 Old 01-29-2019, 02:27 PM   #1
Reds3's Avatar
Posts: 31   (View Stats)
Reds3 is a jewel in the roughReds3 is a jewel in the roughReds3 is a jewel in the roughReds3 is a jewel in the rough
Default High Mileage Compression test #'s
Last weekend i had the opportunity to do a compression test on my 1st gen while i was doing some other friends cars. 219K on the odo and only mod is a cobb SRI, The numbers im getting are as follows and unfortunately, i do not have wet test numbers but would assume they would be in the mid to high 160-170 with a wet test.
(Dry test)
5 trys until peak per cyl.
219889 Kilometers
Cyl 1 - 155 psi
Cyl 2 - 150 psi
Cyl 3 - 160 psi
Cyl 4 - 155 psi
No current issues with the vehicle, i was just interested in seeing what numbers i had since i bought it.
im wondering what current numbers other people have with higher mileages vehicles. The reason is because i have found a few threads pertaining to compression tests with much lower mileage motors and similar readings (some as low as 71k) and wanted some opinions.
2007 Mazdaspeed 3 / Cobb SRI / 219K and Counting
1995 EG6 B16A3 78K *sold*
Reds3 is offline   Reply With Quote
 Old 01-29-2019, 03:06 PM   #2
Posts: 2,235   (View Stats)
The important thing is to have near equal reading and this is about what you got.
The altitude, gage, tests conditions etc can affect the final numbers but all 4 will be affected by the same parameter so if all 4 are equal, it is looking very good. I wouldn't worry about it.
Your #2 is a bit lower but it isn't a ringland, it would be worse than this.
i was worried at first because peoples talk about +/-180psi and the best i got with any of the 3 mzr i had + 1 rebuild, remain at best at 165psi.....I tested 2 gages and i used the same place to test them with throttle body opened etc and i never got 180 on any...
Reds3 (01-30-2019)
How to take account of high compression pistons EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 15 01-21-2017 04:43 PM
High Compression Input - DD use GroceryGtr MazdaSpeed 6 - Engine, Transmission & Driveline 8 11-27-2015 06:13 PM
Looking at high mileage MS6... anesthetize Mazdaspeed3/6 General Discussion 9 08-05-2015 02:06 PM
Mazdafreak's High Compression Build! mazdafreak Mazda MZR DISI Engine Builds (2006-2013) 159 06-04-2015 06:44 AM
Page generated in 0.24634 seconds with 21 queries
