   #190
Police - Grammarhead
Vansquish's Avatar
We still need to know WHO you are trying to contact? A lot of people have responded to this thread over the years.
As far as diagnosing your problem, have you tested the harness to see if there are any weaknesses? Specifically, have you checked the ignition harness to make sure that there are no broken/bent pins that would cause cylinder 2 to get weak or no spark?
Similarly, have you checked the injector harness for the same sorts of faults?
ghost-rider (06-25-2019)
 Old 06-24-2019, 06:01 PM   #191
youre right sir, i saw the video on top of this page from "ganque".
Already saw a lot of threads an contacted a lot of people since over a year with this problem, and never got an advice which solved this problem, just the started threads...
you know this problem on the internet for sure.
Hopefully its okay to use this thread for my personal problem.
Otherwise is will start a new one.
I tried new and old coils and spark plugs, they all worked well and got strong spark.
Checked compression on cold engine (not optimal, i know) tested all cylinders with 135-140 psi.
Only on cylinder 2 i dont see any response if i unplug the coil, so i would think on injectors, but these got cleaned an checked recently.
Curious the misfire only persists in idle oder very low rpm, if i push on the pedal it seems to work.
I will check the injector harness next and clean the plugs, as i lubed the o-ring with engine oil there could be a culprit. Even when i cleaned with brake clean after.
 Old 06-24-2019, 07:54 PM   #192
Vansquish's Avatar
What was the gap on the spark plugs that you installed?
 Old 06-25-2019, 12:41 PM   #193
installed the genpu Plugs ILTR6A-7G, and tested also the old 8G Plugs which were only 2 years old. The Coils were also NGK, new ones mod. 42899.
Also changed Intake Manifold and Throttle Body Gasket, aswell as Header and both Turbogaskets as i installed a new Turbocharger at this point.
I got an primary EGR Delete and added also new Gaskets to be sure and threadsealant on the Plug in the Intake Manifold.
Will check the harness, if some of the lubrication oil got inside the plugs an clean them with contactspray.
You can see the jumping stft in the logfile
 Old 06-25-2019, 12:56 PM   #194
Vansquish's Avatar
You didn't answer the question. What was the gap in the spark plugs? Did you check to make sure that they were in spec between 0.024 and 0.027 inches (about 0.61mm - 0.68mm)?
ghost-rider (06-26-2019), MSMS3 (06-25-2019)
 Old 06-25-2019, 02:58 PM   #195
Not to pile on but proper plug gap is critical on this particular engine. Vanquish is right to ask you twice.
They need to be tighter than most sets come from the factory and never trust the factory to get them right, anyway. The fine wire iridium tip is very easily damaged in gapping. Do not use a gapping tool that scrapes that tip.
I don't know if that solves your problem, but it will eliminate one variable.
 Old 06-25-2019, 03:20 PM   #196
yes sure, i gapped them just a little bit more than they were stock to 0.65, the old ones were 0.8 as spec. No gapping on these ones was needed to spec.
Do you think that some engine oil could make its way into the injector plug also because of oiling the o-ring?
i dont get you wrong guys, im familiar with this platform since 6 years now, before i had a 3 MPS and for over 2 years the 6 now
The Following 2 Users Say Thank You to ghost-rider For This Useful Post:
MSMS3 (06-25-2019), Vansquish (06-26-2019)
 Old 06-27-2019, 03:25 PM   #197
i took the intake manifold off today an cleaned the harness connectors and injector connectors with electric cleaner, now i get a response from cylinder 2 when i unclip the coil.
Not as much noticable as when i took the other cylinders off but still hearable from the exhaust. With the cylinder 2 unclipped i get much more misfires at idle.
Hold the RPM at 2000 for expample and get no misfires, mysteriously.
Sure without the Intake on the car, the MAF was not on the car at this moment, it runs in limp mode.
How about the o2?? That would be my last idea, as the ECU just regulates with the o2 and throttle?
HM-Upgrade K04 Turbocharger, 3" Corksport Catted DP, 3" FMS Catback Exhaust, HG-Motorsport HPFP Internals, Upgraded TMIC, Silicone Turbo Inlet Pipe+Neck, Silicone Intercooler Hose, Simota Podfilter, GFB Mach 2 BPV, Primary EGR Delete Kozmic, PTFE Intake and Throttle Gasket, Throttle Coolant Delete, Cobb Accessport V3
 Old 06-30-2019, 09:39 AM   #198
no one looking at the video or log yet??
P0302 misfire... SlickDevil Gen2 MS3 General Discussion 42 08-24-2016 08:48 PM
p0302 misfire only under pressure? Fan2zo MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 02-06-2015 05:48 PM
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 09:35 PM
Page generated in 0.58137 seconds with 35 queries
